Question about Maytag Atlantis MAV6451 Top Load Washer
Won't spin My Maytag Atlantis MAV-35(not the 6451 as indicated) is agitating during the spin cycle, and not spinning at all. This happens in all cycles. I have replaced the timer with no effect. The lid switch works fine and the water drains. I have since pulled the motor to remove a stripped nut, and now it won't do anything at all. Please help.
  • 3 more comments
  • lemelin Sep 30, 2007
    I made a mistake with the model #. It's actually MAV-8551.
  • dbulloch Nov 19, 2007
    My washer will agitate but was not spinning fuu speed on the spin cycle. it also will not drain. When I restared the cycle while empty, it began to smell like the belt was burning. Any help would be greatly appriciated...
  • Anonymous Jan 27, 2008
    The MAV-35 washer fills water properly but fails to go into spin cycle. The manual says there is a lid switch which turns off for safety. Where is the lid switch?
  • angmp3 Mar 29, 2008
    i bought my maytag atlantis mav8551aww july 2005.
    For the past year my washer would occasionally make strange noises while washing, like loud clicking or grinding, but it would go away and then yesterday my washer was unbalanced from a heavy sweatshirt i was trying to wash and so i took the sweatshirt out. i went to do a new load and noticed the it wasnt spinning anymore after any of the rinse cyles, it agitates and doesnt spin. i tried this several times with just water in it. a couple times if it was full of water the tup would slowlllyyy spin while agitating as well, until the water drained out, once the water was gone, there would be no spinning action at all and it would be just agitating.
    i called maytag and they said if the problem is from the transmisson or the drive motor that it would be covered under the 3 to 10 year warrenty...
    otherwise i would have to pay for anything else that may be wrong..
    what should i do? did you figure out what was causing the problem with your washer? thanks, angie
  • Anonymous Aug 03, 2008
    hi my atlantis does the same thing does not spin but ajitates thru the intire cycle. whats wrong? thanks paul
Sounds to me, your belt is slipping. The motor tensions the belt with springs. The motor slides in grooves to keep the belt tensioned. These grooves get gooked up with dust, dirt, rust, slime, etc. Move the motor back and forth a few time to clean the grooves. Also spray some lubricant on it to help clean it and make it slide freely. Be sure both sides slide back and forth in their groove. After doing this, your belt should stay tensioned enough not to slip during the spin cycle. No tools needed and even the average moron could do it. Hope this helped.
Posted on Feb 23, 2008
My maytag will spinn*then stop&will not wash .
Posted on Jan 04, 2008
I had the same problem when the machine ran went into spin but did not. Get the Thrust Bearing Kit - Includes the Pulley, Bearing, Plastic Gear. Make sure you mark the pulley, gear and shaft when removing the older pullet, bearing and plastic gear. It is very important to keep the machine correctly timed. The kit is cheap $35, flip the machine on its back and remove the plastic cup in the center and then the c-clip and remove in order after marking everything with a black marker (line all up the same way) Good Luck
Posted on Nov 29, 2007
Mav7600aww maytag spinning but not agitating
RDU Appliance Repair 919 827 1482 Serving Raleigh Cary Durham NC
mav7600aww has a brake that goes bad. some will just spin slowly during agitate cycle and not really agitate
Sep 07, 2013 | Maytag Atlantis MAV6000 Top Load Washer
Maytag mav-1 doent spin
What does it do when it gets to the spin cycle?
Nov 29, 2012 | Maytag Atlantis MAV6451 Top Load Washer
Hi, I have a Maytag Alantis Washer (model: MAV
Does it not spin just in the final cycle or not at all during the wash cycle? Also, does the wash cycle agitate normal?
Regards,Richard
Nov 07, 2011 | Maytag Washing Machines
My Maytag washer agitates, and will pump during the spin cycle but will not spin
Check the lid switch is operating. It will not spin for safety reasons if it thinks the door is open.
If the switch is good test for power at the wigwag (spin) solenoid when in spin cycle. Since it agitates the solenoid itself could be bad.
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Aug 02, 2009 | Maytag Atlantis MAV6000 Top Load Washer
High pitched buzz/whine during wash cycle only, spin fine
1) Make sure valve is open all the way 2) some machines have a screen inside of the hose hook up which could be clogged. 3) last check to see if it is the hot or cold by switch your selector switch on your machine to hot then cold. If one of these positions eliminate the noise then the valve in the machine is bad.
May 16, 2009 | Maytag Atlantis MAV8000
Maytag Mav-1 Slow Spin
hi thanks for the question with any washer if you use a hi sud zing detergent it really slows down the spin cycle check this just fill & drain 2or 3 times use some veniger try this thanks the appliance doc
Jul 17, 2008 | Maytag Atlantis MAV6451 Top Load Washer
My maytag atlantis mav6200 only spins on whites cycle
Try running the machine in another cycle the very next time you use it. I'm trying to determine if this is machine fault something else.
If you just used the machine wait for about 1/2 hour before starting it again.
Jan 14, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Loud noise during spin cycle
this is my experience repairing the maytag washer Atlantis mav series 9750 aww, I had to replace the spin bearing since it was making a jet engine noise when it was spinning out the water. its not an easy job for my 1st time taking this machine apart, you literally take it all apart to get to this bearing, but now I can show how to do it with pictures making it easier for you to do it. even if you have to replace something other than the spin bearing, this how to tutorial will show you how to get to most of the parts in this machine
tutorial located here tutorial located here https://sites.google.com/site/maytagwasherrepair/maytag-washer-repair
Jan 02, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MAV6451 Top Load Washer Logo
351 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
