Question about Biostar K8VGA-M Motherboard
Long Beeps every other second
I have a K8VGA-M motherboard and it wont boot up it just makes some long beeps every other second and it does nothing. I had it for about 2yrs now and this is the first time this has happened. What can I do?
    Guru:
  • 120 Answers
Ok, I did some research into your board. Your motherboard is running an award bios. All motherboards use beep codes to tell you what is wrong. You've got a hardware problem somewhere for sure, but where is the question. If you're having 1 long beep, with the same timing and frequency over and over then according to the codes you most likely have a memory problem. Try resetting the motherboard by resetting the cmos ( you can also do this by removing the power from the computer and taking the little clock battery off of the motherboard for about a minute). Also, make sure your ram is tightly seated. In fact, take the ram out and then place it back in. Try running the computer with only one of the chips of ram installed (if you have more than 1 chip that is). Maybe one of the chips went bad. Finally, here is a list of the award beep codes. If you are getting beeps that match one of these examples better than we can go from there. 1 Long, 2 Short - Video adapter failure Repeating (Endless loop)- Memory error 1 Long, 3 Short - Video adapter failure High freq. beeps (while running) - CPU is overheating Repeating High, Low beeps- CPU failure
Posted on Sep 30, 2007
Continues two beeps and wont boot
From the time it start beep it means either your ram or video card is not good. My recommendation would be checking to connections of the ram and the any other card you have installed on the motherboards or simply just dis connect them wait a couple seconds and connect them back properly and firmly.
KJR
Jan 10, 2013 | Foxconn Computers & Internet
Beep comes first and then no beep at all.no signal to monitor
un plug the RAM
then on the system without ram. if you hear the continuos beeps,off the system and fit the same ram properly.
if again you have the same problem,then Replace the New Ram.
Feb 12, 2010 | Biostar K8VGA-M Motherboard
Beeping when i add ram
please see this link to determine the real problem. it depends on how many beeps you hear.
http://www.computerhope.com/beep.htm
Jan 21, 2010 | Intel Server Board SE7501WV2 Motherboard
Consecutive beeps last 10 seconds, silence for 5 seconds, the long beep for 10 seconds...pattern repeats. Nothing comes on screen. I removed single RAM card, tried other slot, same problem. I powered it on...
how many beeps any breaks between beeps and then how many like 3 beeps then stops for 1 sec then beep beep beep stop beep beep beep check to make sure that your installing your memory sticks right and they are seated all the way make sure all cards are seated right all wires are not shorting out and a worst case your cpu is good
Dec 25, 2009 | Biostar K8VGA-M Motherboard
When i try to boot my pc, it continuously beeps
check it one by one first is remove the ram, then then restart it, if nothing use another vga card ..insert the ram and then start again.. else..reset it by removing the battery in few second the start again until you find the couse of that problem..
Sep 13, 2009 | ASUS P5N32-E SLI Motherboard
Wont boot up just beeps
3 beeps points to the memory. Try re-seating the RAM.
Mar 20, 2009 | Soyo P4VTE (SY-P4VTE) Motherboard
AK77 Pro won't boot, won't go into setup, just beeps
remove bios battery from motherboard for few seconds
and bios will reset
Dec 18, 2008 | Acer AOpen AK77 Pro(A) (91.89A10.104)...
Computer beeps three times and will not start
Clear CMOS/ Remove battery for 10 minutes, reinstall battery & wait for another 10 minutes before turn on. Three Beeps means RAM is defective/ not detected.
Jun 27, 2008 | Foxconn (755A01-6ELRS) (K8S755A6ELRS)...
Wont boot up at all.
3 Beeps is a Power on self test alert. General this is a card isn't inserted properly or maybe is an AGP card in a PCI slot
Jun 05, 2008 | ASUS M2R32-MVP Motherboard
Biostar K8VGA-M Motherboard Logo
528 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Martin Murray
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
