It doesnt load anything from the hard drive or from the disc? Do you hear the disc spinning? Are your cables properly connected and do you have the television set to the proper tv input? Usually if its the hard drive it will or should reformat itself especially if connected to the internet via wireless or the cat5 cable. Many of the early xbox 360's used to heat up really bad and you would get the red ring of death. There is a fix for that overheat issue though.
SOURCE: xbox 360 open tray error
sounds like the whole assembly is off track or ruined. here is a great site that you can use to order the complete assembly and replace this malfunctioning one. Click here.
SOURCE: My 360 dose not read discs but it dose spin them
Disc Error :- I have the same error. You can do 4 things.
A)
You have to keep turning it on and off. Here's how... Turn it on, then
click open tray then close tray ( keep opening and closing tray about
10 times) then turn the console off. Then keep repeating process for
about 15-20 minutes and eventually the game disc will show up. ( I have
to do this every time)
B) Make sure that this is covered by
Microsof't's RROD warranty. Then some how get teh red rings on this
console and send it to Microsoft. (Note: I am not held responsible for
your actions.)
C) This is a lens problem. So go out to a store
and buy a DVD lens cleanser. It's a disc that cleans the lenses of the
DVD or the XBOX.
D) Open it up and replace the lens (like the above guy said) (much harder and more costly).
Pls rate my solution if it did help thanks.
SOURCE: 360 wont load games just goes to 360 screen
This means that your console was not updated with the latest firmware to read Wave 4 games. To update your console, you have to join and sign in to Xbox Live and the system wuill automatically acquire an update to enable wave 4 games to run. Hope this helps.
