Question about Intel D945GNT Motherboard
Starup and Shutdown problem
Dear sir/madam, I've got Intel 945Gnt motherboard with Pentium D processor 2.8Gh,2 g b of ram (transcend) initially the problem was there was no display on screen,changed the ram, it starts working but it shutdown automatically while booting up or within 5-10 min after system gets started. can u pleas tell me is there is any problem with any hardware?? thank you.
I checked the system heat within 105 C and above restart issue
Posted on Feb 04, 2008
    Scholar:
  • 113 Answers
I am not familiar with intel.. but i do full repair, design and accrediting on many other platforms: make sure you have either of these specs for your memory: your M-board should have:"Four 240-pin DDR2 SDRAM DIMM sockets. it supports: DDR2 667, DDR2 533, or DDR2 400 MHz DIMMs Support for up to 4 GB of system memory. i suggest that your memory is dammaged or not in correctly: so try these steps. firstly, get another spare mem if avalable (borrow someones :) )and put it into your M-board, if things behave better, your mem is stuffed and needs returning or becoming a paperweight. secondly, make sure in your POST (STARTUP) that your BIOS is the correct version and is ok, by going into your BIOS settings by pressing 'del'. At the bottom of the BIOS screen an option: "SET FAILSAFE DEFULTS" or similar will be there. select this and exit and save! to check your BIOS version look here: http://downloadcenter.intel.com/Filter_Results.aspx?strTypes=all&ProductID=2068&OSFullname=OS+Independent&strOSs=38 ***read the how-to stuff first!!** good luck. but their may be more to your problem, faulty memory/RAM/PCI their could also be a HDD partition errror, boot sector error or PCI/IO error. good luck.
Posted on Sep 30, 2007
Does Intel Pentium 4, 2 GHz Processor support 2GB DDR1 RAM..?
Type of RAM supported has nothing to do with the processor make & type in most cases. It is more important to verify that the motherboard supports this kind of RAM.
In general, most motherboards supporting the Intel Pentium 4 2.0 GHz processor support also DDR1 RAM.
Sep 05, 2011 | Intel (P42000400512SK478) Pentium 4, 2 GHz...
I have a Intel D102GGC2 motherboard with Intel Pentium D 805 processor having core speed of 2.667 GHz. I was using a 1GB of Dynet RAM (DDR2-667 MHz) earlier. Recently, I got a Transcend 2GB DDR2-667 MHz...
specs on that board from Intel is 2 gig max. when you install the 2 gig alone does it show you 2 gig in windows or only 1?......with a 2 gig max I would think that would max each slot at 1 gig...
http://downloadmirror.intel.com/15112/eng/D102GGC2_TechProdSpec.pdf
Jul 04, 2011 | Intel D102GGC2 Motherboard
Sir, In my system motherboard model is D101GGC. my question is can i replace porcessor pentium 4 with the Core 2 Duo
Sorry but you can't. It is not compatible. You can install Pentium D processor instead, if you want to.
For the list of compatible processors for your motherboard, you can check it here:
http://www.intel.com/support/motherboards/desktop/d101ggc/sb/CS-025906.htm
Thanks for using Fixya!
May 31, 2011 | Intel D101GGC Motherboard
I have an Intel 945GNT Motherboard along with a Pentium D processor running at 3.4GHz and 3 sticks of 1GB RAM at 533MHz. I have given it to one of my engineers for repairs and he said that the motherboard...
The D945GNT appears to have been discontinued - however, processors are always made to fit a certain standard socket type. In this case, you will be looking for a motherboard that uses socket LGA775 and has a FSB (Front-Side Bus) speed of 533 Mhz in order to use the same processor and RAM.
These motherboards are still available through the internet, although they are getting older and may be harder to find, but any one of them would work properly. My recommendation would be to read as many reviews as possible before deciding on a certain one.
Motherboards that support 533MHz RAM seem to be harder to find these days, but boards with 800 MHz FSB speeds are pretty common, so you might have to buy new RAM sticks to go along with the new motherboard. The good thing is, RAM isn't all that expensive these days. I would advise checking well-known internet retailers to see if you can find a board that suits you.
Hope this is helpful!
May 10, 2011 | Intel D945GNT Motherboard
Dear Sir, my mother board d101 has been damaged can i use of p4sd m/b insted of that while i want all rest parts remain using i dont want change ram,SMPS, Proccesser etc.
fbhushan, the Intel D101GGC motherboard (Grand Country) supports;
1) Intel Pentium 4, Intel Celeron D, and Intel Pentium D processors that fit in an
> LGA 775 processor socket.
http://en.wikipedia.org/wiki/LGA_775
The Processor has the socket holes, and the processor socket (LGA 775) has the pins.
775 socket holes, and 775 pins.
The Front Side Bus (FSB) can be either 533MegaHertz, or 800MHz.
2) Supports DDR Sdram ram memory at either 333MegaHertz or 400MHz.
(PC2700 and PC3200, respectively)
Will support Up To 2GB of ram memory.
Has two ram memory slots. The maximum amount for EACH slot is 1GB
3) The SMPS used for it has,
A) One 24-pin ATX main power cable
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
B) One 4-pin ATX +12 Volt power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
The Intel D101GGC motherboard has Four SATA headers (Connectors) on it, so I'm going to assume you are using a SATA harddrive.
This would mean the SMPS you are using should have at least one SATA power cable.
It should also have an assortment of 4-pin standard Peripheral power cables.
(Misnomered as 'Molex')
The Asus P4SD (Motherboard chipset Intel 865PE) supports;
1) Intel Pentium 4 and Intel Celeron processors that fit in a > Socket 478 processor socket
http://en.wikipedia.org/wiki/Socket_478
The Processor has the pins, and the processor socket has the socket holes.
478 pins, and 478 socket holes.
Your Processor will NOT work.
The Ram Memory WILL work.
The SMPS MAY work.
I state MAY because the Asus P4SD motherboard uses a 20-pin ATX main power cable.
If the last four pins of the 24-pin ATX main power cable that you have on your SMPS right now, Do Not remove, you can Carefully cut them off. Wrap them up, and out of the way.
If you need guidance on this I can help instruct you.
You need an IDE (PATA) harddrive, or a SATA adapter card to use a SATA harddrive.
So there you have it sir.
Regards,
joecoolvette
Nov 22, 2010 | Intel D101GGC Motherboard
DEAR SIR, I AM USING INTEL 945GNT DESKTOP
shutdown is due to overheating there is a sensor inside every processor to protect it from overheating nd if the temperature goes above this temperature it automatically shutdown.
if you are using a desktop then change your cabinet buy a airy one with extra fan installed in it. or you can open one side of your cabinet to sink the heat quick;y.
Apr 06, 2010 | Intel Computers & Internet
Whether INTEL 810 motherboard supports ddr2 ram of
The intel 810 motherboard will not support DDR2 memory.
Intel Pentium 3 Socket 370 SDRam PC100 Ultra DMA100 Motherboard With Onboard Video / Sound & LAN! For Intel Pentium 3 Processors (CPU.
This board will only support SDRAM PC100
Oct 01, 2009 | Intel Motherboard
Dear Sir i have pentium 4 motherboard 865gbx and i wanted to upgrade the ram. so maxixmum how much ram it will support and wat shd be speed like..333mhz??
IT supports Maximum 2GB DDR400 RAM.
It mainly depends on the Processor speed.I think 1gb RAM is sufficient for Your Pentium 4 configuration. If you use more than 1Gb.there is no remarkable speed difference between them.So better choice is use 1GB RAM.
Jun 24, 2009 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Windows xp crashes frequently after inserting new RAM.
try to use one ram at a time if the 1gb ram does not gve any error thn the 256 mb ram is the culprit and if the opposite happens than 1 gb is culprit yur ram slot also may ve got damaged somehow if the ram is culprit and ti is under warranty get it replced with the same memory clock one
Jan 29, 2009 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Maximum HARDDISK CAPACITY FOR Intel 865GV motherboard
Yes, your board will support 320gb. I am not aware of a limit to how many gigabytes you can have per computer. I currently have 1.5 terabytes. 1500gb.
Apr 22, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Intel D945GNT Motherboard Logo
Top Intel Computers & Internet Experts
Alun Cox
Joe Negus
Joe Negus
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
