Question about Epson Aculaser C1100 Printer
Error 537 I have got an epson aculaser CX11F colour. i tried to print on a transparency paper but did not work well. insted i have this error coming up everytime i turn printer on. can anyone help me? Raf
  • 1 more comment
  • rhl007 Oct 01, 2007
    the error relates to Fuse Error, i do not know if to change the fuser or it maybe something else.
  • rhl007 Oct 10, 2007
    well i thank you all for taking the time and look at my issue. The problem is that i just get possible causes to my problem. Yes, the paper got jamed in the fuser and i did removed it. I need someone to tell me how to fixt it or the solution.
  • Anonymous Jan 19, 2009
    service req 537
  • Epson Master
  • 691 Answers
E537 Indicates A Fuser fail for one of the following reasons:
• Control Thermistor detected a temperature exceeding the specified temperature. Safety Thermistor detected a temperature exceeding the specified temperature.
• The Control Thermistor did not detect a Ready even though the specified time elapsed from Main Lamp ON at Warm Up.
• The Main Lamp continues to stay lit even after time specified for the Main Lamp elapsed after the Control Thermistor detected a Ready.
• The Control Thermistor detected a temperature below the specified temperature even after the specified time elapsed from Main Lamp ON at Warm Up.
• The latch lever of FUSER ASSY is set incorrectly.
With the exception of the last entry all the above mean the fuser is dead and needs to be replaced. It is an easy job that involves 3 screws and a connector.
Posted on Oct 13, 2007
  • 64 Answers
When you tried printing onto transparancy did any get jammed in the machine? a common problem is that the transparancy film carls around the fuser roller and melts its self to it. this will result in your error as the thermistor will not be able to get an accurate reading of the fusers temperature an average fuser will reach around 180 c and obviously plastic doesnt like heat much either. Hope this helps Cops Pete@wedotoners.com
Posted on Oct 10, 2007
    Scholar:
  • 113 Answers
I think that is a memory related error: http://support.epson.ru/products/manuals/000836/alcx11_ug_en.pdf good luck:
Posted on Sep 30, 2007
Hi when I print out in colour on the epson aculaser c1100, I get a smudge of yellowish pale colour on the right handside of the paper how do we fix this problem
Click here for the manuel. It will walk you through cleaning the cartriges. In most cases using the built in self-clean will take care of the smudge. You can also try removing the cartige and cleaning it and the housing with a damp q-tip or cotton swab.
Jun 07, 2011 | Epson Aculaser C1100 Printer
Keeps saying paper jamed when I try to print
On the Epson website it is confirmed that the Epson WorkForce 610 will not recognize transparency media. It is just the way the printer works; if it can see through the media, it doesn't think it's there.
However.....you can tape a sheet of white paper to the non-printable side of the transparency, and it prints just fine. I put two strips of scotch tape on either side, top and bottom. Works great. It's kind of a hassle, but better than not being able to print transparencies at all!
Jul 22, 2010 | Epson Workforce 610 All-In-One InkJet...
Epson ACULASER CX11NF paper Jam error every time I print
you may wanna check if the paper that your using is a laser paper, check the mp tray, reload the paper and check the settings on your computer using thicker needs to match the setting on your driver you may also wanna check if your printer can do a stand alone copy so that we can identify if this a hardware issue or a driver issue.
hope this will help u
May 10, 2010 | Epson ACULASER CX11NF All-In-One Printer
Hullo I have a c900 aculaser, printing fine and now on all colour images, there is no image just block of colour and a series of broken repetitive lines. Help! Christine Willis tel 01803 866577
Unplug your printer power cable, restart your computer and plug the printer cable back and on it and tryt to print. this may help. thank. let me know if it works
Jul 02, 2009 | Epson AcuLaser C900 Printer
Epson aculaser c1900 error code e014
Error code 014 indicates that the cooling fan on the power supply board is not operating when the printer is switched on. Does n't explain the poor print quality though. I suspect it is a worn 2nd BTR roller (the black foam coloured roller inside the rear door). To check this send a coloured print through and press hard against the rear door during printing. If the print quality improves then it is a worn roller, if it doesn't let us know and we'll try something else.
Please take a moment to rate this solution. Thanks.
Mar 10, 2009 | Epson AcuLaser C1900 Printer
Epson aculaser c9100 error code Eo86
After a repair person came and worked on the Epson Aculaser CX11NF, I have vertical line, full lenght across every printed page
Oct 08, 2008 | Epson AcuLaser C1900 Printer
Epson aculaser cx11nf MP E paper jam
open the mp tray
locate 2 white plastic egg shaped piece on the ends of the steel rod
gently push one or the other towards the back of the machine
if the paper jam error message is on then the roller will turn as soon as you give it a push
re load the paper
open and close door a or e
printing should resume
that white piece works with the paper lift to get the paper up to the in feed roller
Sep 01, 2008 | Epson ACULASER CX11NF All-In-One Printer
Color transparencies are dark & poor color
Nice printer.. Hope this will give hints. Considering transparency papers, please try another batch of or a piece of transparency paper. Try to adjust also the graphics preferences (dark to light) aside from transparency paper selection. Have a nice day.
Best regards,
Rosener Guyano
Feb 17, 2008 | Epson ACULASER CX11NF All-In-One Printer
Epson Aculaser C1100 Printer Logo
507 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
