SOURCE: parts
Best bet is to call and request availability and pricing info as wellas
how to purchase. The following link is a request form with an 800#at
the bottom you can call...
www.euro-pro.com/euro-pro/feedback.aspx
SOURCE: Old model Bernina 830, running ok, then kept
There is a thing called a suppressor which is normally located in the foot control which has fused, you need to open the foot control and you should see a a small thing that looks liuke a fuse connected to the two terminals which you need to take out and discard because you don't need it any more, if you don't have on in the control then it will be on the motor which means you will have to take it in for repair.
SOURCE: I have a Kenmore sewing
Buy a new foot pedal for it, probably one of the electrical components inside the foot has failed.
There are Kenmore footcontrols for sale on www.sewingpartsonline.com. You could email them to check its right for your model if it isn't listed.
Obviously I'm assuming that you are in USA with 110 Voltage and that is what your machine is. If not and your country is 220V, you would need to source it from a reseller in your own country or another with the same voltage.
SOURCE: Run away foot pedal.
I had this problem with my Janome and also after I was given a new foot pedal as well, even though no fault could be found with it. I then suspected power surges as my computer went haywire at the same time on one occasion. I have never yet had the problem since I started to use surge sockets. I have only ever had the problem with my computerised machine, not my other although the foot pedals are the same.
SOURCE: foot pedal dead, machine keeps sewing!
Sounds like your foot control is faulty.
I can supply foot controls for 99% of sewing machines.
Mike
[email protected]
http://www.sewingmachineswales.com
Pfaff 2144--I see that i can buy a new cord to attach the pedal to the machine, but the foot press doesn't easily come apart after i unscrew the screws. Is there a secret way to open it up so i can replace the cord?
