Question about Sony STR-DE915
Sony STR-K660P Intermittent sound problem
The receiver display window flashes "PCM 48" when trying to play a DVD in my Pioneer DV-525 player. I get great video playback with intermittent sound every 2-3 seconds?? Any suggestions would be appreciated.
  • John Bartlet May 14, 2012
    i'm having the same problem but with my STRDH820 and this is literally the only place on the internet that mentions anything like it!
  • Anonymous Mar 14, 2014
    Sync sony str-k660p to comcast remote
    New Friend:
When i turn on my STR-K660P nothing shows but the little lights that are on the 4 buttons on the top right of the face plate. Please Help Me!
Posted on Sep 12, 2011
Xdfcbzdf
Posted on Mar 13, 2008
SOURCE:
Pcm 48 khz
mine does the same thing. I found a pdf of the manual and it said this in the troubleshooting section:
""PCM--kHz" appears on the display. , The sampling frequency is more than 48 kHz. Change the DVD setting to 48 kHz."
I have my seiki tv hooked into the dvd/ld input through a coaxial cable, and I don't think my tv has a setting to change the sampling frequency. so I have no idea what to do. any help would be great!
Jan 15, 2014 | Sony STR-DE445 Receiver
Tip
Pioneer region free code DV-340, DV-343, DV-444, DV-545
Introduction
The Px4x DVD Upgrade is an advanced modification to your DVD player, which adds extra features and enables you to get more from your machine. The upgrade supplements the DVD player and in no way harms the playback quality or removes any performance features of the DVD player.
Main Features
The DVD Upgrade adds the following features to your DVD player:
 Multiregion capability
 Macrovision disable
Players Supported
The following DVD players are supported by this version of the DVD Upgrade:
 Pioneer DV-340, Pioneer DV-343
 Pioneer DV-444
 Pioneer DV-545
Modification Details
Multiregion selection
Nearly all DVD discs on the market today are encoded with a specific "region" in mind and are made in such a way that a disc designed for "region 1" will not play on a player designed for "region 2". This is so that the Hollywood studios can control the release of titles in different geographical regions all over the world. Our upgrade allows you to select between regions 1 to 6.
Macrovision & CGMS disable
All DVD players have a system called Macrovision built in to the player, which is designed to stop the copying of DVD discs to video. However, this system can have adverse affects on some projectors. For this reason the DVD Upgrade disables Macrovision to solve any problems.
Operating Instructions
You can select the region code by remote. This region will be tried first when playing a disk.
Due to this design, the modification will work on the RCE (Regional Code Enhancement) protected DVD’s. In some cases it will be necessary to insert a conventional (non RCE protected) disc before playing a RCE protected disc. Follow the instructions as detailed bellow:
1. Turn the player on without a disc in it
2. On the remote control, press 'SETUP'
3. Use right arrow to select 'General'
4. Use down arrow to select 'Basic'
5. Press 'ENTER' on the remote control
6. Press 'Display' on the remote control
You should see the region code and OSD version that the player is set to
7. Press 'Condition/Memory'
8. Press '1', '2', '3', '4', '5' or '6' to change the region code of the player
The text will disappear
9. Press ' Display ' on the remote to control the region
10. Press 'SETUP' on the remote to exit. Play the disc
This dident work for me but mayby work for you.
on Mar 06, 2010 | Televison & Video
Pioneer receiver vsx 820 no sound display flashes digital
Friend, try to press the receiver button on the remote, and right after that press '0' (also speakers)... i had the same problem, thats how I fixed it.
Feb 11, 2012 | Pioneer Audio Players & Recorders
How can I make my Pioneer DV-525 Region Free?
Unfortunately you can't make it 'region free' but you can change the region as follows:
* power up the player without a disc init.
* press setup on the remote control,an osd will appear on the tv.
* select GENERAL using right cursor and use down cursor to select BASIC,press ENTER.
*press DISPLAY, the current region will be displayed.
*press CONDITION/MEMORY followed by 1,2,3,4,5,6 dependent upon the required region.
* press SETUP.
* your player is now ready for use
Feb 19, 2011 | Pioneer DV-525
HDMI Video/Audio cut after 10min playback
if its overheating you might have to replace the reciever
May 08, 2010 | Yamaha RX-V661 Receiver
No sound from new Pioneer DVD player
try resetting defaults
Place DVD player in standby mode
Push in the stop button on the hardware unit and keep pushed in
Push in Standby button on the remote provide while doing the above
Then put into standby mode again insert your DVD and see if it changes.
All Happiness
Apr 08, 2010 | Pioneer DV-333 DVD Player
Samsung wont play entire divx movie
If you are talking about the fact that this player zooms picture when playing divx and does not allow manual correction, my solution was to go out and buy a pioneer player today (DV-220VK). It's strange as the samsung plays normal dvd format fine but they have obviously got the divx playback wrong. So far the pioneer has been great!
Feb 14, 2010 | Samsung DVD-1080P9 DVD Player
I cannot get sound from a sony BDS350 (Blue ray
This must be configuration problem on the BD player. In this case receiver just outputs the signal it receives digitally. If it displayes PCM 2ch, that means it receives only 2 channel audio from BD player.
You can try to configure the BD player not to decode audio and to output the RAW stream over coax cable to the receiver. Then the receiver should get raw Dolby Digital encoded data and be able to decode it into 5.1 channels. It should also display Dolby D instead of PCM in such case.
Feb 11, 2010 | Sony Audio Players & Recorders
I have the code pcm 48 showing up on the display and dont no what it means or how to fix help please
PCM 48 means pulse code modulation at 48kHz. Your receiver is decoding digital information and displaying what format it is, and it's frequency. That is normal.
Dec 25, 2009 | Sony STR-DG810
UNLOCK CODES
*press CONIDITION/MEMORY followed by 1,2,3,4,5,6 dependent upon the required region.
* press SETUP.
And thats it.
Sep 07, 2008 | Pioneer DV-525
530 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
