Question about Abit KN8 Ultra Motherboard
Abit eq software
Getting a reading of 252 degrees C on the PWM...is this an EQ bug or do i have a failing sensor??
Switched to SpeedFan...and PWM sensor now reads a balmy
32 C...i suggest all AbitEQ users switch to SpeedFan...a better
program all together
Posted on Oct 12, 2007
  • 21 Answers
Does it vary? If it changes, it's probably a bug. If it stays static, it could be either. Try installing a different version, ask ABit Support, check the forums, etc.
Posted on Oct 02, 2007
The low frequencies adjustment is not working when i turn the sub frequency on low it lowers the volume of the bass completely
check the rca cables on the back to see if you might have the sub woofer cable in wrong rca spot
this is how it should be wired from your radio front output a set of rca cables go to the radio input of the eq. if you have sub out on radio it will not be used ... eq takes place of it ... turn off subout on radio ... to use eq or preamp you must have at 2 amps 1 for mids and tweets and 1 for subs to work eq right
then from the eq you have another set of rca cables comming from the front output to your mids and tweet amp and then if you dont have a second amp u wont need rear output move over to the suboutput and run a set of rca cables from eq's sub output to sub amp this is how the audio cable section should be connected if you still dont get it to work proper then then it has a electronic issue and need to warranted out if still in warranty or buy new one .... here is a link to the install manual with a wire diagram for repair shop .....http://www.poweracoustik.com/pa2006/manual%20and%20catalog/Processors/PWM-20.pdf
Dec 27, 2010 | Power Acoustik PWM-20 4-Band Car Equalizer
Telescope working principle
This is a reflector style telescope. It may also be on an equatorial mount. If it is on an EQ mount the mount must be polar aligned first in order to properly use the telescope. That's why we never recommend an EQ mount to a beginner.
However you can read my tips on EQ mounts on my profile page. AND-- read these:
http://www.texasastro.org/telescope.php
http://www.texasastro.org/mounts.php
http://www.astronomyboy.com/eq/
Jul 15, 2010 | Galileo (G118DX) Telescope
Im trying to connect a bsr xr eq to my avr687 denon receiver
If you want the EQ to affect the iPod music only, you can hook up the iPod output to the EQ input, then the EQ output to your receiver's AUX input (or DAT input, or whatever you're using to listen to iPod music.
If you want the option of using EQ for other signals as well, then you hook up the EQ to the TAPE inputs/outputs (TAPE OUT goes to EQ input, and EQ output goes to TAPE IN)
If you hook it up this way, then you have to select MONITOR or TAPE MON to get the equalized signal.
Apr 15, 2010 | Denon Audio Players & Recorders
How do I use the Celestron powerseeker 80eq 21048?
If you will go to my profile page I have a TIP and instructions for using an equatorial mount.
This mount must be polar aligned before you can use it. That's why we never recommend an EQ mount for beginners. EQ mounts are very good for astro-photography however the low cost ones are too shaky to use. Normally you need to spend at least $500-$1500 to buy a usable EQ mount that can be used to take pictures of the sky.
Read my EQ Tip on my profile page, and read the link below:
Apr 11, 2010 | Celestron PowerSeeker 80EQ Refractor...
I have a GR-470 EQ. I don't think I'm connecting
The proper sequence to eq just your CD player is, CD out to EQ in, EQ out to receiver in.
Jan 16, 2010 | Pioneer GR-470 Home Equalizer
Equalizer doesn't turn on
hookup the remote wire of your EQ to that of the HU or just simply connect it to the positive line but it would make your EQ powered ON all the time. That remote wire of your EQ is to get a trigger signal from the HU so that it will turn the EQ "on".
Apr 20, 2009 | Power Acoustik PWM-19 4-Band Car Equalizer
How do I connect a Marantz EQ 140 to a Marantz MR235 reciever through tape one (tape monitor) I am not confident that I have it hooked up correctly because I get music when the eq and tape monitor are on...
Dear driver800,
Don't you just love it when when someone who knows less than you do tries to answer your question? Why is it people who know little waste everyone's time with suggestions like "read the book"
On the back of your Marantz MR-235 you will find the RCA phono jacks marked Tape 1 Monitor Output these connect to the jacks labeled input on your EQ 140. The corresponding jacks labeled Tape 1 Monitor Input connect to the jacks labeled output on the EQ 140.
QED
Russ
Jul 28, 2008 | Marantz Audio Players & Recorders
Power Acoustik Equalizer PWM-30
i don't know about the availability of boschman but it's the best.
Jul 04, 2008 | Power Acoustik PWM-30 Car Equalizer
Abit EQ Temperature Monitor
If SpeedFan is showing the correct temp for the same sensor, and that temp varies, then it's an ABit EQ bug. Frankly, I've never been impressed with the latest round of Windows software that ABit/Asus/etc. have been bundling with their motherboards. I suspect they're outsourcing the development, and the programmers are better at "pretty graphics" UI's than solid functionality.
Sep 30, 2007 | Abit KN8 Ultra Motherboard
Equalizer hook up.
only hook up to tape monitor or else u wont get an audio signal . .....also hook all equipment to amplifier not eq ...it goes tape cd tuner and any type of external equipment to amp.then find tape 2 it sould be called tape moniter and have a separet botten for u to select it goes record to eq and play from eq
Aug 27, 2007 | Spectrum Technical Hifi EQ-B5100...
Abit KN8 Ultra Motherboard Logo
71 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
David
David
Rommel Balcita
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
