The left rear burner does not work and it is not the electronic igniter as there is spark there. The burner is not getting gas. All the other burners work fine. The left front burner sparks and doesn't light. From what I have read, it's probably the potentiometer assembly (Bosch-497235) which replaces the origianl part. The part is expensive and it is recommended that a professional install it. I would like to know more details about installation, as to whether a handyman can do it. My product is the RDFS30 with the later SN. Thanks, Michael
Comments:
Apr 28, 2009
- no gas coming out of the venturi. The knob is not cracked, so the valve shaft is turning.
that part is about $150.00 ouch. Take a look on repair clinic .com I am amazed that some of the parts for it are no longer made. Also there is a place in Carol Stream ILL that will refurbish some parts for your unit. Contact CG Industries at (630)588-4030.
Located at: 356 Gundersen Dr., Carol Stream, IL 60188. Let me know if this helped
Our Thermador rdds30vrs oven suddenly stopped working. The whole electrical display is black, no...
(More)
Our Thermador rdds30vrs oven suddenly stopped working. The whole electrical display is black, no oven light, nothing. It is like someone pulled the plug. The circuit breaker is fine and the blower and fan work so power is getting to the unit. Any ideas?
Temperatur display on the control panel became dim, I cannot read it, repair is possible or I need...
(More)
Temperatur display on the control panel became dim, I cannot read it, repair is possible or I need to replace the control panel (almost $300.00 auch)
RDSS30 - Bottom heat element in oven will not heat up. Top element is working so there is electric...
(More)
RDSS30 - Bottom heat element in oven will not heat up. Top element is working so there is electric going to the oven.
oven cleaning does not work because oven door will not lock. Turned the clean cycle on and the door...
(More)
oven cleaning does not work because oven door will not lock. Turned the clean cycle on and the door alarm comes on since the locking mechanism does not trigger. Relay?? Control board?
I'm having trouble with the left hand burners. The left rear one does not spark at all and the left...
(More)
I'm having trouble with the left hand burners. The left rear one does not spark at all and the left front one sparks but does not ignite even though there is gas coming out.
