Question about JVC RX-6018V Receiver
JVC receiver I was trying to add speakers to my jvc receiver and accidently turned the speaker volume to +21 and now there is no speaker sound, and don't know how to turn it back down. I also would like to know how to add more speakers to my receiver, have no instruction manual.
  • 93 Answers
Did you check impedance value and wattage on speakers you want to add to receiver?
Posted on Oct 03, 2007
There is no sound coming out of my jvc k series tv. it worked like 10 minutes ago. what went wrong?
Look in audio menu or setup menu to make sure the speakers did not get switched off----check set or a box if used for same or volume turned all the way down---speakers being switched off is the most common cause or the audio circuit has failed.
Apr 15, 2012 | JVC AV-A21M3U 21" TV
I have a JVC RX 554v Receiver when it's turned on I have no sound their is a mute auto light that's lit in the window....Tried changing the speaker wires with no results...
From the remote control only: Press MUTING to turn off the sound through all speakers and headphones connected. "MUTE" appears on the display and the volume turns off. To restore the sound, press MUTING again. Turning MASTER VOLUME or pressing VOLUME +/- also restores the sound.
Sep 01, 2011 | JVC RX-554V Receiver
I have a fisher ca-9335 integrated stereo amplifier thats hooked up to sanyo tp 1010 turn table and plays out of yamaha ns-70t speakers. a simple jvc cd player is also hooked up to the speakers but not to...
Something doesn't add up. You mention two connections to the speakers - CA-9335 and a "simple jvc cd player". Is that true? If so, you might want to UNconnect the CD from the speakers and run it into the receiver where it belongs. An amp isn't designed to share the load with another live device; or even have electrical contact with anything BUT speakers.
Did you actually find documentation that supports this hook-up? Or just winging it?
Feb 20, 2011 | Audio Players & Recorders
On my jvc 517v when you turn the volume up the speakers are crackeling and scratchie and speakers sound terrible.
Is this a NEW problem or has it always been like this? What modes or sources are affected? Generally, crackling, scratchty sound is either overdrive distortion, speakers being pushed too hard, or blown speakers.
What is the exact model. Can't find the manual for "517v".
Feb 09, 2010 | JVC Audio Players & Recorders
My car speakers cut out when i turn my volume to loud what could the problem be i have stock speakers in a 02 chevy truck and a brand new jvc radio
Hello soccer_fr704,
Sounds like the JVC is overdriving the speakers. Most OEM speakers are just not designed to handle more than 12-15 watts RMS and the JVC is rated at 22 watts.
About the only solutions are to keep the volume really low or replace the speakers with ones that can handle the power from an aftermarket receiver. New speakers will make that JVC sound better, too.
Hope this helps.
Jul 09, 2009 | JVC Car Audio & Video
Volume on jvc home stereo receiver cuts off at a certain level
I had the same problem and found that when I moved the speakers apart further...It works as well as it always did before my 8 speakers were introduced..I think the sound was interfering with itself.. Try it !!
Jan 18, 2009 | Audio Players & Recorders
Little or no sound JVC RX6010V
i had the same problem but i went to adjust settings and it says right speaker left speaker and you have to set them on ten
Jan 02, 2008 | JVC RX-6010V Receiver
My jvc rx-6010v is OVERLOADING?
The very FIRST thing to check is to make certain ALL of your speakers have an IMPEDENCE of 8 OHMS. (JVC - and others - say SIX ohms, but 8 is the "standard" you should use.) Virtually all speakers of even modest quality will include this specification on a label on the back of the speaker. You CANNOT run more than (2) TWO speakers with 4 OHMs impedence on ANY amplifier (technical discussion too long!) [NOTE: The internal overload protection system you mention is designed to help prevent permanent damage. However, you cannot re-set these systems yourself. Your dealer or authorized JVC service center must do this. Note, though, that if you have attempted to "cheat" the system several times, damage CAN be done that requires servicing.] But, before you take the unit in for service, there is one more "test": check for shorted and/or mis-connected/disconnected speaker cables/wires. Visually inspect connections at the receiver and speakers first. You might find something obvious! If everything looks okay, then disconnect ALL of the speakers; and reconnect and test them one at a time (at relatively low volume.) For example, reconnect the left front speaker, test the system; THEN add the right front, test the system,and so on, ADDING one more speaker each time - FIRST MAKING SURE EACH OF THEM HAS AN IMPEDENCE OF AT LEAST 8 OHMS! IF there is a short (or bad speaker) this will help isolate it. Hopefully one of these "fixes" will work for you. GOOD LUCK!
Jul 10, 2007 | JVC RX-6010V Receiver
JVC RX6040 OVERLOAD TROUBLE
clean your volume control if that does not help take it to a tech for repairs.
Mar 29, 2007 | JVC RX-6040 Receiver
Audio noise on cold start
hi pick up the volume just a bit and so for the speakers and see if it continues to happen if soo try by putting all settings as normal( not your normal the tv's normal...speakers and volume without the reciver) if soothen the problem is in the tv's AMP which was mute all those years hope it works good luck
Mar 19, 2006 | JVC AV-32750 32" TV
JVC RX-6018V Receiver Logo
273 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
