Question about Samsung SC-D353 Mini DV Digital Camcorder
Formatting When turned on it says "Not Formatted", When I try to format nothing happens. The memory stick is unlocked and has worked fine untill now. Any ideas?
  • Anonymous Apr 22, 2009
    I have the same problem, the camera seems to hang when I try to format it, but my laptop reads the card just fine when I pop it into the built in card reader. I've been able to copy files to and from the card with no problems. Just the camcorder says "Not formatted" and wont complete a format. I have the same issue with both of my cards.
  • 73 Answers
SOUNDS LIKE A ERROR IN MEMORY STICK .. TRY A NEW STICK THIS SHOULD FIX YOUR PROBLEM
Posted on Mar 02, 2008
SOURCE:
What is a Sony camera c:13:01 memory card error?
The manual says: The inserted "Memory Stick Duo" media cannot be used in your camera. (page95) in my manual.
There it is saying that certain sticks do have encryption technology like MagicGate. Or the camera is not compatible with the high speed parallel data transfer and some more reasons.
But if your stick worked fine before in the same camera something else must be wrong. If it was used before in the camera, please try to format it in an external card holder connected to your computer, before putting it back in the camera. Pleas also check is all contacts are clean and nothing is in the cardholder. Sometimes just a little but of dust or a tiny paper can ruin good working connections. Do the checking and cleaning first, before formatting, because from a formatted stick you can't get pictures that supposed to be there.
Nov 29, 2013 | Cameras
Camera says out of memory won't let me take pictures. i cleared all the pictures out and still cant take pictures. What do you think the problem is?
I'm assuming you are trying to use an SD card in your camera and not the internal memory. I suggest you format the memory card if you are sure there is nothing on the card. Formatting the memory card deletes everything on the card and sets it up with a file system that your camera recognizes. Follow these steps to format your memory card using your camera. 1. Turn camera off 2. Insert memory card 3. Turn camera on 4. When the memory card is inserted in the camera, the [Format card] option appears in the setup menu 5. Choose Format to format the entire card. Don't choose Quick Format 6. Wait until your card is formatted
After formatting your memory card, try turning your camera off and on and you should now be able to take pictures to your memory card.
P.S. If you remove your memory card you can choose Format Memory from the setup menu to format the camera's built-in internal memory
Sep 01, 2011 | Nikon COOLPIX L5 Digital Camera
Says error on formatting memory card.
The camera may display a FORMAT ERROR if the inserted media is not formatted or if the media was formatted on a computer. This error may also display if the inserted media is not supported by the camera.
Try to remove and re-insert the Memory Stick media several times.
Make sure that the inserted Memory Stick media is compatible with the camera. DSCW310 Camera is compatible with the Memory Stick Pro Duo upto 32 GB.
You may also try formatting the Memory Stick media to resolve the issue. Format the Memory Stick media using the FORMAT option in the camera menu.
Formatting will erase all stored data, images, movies, etc., from the Memory Stick media. FORMAT option is available in the Memory Card Tool Menu of the Camera which is in the Settings Menu. Please back up the data by inserting the Memory Stick in the Computer Memory Card slot.
This may also happen if the terminals on the Memory Stick media are dirty. Remove the Memory Stick media from the camera and use a soft dry cloth or pencil eraser to clean the contacts. Make sure there are no residual particles on the Memory Stick media before re-inserting it into the camera.
The data on the Memory Stick media or the Memory Stick media itself is damaged. Try using a different Memory Stick media in the camera.
This should resolve the issue. If the error continues to display, the media may need to be replaced or the camera may require service.
Jan 23, 2011 | Sony Cybershot DSCW310 Digital Camera
I have format error on my cybershot camera. I need to access photoc on camera
The Camera may display the FORMAT Error if the inserted media is not formatted or if the media was formatted on a computer. This error may also display if the inserted media is not supported by the Camera. The maximum supported capacity and media used is Memory Stick Pro Duo with 1 or 2 GB.
If you've already captured the images in the Camera and the error message displays, then try to open different images captured in the Camera and check if the message appears for all the images.
If this happens with all the images, then remove and reinsert the MS (Memory Stick) in the Camera and check if it works. You may also try cleaning the MS terminals and also check if the Internal Memory of the Camera displays the error. If the issue persists, then insert the MS in the Computer slot and transfer all the images to the Computer. If the images appear normally in the Computer, then Format the media in the Camera. To Format the Memory Stick, select the Format option in the Memory Stick Tool Menu of the Camera. (Menu-->Setup-->Memory Stick Tool-->Format)
Formatting the MS will delete all the files saved.
Formatting the MS should resolve the issue.
Thanks for using FixYa.
Jan 18, 2011 | Sony Cyber-shot DSC-S700 Digital Camera
I have a polaroid dvf-720 brand new and trying to record and 2mins and it says memory full? i dont understand,and i have a memory card that says card error,need help or im in trouble with the wife!
Ok so I have the same problem I went out and purchased an SD card...but it doesnt work. So I called Polaroid and you need to purchase a CLASS 6 SD card of 2gb or more for it to work properly...figures it does not say that in the manual.
Dec 25, 2010 | Polaroid Cameras
My camera says that there is a card read error and to insert a memory card why does this happen when i have a memory card in it?
This may happen if the Memory Stick is formatted in the Computer.
You may try formatting the Memory Stick in the Camera itself by using the FORMAT option in it.
If the issue persists even after formatting the Memory Stick in the Camera, then check whether a different Memory Stick works in the Camera.
If the other one works in your Camera then it must be the issue with the previous Memory Stick.
If the Camera does not work with a new Memory Stick, then you may try initializing it to check whether it resolves the issue.
Initialize option can be found in Menu items in the Camera.
If that does not resolve the issue, you may try removing the battery of the Camera for atleast one minute.
Jul 21, 2010 | Sony Cyber-Shot DSC-S40 Digital Camera
Kodak easyshare c613: memory card says its full when there is no pix on it, what happens is: i turn it on, says "memory card full", i go to review, says "no pictures or videos to display on memory card",...
If you connected the camera to the computer with a USB cord to download your pics and then just yanked out the cord without using the "safely remove hardware" icon at the bottom right corner of your screen, the card may have been corrupted. Replace it.
Nov 10, 2009 | Kodak EasyShare C613 Digital Camera
Problem with corrupted files
Dont panic... Just insert the memory stick in to a card reader and donot try to open it. but make sure that your memory stick gets detected.Then you can use any of the file recovery softwares to recover the photographs with out formating.I generally use the free app "PC file recovery". In case your memory stick is not detected in the first place, then There is no other option other than formatting. But the recovery software can recover 90% of the photos even after formatting.
If this doesnt work, post back. I will explain in more detail.
Nov 09, 2008 | Sony 2GB Memory Stick PRO Duo Memory Card
Phone wants to format the M2
You have to clear the card it sounds like,it may be full.Formatting will erase it.It may be a bad memory card.
Jun 10, 2008 | Sony Ericsson K800i Cellular Phone
Sony Cybershot DSC S650 Memory stick not formatting
Well I have the same camera.
And mine won't turn on.
Suggestion dont trust this camera.
Or maybe it just can't hold that much memory.
Mar 15, 2008 | Sony Cybershot S650 Digital Camera
Samsung SC-D353 Mini DV Digital Camcorder Logo
165 people viewed this question
Top Samsung Video Cameras Experts
Marvin
Marvin
302lab
Level 1 Expert
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
