Question about Fujitsu Siemens LifeBook T-3010 Notebook
Removing bottom of laptop
I'm trying to remove the bottom of my laptop case. I have removes all the screws that I can see but only 1/2 of the bottom is coming off. I have a Fijutsu Lifebook N3010
  • hellllp Nov 29, 2007
    I need to replace the AC plug....do I need to take off the bottom like this or the top?
    PC is dead,.,,
  • hellllp Dec 31, 2007
    I have same problem - do I need to take the screen off? I have the keyboard off but still can't get the whole thing off in the back - so I can't get to the adpater. HELP please
    Thanks
    Judie
    Novelist:
    Scholar:
  • 167 Answers
It is a difficult task. After removing all the screws, look for the plastic locks on the sides of the top cover. On the one side you got the screws, and the other the plastic locks. Before removing the locks carefully detach the flat cables conecting the boards. Remember, do not break any connection and also make sure your laptop is off. The next thing you should do is to remove the battery. Now carefully slide the bottom cover off laptop.
Posted on Oct 02, 2007
How to remove the bottom of the gatwway lt2016u
Ok, on a laptop you need to get some cups and label them toput the screws in so you will know where they came from. Remove the PowerCord, Remove the Battery then start removing all thescrews from the bottom of the laptop. Then remove all the devices fromthe bottom of the laptop such as the hard drive, the memory, dvd/cd drive,wireless card, etc. Take note of how the wires are on the wireless card,those are the antennas.
Look inside the battery case, hard drive case, memory case and dvd drive slotfor screw. Some screws on the bottom case in inside of some of the devicecases might have the icon of a keyboard next to it. Those screws hold thekeyboard in place.
Turn the laptop over, remove the strip that is just above the keyboard but becareful because a cable might be attached to it. Then remove the screwsthat hold the keyboard in place that are under where the strip was and gentlylift the keyboard out because there is definitely a cable under it.
Next you can remove the screws from the lcd hinges at the corners and lift thelcd screen off, also note that you will have to pull the antennas cable and thelcd cable when you remove the lcd.
Next start removing any screws that hold the palmrest in place. Take note ofany cables that are attached to the palmrest and remove them then lift thepalmrest off.
Next start removing any screws you see that hold the motherboard to the bottomcase, then lift the motherboard out an start replacing the fan.
A digital camera to take pictures will be most helpful to refresh you memory ofwhere things were.
Jun 09, 2012 | Gateway Computers & Internet
How do I disassemble my netbook?
Jun 08, 2012 | Computers & Internet
Can not open my toshiba laptop
Jun 07, 2012 | Toshiba Satellite A100-S8111TD Notebook
Open laptop to change cooling fan
Jun 04, 2012 | HP Compaq Presario CQ61420us Notebook
Remove the cover on an emachine e525
Umm, well there are things like the motherboard and plamrest that have screws in them that might be holding it. You just can't remove the bottom cover, You have to start by Removing the bottom screws like you did, but then you have to remove other things before you can get the bottom case off. Also the VGA Port might have screws on both sides of it that keeps the bottom case from coming off.
Below are some steps to follow.
Look inside the battery case, hard drive case, memory case and dvd drive slot for screw. Some screws on the bottom case in inside of some of the device cases might have the icon of a keyboard next to it. Those screws hold the keyboard in place.
Turn the laptop over, remove the strip that is just above the keyboard but be careful because a cable might be attached to it. Then remove the screws that hold the keyboard in place that are under where the strip was and gently lift the keyboard out because there is definitely a cable under it.
Next you can remove the screws from the lcd hinges at the corners and lift the lcd screen off, also note that you will have to pull the antennas cable and the lcd cable when you remove the lcd.
Next start removing any screws that hold the palmrest in place. Take note of any cables that are attached to the palmrest and remove them then lift the palmrest off.
Next start removing any screws you see that hold the motherboard to the bottom case, then lift the motherboard out an start replacing the fan.
A digital camera to take pictures will be most helpful to refresh you memory of where things were.
May 31, 2012 | Computers & Internet
Cooling fan quite working on nv55c
May 24, 2012 | Gateway Computers & Internet
How to disassembly
May 16, 2012 | Toshiba (M305-S4910) PC Notebook
Disassemble
May 16, 2012 | ASUS M3000Np Notebook
How to Replace the HP Pavilion dv7-4270us Fan
You will have to take the laptop apart to get to the fan.
May 10, 2012 | HP Computers & Internet
Regarding to http://www.fixya.com/support/t9259110-sony_vaio .. how will i remove the case to remove the cooling fan?
Ok, on a laptop you need to get some cups and label them to put the screws in so you will know where they came from. Remove the Power Cord, Remove the Battery then start removing all the screws from the bottom of the laptop. Then remove all the devices from the bottom of the laptop such as the hard drive, the memory, dvd/cd drive, wireless card, etc. Take note of how the wires are on the wireless card, those are the antennas.
May 03, 2012 | Computers & Internet
Fujitsu Siemens LifeBook T-3010 Notebook Logo
361 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
