Question about Lexmark X8350 Print, Scan, Copy and Fax All-in-One Multifunction Printer Plus Photo w/USB Printer ...
Default printer factory settings Lexmark X8350
Wish to change Lexmark X8350 factory default printing setting to one of my choosing.
  • Anonymous Mar 20, 2014
    Can I set up x8350 as wireless
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 77 Answers
Please follow the steps given below:
1. Press "Fax Mode" button.
2. Press "Menu" button.
3. Use the "Down Arrow" till the display reads "Maintenance."
4. Press "Select."
5. Use the "Down Arrow" buttons till the display reads "Reset Defaults."
6. Press key pad "1."
7. Press "Select."
Please let us know the results.
This will restore to factory default
Posted on Sep 08, 2010
SOURCE:
Lexmark 3600-4600 stops at 34% when trying to print a test page. Color ink is low, but I only want black in any event.
If your color ink is already empty or not substantial for printing, then you must replace it with a new cartridge. The Lexmark printer will continue to print when there's substantial ink in the cartridges.
If you prefer to print in black and white as your default print setting, please follow the steps below: (make sure your black and color cartridges ink levels are good)
For Windows OS:
1. Go to Control Panel.
2. Open Printers and Faxes.
3. Right-click on Lexmark 3600-4600 Series print object and click on Properties.
4. In the Lexmark 3600-4600 Series Properties window, go to Advanced tab. Click on Printing Defaults.
5. In the Lexmark 3600-4600 Series Printing Preferences window, under Ink Use, select Print using black ink only. Click OK.
6. Click OK button in the Lexmark 3600-4600 Series Properties window to save the changes.
Your printer will print in black and white draft mode the next time you send a print job to the printer.
For Mac OS:
1. With the file (you wish to print) open, go to Print. A window will pop up.
2. Select the Lexmark printer.
3. Expand the arrow pointing down beside printer name if you're not able to see other options for printing. Look for Quality and Media.
4. Under Paper tab, select Print in Black and White.
5. Save this as your default print setting. Click Presets option and choose Save as. You can personalize the name for this default print setting (e.g. Black and White Draft or My Setting).
Select this Preset name every time you print your files/documents.
Aug 31, 2011 | Lexmark X4690 Wireless InkJet Printer
I cannot send or receive faxes. The Transmission Error report says phone line error. I don't know how to set up the fax software; cannot find my Lexmark x8350 manual. Thank you.
4. Press "Select."
7. Press "Select."
Jun 20, 2010 | Lexmark X8350 InkJet Printer
Cannot change/ save two default settings on X6570 Lexmark printer
you can go to printers and faxes (XP) or printers (vista) in control panel Right click on the printer and click on properties. Go to advanced tab and click on printing defaults. It will pop up the printer printing preferences. choose the desired setting. To disable 2-sided printing, go to advanced tab in the preferences window and turn off the feature. Click ok to save all settings. Go back to general tab and click on printing preferences and set desired settings if there is a need. Click ok to save settings. Then, for all changes to take effect, click ok button on the lexmark 6500 series properties window. Try to print again. Hope this helps.
Feb 17, 2010 | Lexmark X6570 InkJet Printer
Change default ptr setting for lexmark x8350
4. Press "Select."
7. Press "Select."
Apr 27, 2009 | Lexmark X8350 Print, Scan, Copy and Fax...
Printer instalation
Good day.
Usually that happened once the printer was not set to default setting after it was installed.
To set to default, click start, choose printers and faxes, select the lexmak pinter, click file select default printer.
To test your printer if it print.
1. right click the printer icon
2. select properties
3. click print test page
Thanks.
Nov 01, 2008 | Lexmark X6570 InkJet Printer
I have a Lexmark X8350 printer. The factory settings are for full color and High quality printing. For every day stuff I would like to save some expensive ink and use the Quick Print and printing color...
This can differ b/n manufacturer and models, but basically what you have to do is get in to the printer properties window. Go to File>Print. In the box that pops up, make sure your printer is selected and click the "properties" window. THere is usually a tab that says "Printing Preferences", but like I said, this can vary. Just go thru all tabs and if you are looking to print in black, look for an entry that says "Print in grey scale" or "Economy Print". That should resolve your issue. Be sure to click OK in the box when you're done :O)
Oct 22, 2008 | Lexmark Office Equipment & Supplies
Default status
SET YOUR PRINTER AS DEFAULT PRINTER
GO TO START - CONROL PANEL- PRINTER AND FAXES.
CHOOSE YOUR PRINTER RIGHT CLICK IT SET DEFAULT PRINTER .
THEN OK
U CAN GET PRINT
Apr 01, 2008 | Lexmark X1150 All-In-One InkJet Printer
Lexmark X8350 Print, Scan, Copy and Fax All-in-One Multifunction Printer Plus Photo w/USB Printer ... Logo
377 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Ekse
Thomas F. Schneider
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
