Question about Systemax Venture S519J (988868) PC Desktop
Ram memory I just got and installed 2 new mem.strips I should now have 2gb it appears that only one is active. I can run bio's and it says its there in slot 3 and slot 0 did I put one in the wrong place? Thank You Michael49er
  • Michael Ericson Sep 30, 2007
    Hi thank you
    Its the mem. that was recommended I took out the 512 and put new ones in but I didn't know I had that many slots should they be in slt. 0 and slt.1
    President:
  • 2,961 Answers
The problem may be that your new memory is not compatable with the current memory and board, the easiest way is to remove your memory and just install the new memory and try all slots, if you get no boot then you know the memory is not compatable.
Posted on Sep 30, 2007
  • andrew pester
    andrew pester Sep 30, 2007
    depends on the board, it could be either of the slots really, the pc wont work at all if you use the wrong one or it wont recognise some of the ram
I upgraded Memory to 4GB with Two 2GB SD Ram Modules but System shows Only One 2GB module and does not show/recognize second module. BIOS Setting Shows Second Slot/RAM Module Not Activated.
is the module in properly?,is anything broken?? switch them around and see if the module is good or not,also,just because the motherboard supports 2 modules,if intel only recognizes 2gb then that is all,whether you have 2 1gb modules or 2 2gb modules,upgrade your intel chip and upgrade your bios
May 21, 2015 | Computers & Internet
Have a COMPAQ PRESARIO SR2020nx want to upgrade the memory it have 512mb how high I can go up on the memory
  • Two 240-pin DDR2 DIMM sockets
  • Supports PC 4200 (533 MHz) and PC2 5300 (667 MHz) DDR2 DIMMs
  • Non-ECC memory only, unbuffered
  • Maximum HP/Compaq approved memory is 2 GB
Feb 28, 2013 | Computers & Internet
Dell dimension 4700- added 2gb module in memory slot one, color coded white, and added 2gb module slot 3, also color coded white. only 2 gb recognized by computer, the second module is not recognized. ...
This motherboard uses inter-leaved RAM and RAM needs to be installed in pairs.
Check the BIOS RAM settings.
Try and use the same make of RAM.
One of the RAM modules may be faulty.
Try inserting the RAM module that was in slot 3 to slot 1
Feb 19, 2011 | Dell Dimension™ B110 PC Desktop
Toshiba satellite A100 slot 2 doesn´t work. A
Is memory matched (DDR2 667)
Have you put original mem in slot 2
Download / install CPU-Z with both modules in and run program to see if it shows.
If all above is correct may be damaged mobo.
This is for your laptop from vendors site.
Memory5
• Configured with 512MB DDR2 SDRAM (1 slot occupied and 1 available)
• 512MB(min)/2048MB (max), 2 memory slots using 256MB, 512MB or 1024MB PC4200 DDR2 533MHz SDRAM.
Mar 29, 2010 | Toshiba Satellite A100-S8111TD Notebook
I want to put in 3 x 2gb mem. I have the correct type but when i boot it does not work. i then put 2 x2gb and it works. is this a bios set up problem or something else?
Ram on an ATX motherboard is called "DIMMs", that means it has to be installed in Pairs, you cannot have an empty slot, if you are running windows XP or a 32 bit operating system, then I would put (2) 1 GB sticks in the same colored memory slot and then (2) 512 MB sticks in the other two alike color slots. The memory slots are color coded. If you were only putting in one pair of sticks they have to go in the same colored slots.
Oct 09, 2009 | Foxconn 975X7AB-8EKRS2H Motherboard
I want to run 3 gig ram in my acer aspire 3680
The specifications for your Aspire 3680 only supports a max. 2Gb.
see the details.
System memory1,2
512 MB of DDR2 533 MHz memory, upgradeable to 2 GB using two soDIMM modules (dual-channel support)
Mar 06, 2009 | Acer Aspire 3680 PC Notebook
Asrock K7S41/K7S41GX problem
2 x DDR DIMM slots
- Supports DDR400/333 non-ECC, un-buffered memory
- Max. capacity of system memory: 2GB
3 beeps is usually either video card related, or memory. be sure your memory is UN buffered, and DDR400 or 333 DIMM not DRam.
Remove and re-seat your video card as well.
there should be a troubleshooting guide in your install manual stating the designation of 3 beeps.
Dec 22, 2008 | Asrock P4VM890 Motherboard
HOW TO ADD GRAPHIC CARD TO LAPTOP
it is not usually possible to upgrade the graphics card on a laptop. as the graphics chips are on the motherboard. and they do not usually have a graphics card slot.
some (quite recent) laptops have a graphics express slot which does allow for them to be upgraded.
most often you find that laptop graphics chips share mem with the main RAM (allocated) this is controlled in the BIOS(Setup) and it may be possible to increase the allocation of memory there,
but I'm sorry to say for most laptops there is no upgrade (flexibility is traded for portability)
the 5002WLMI does not appear to have a grpahics express slot, however you may be able to increase the mem allocation in the BIOS (as it does use allocateable shared memory)
Oct 19, 2007 | Acer AOpen MX 400-A (32 MB) Graphic Card
Ram upgrade
memory not compatable or ram port doesn't support 2 gig memory. It's all i can think of.....another thing you can do is....put old mem back...upgrade bios and try new mem again, and then if still not working mail manufacturer for reason. JJ
Sep 15, 2007 | Acer Aspire 3610 Notebook
Systemax Venture S519J (988868) PC Desktop Logo
55 people viewed this question
Top Systemax Computers & Internet Experts
Steve Allison
Steve Allison
pankaj rautela
pankaj rautela
Abhinandan  Patil
Abhinandan Patil
Are you a Systemax Computer and Internet Expert? Answer questions, earn points and help others
