Question about Miele Vacuums
Miele S2511 Vacuum Cleaner Disassemble Question
How do you remove the top cover to get at the cord winder in a Miele S2511 Vacuum Cleaner?
  • Anonymous Mar 13, 2014
    How do you close an Hera Miele vacuum cover lid
My problem is with the power brush...I checked the belt and cleaned the rotating bar..still very low suction. The canister is still giving me plenty of power...thanks for any help
Posted on Sep 21, 2011
Miele S2511 Vacuum Cleaner Manual
Hello, this is Ava with Think Crucial.
You may find the User's Manual for your Miele model by clicking the link below.
Miele 251i Manuals
You can purchase a wide variety of high quality Miele replacement parts for your Miele vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Miele
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Jan 30, 2014 | Miele S251i Plus Bagged Canister Vacuum
My Miele Carina Vacuum stopped working. Does it have a fuse that can be replaced that could be at fault here?
although it might have an internal fuse on this model, I dont think that will be the problem.
The miele cord rewinder has been known to have a small fault in it where the cord winder that actually retracts the cord onto will come apart from the electrical connection in the cord winder itself.
As most of these units have a 5 year warranty anyway, I suggest that you take it to your nearest miele dealer for a repair/replacement on the cord rewinder.
Good luck.
Nov 06, 2010 | Miele Carina Vacuum Vacuum
How do I separate the top of a miele vacuum S 248 i from the bottom so I can replace the cord winder?
A lot of Miele's have similar construction, you might find the instructions here useful: http://www.sannerud.com/house/miele.html
Aug 15, 2010 | Miele S2180TITAN Canister Vacuum System ...
1 ) how do you open the body of the vacum ? 2) How to replace the power cord? Epic 6500 sr
Very Carefully! LOL! Disconnect the hose from the door. Open the door. Remove the bag. Flip the vacuum on its top. You will then need to remove the trim pieces from the sides by sliding them toward the front of the machine(bag opening). Usually they won't want to go easily. The way I used to do it was by wedging a screw driver between the rear cover and the trim piece then gently tapped the side of the screw driver blade toward the front. Once you get enough hanging over you can grab and pull them the rest of the way. The vacuum should separate once the trim has been removed. ****I have to warn you. If you have never done this before it is extremely important to take note of how and where everything goes on an Electrolux. They are complex machines that are assembled in a fairly meticulous way.**** The best way for someone that has not had any training to replace the cord is by replacing the cord winder assembly that comes with a new cord. Otherwise you have to disassemble the cord winder. Not fun.
Dec 28, 2009 | Electrolux Epic 6500 Vacuum
Have a miele S546 vac. and it won't turn on. Is there a fuse? Can the on/off switch burn out? Thanks.
If you vacuum wont turn on it is most likely the cord winder. This is a pretty big repair, you wouldn't want to attempt it yourself. Most shops should be able to repair the cord winder for about $50-75. If you need a new cord winder expect to pay about $150.
Oct 13, 2009 | Miele S548 Bagged Canister Vacuum
Miele s314 red star-motor stopped working-on/off switch broken?
Most likely the problem is with the cord winder. This is the most common problem with Mieles. It is actually the most common problem with any vacuum with a cord winder. A Miele repair center should not change you to look at the vacuum and tell you what is wrong with it. The Red Star was a great model and if the powerhead is still in goood condition I would get the vacuum repaired. If it is the cordwinder they can usually be repaired and it should cost about $75.00. If you need a new cord winder this will cost about $150.00. The top piece can be pryed off, however if it feels like it is switching than it is not jammed.
Oct 08, 2009 | Miele Vacuums
How do i disassemble (i.e. which screws do i pull and which hidden tabs are there) the cord retractor/switch assembly? there is only one screw that appears to hold the piece but it does not come out,...
There are 7 torx head screws to remove in the top plastic housing. 5 are in the perimeter and two are "hidden". One is under the power/cord winder panel which pops off in an upward diredtion. and one is under the cloth filter on top of the motor, inside the bag compartment. Take out those 7 and lift the plastic top panel off !
Sep 26, 2009 | Miele S514 Solaris Bagged Canister Vacuum
Vacuum not running; do I have to replace the cord winder or just cord?
Typically, the cord and winder are supplied as a unit.  It is possible to fit new cord to an existing winder, but the amount of labour involved will make the job more expensive than simply exchanging the complete unit.  Even if you're going to do the job yourself, it's simply not worth planning to just fit new cable (unless you are a masochist with unlimited time and patience).  Pay that bit extra for a complete unit - you'll be glad you did (or you'll be sorry if you don't!).
May 27, 2009 | Miele S514 Solaris Bagged Canister Vacuum
Vacuums Logo
1,228 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
