Question about Abit KN8 Ultra Motherboard
Abit EQ Temperature Monitor
Im getting a reading one the monitor software Abit EQ that my PWM is at 252 degrees C , this cant be right....is anybody else having problems like this with abit EQ utility?? SpeedFan shows normal temps.
  • 21 Answers
If SpeedFan is showing the correct temp for the same sensor, and that temp varies, then it's an ABit EQ bug. Frankly, I've never been impressed with the latest round of Windows software that ABit/Asus/etc. have been bundling with their motherboards. I suspect they're outsourcing the development, and the programmers are better at "pretty graphics" UI's than solid functionality.
Posted on Oct 02, 2007
6ya staff
SOURCE:
How to repair dead abit nf-m2pv
please remove the mother board cell and few minutes rest and reinstall cell and solve the problem
Apr 17, 2012 | Abit Computers & Internet
Abit IT7-max2 no video
Check RAM first, Then if that is good the problem is most likely the motherboard, A windows pc will boot and display without graphics specific drivers installed, but only if the motherboard is working. If the ram is good and you can give more info, Does the monitor display the BIOS post screen and booting. ( The name of the mobo and the physical drives in the machine.)
Jan 26, 2012 | Abit Computers & Internet
My pc is not showing anything on screen whereas everything is running inside cpu
http://www.nvidia.com/Download/index.aspx?lang=en-us
http://www.abit.com.tw/page/en/download/download_driver.php?pFUN_KEY=9000&pTITLE_IMG=/download/images/download.gif
Thefirst link is Nvdia"s link for driver downloads. The second is Abit's. In nvdia's link I put in you info but you will have to enter what driver(software) and your operating system. Keep in mind that you wil have to uninstall ant prior software related to this board before installing new.
Will the system start in safe mode? If so go to "device manager" through "control panel' and click on box next to "dispaly adaptors" your Nvdia driver should show in the drop down. Right click on that and you should see "enable" or "disable" if you see enable, click n that and you should be set
If you have made any recent changes, ie; cables to monitor, you may ahve to hook system back upthe way it was and do a "system restore back to when it did work.
Mar 18, 2011 | Abit IN9 32X-MAX Motherboard
Abit V17 motherboard no monitor output??????
try vsing another video card, or check in the bios if it will post and see if the onboard video is disabled. if it won't post you either have a bad or mismatched(processor to motherboard) motherboard, processor or video card.
Jul 17, 2009 | Computers & Internet
Abit IS7-E2 monitor wont display anything
is this a brand new motherboard?
do you have onboard graphics or a card?
without testing i couldnt say for sure but it sounds like you are not getting power to your graphics on motherboard.
this is usally a common issue for asus motherboards. not easy to fix.
if your motherboard is new i suggest a replacement from the seller.
Feb 24, 2009 | Abit IS7-E2 Motherboard
Abit Kg7-Lite motherboard USB2 pin Locations desperately needed!
Lay case down with the bottom in front of you. Looking straight down at the row nearest the case bottom reading right to left there will be two rows of four pins.
Reading right to left the row closets to the case bottom the first lead is vcc1, next usb1-, next usb1+ and grnd1.
Top row reading right to left is vcc2, next usb2-, next usb2+ and grnd2.
I just replaced bad caps on my kg7 and had to remove the motherboard for the repair so I just reinstalled my front case usb ports.
Help this helps.
anon paranoid
Feb 18, 2009 | Abit KG7-Lite Motherboard
Best video card
Any video card that is AGP 8X not over and the more ram it has the better 256mb or if you can 512mb
Please post rating
Aug 16, 2008 | Abit KV7-V Motherboard
Connect a vga card on a used a17 mobo
Hi Rafae183, yes, you're board, Abit Al7/Al7-G supports AGP8x/4x speeds & voltage of 0.8v/1.5volts only.
Below is the Abit link for you're board. Listed on the right of the page is product Inf. & support Inf. Suggest you add this to you're favorites.
http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?pMODEL_NAME=AI7&fMTYPE=Socket%20478&pPRODINFO=Specifications
Suggested any one of these AGP8x speed video cards.
http://www.tigerdirect.com/applications/category/category_slc.asp?CatId=318&
Remember to check for voltage. You're video card must run at 1.5volts only. Warranty's are important too.
Have more questions, feel free to ask.
Best of luck to you!
Mike
How to vote you're expert.
Enter FixYa.com site.
Sign in to your FixYa account.
Locate My Profile on our FixYa's homepage.
Under My Problem locate your problem and click on it.
Under the solution given by the expert, choose.
Apr 12, 2008 | Abit A17 Guru Motherboard
Abit eq software
Does it vary? If it changes, it's probably a bug. If it stays static, it could be either. Try installing a different version, ask ABit Support, check the forums, etc.
Sep 30, 2007 | Abit KN8 Ultra Motherboard
Open Questions:
MAGICJACK SuPpOrT PhONe Number @[+1-845*481.1722]#OO#-%+-' 24X7 MAGICJACK Tech Support Number +1-845-481-I722 to resolve all MAGICJACK products. End Your MAGICJACK Membership You can end your Prime membership by clicking the End Membership button on this page. Paid members who haven't used their benefits are eligible for a full refund of the current membership period. [1``845`-481`-I722``] UsA MAGICJACK Technical SuPpOrT Number +1-845-481-I722 to resolve all MAGICJACK products. MAGICJACK is an American multinational company which was founded by Michael MAGICJACK using its company headquarters in Round Rock, United States of America.Contact MAGICJACK for Setup & Installation MAGICJACK Setup Support & Installation MAGICJACK Helpline number Connect is a utility carrier that lets in you to print and scan from anywhere. Facebook is an internet social media and networking website and with Facebook, you'll be able to share something like permitting registered users to create profiles, upload photos and videos, send messages and keep in contact with friends, family, and colleagues. To find out new things and knowledge completely different places beauty we tend to arrange our tour at reasonable costs. Then you'll watch United Airlines, here all of your needs are fulfilled at a minimum rate. Alaska Airlines could be a major USA airline headquartered in SeaTac, Washington, inside the urban center metropolitan space of the state of Washington. it's the fifth largest airline within the u. s. once measured by fleet size, scheduled passengers carried, and variety of destinations served. Walmart is committed to providing you superior customer service and a nice searching expertise. We're happy to retort to your questions about Walmart com connected queries. The best Walmart phone number with a tools for skipping the wait on hold. The customer can Call Walmart com customer service faster by CSPN. Contact Customer Service team to provide a comment or ask a question according to your problems. This is Amazon's best phone number, the real-time current wait on hold and tools for skipping right through those phone lines to get right to a Amazon agent. This phone number is Amazon's Best Phone Number because 1,820,712 customers like you used this contact information over the last 18 months and gave us feedback. Common problems addressed by the customer care unit that answers calls to +1-845-481-I722 include Return an Order, Missing Delivery, Refund an Order, Dispute a Charge, Can't Login and other customer service issues. The Amazon call center that you call into has employees from Arizona, Washington, North Carolina, India and is open 24 hours, 7 days according to customers. In total, Amazon has 1 phone number. It's not always clear what is the best way to talk to Amazon representatives, so we started compiling this information built from suggestions from the customer community. Please keep sharing your experiences so we can continue to improve this free resource.
Oct 22, 2019 | Facebook Computers & Internet
See all Abit KN8 Ultra Motherboard Questions
Abit KN8 Ultra Motherboard Logo
1,346 people viewed this question
Top Abit Computers & Internet Experts
Alun Cox
Ekse
Bart Fonteyne
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
