Question about Microsoft Office Outlook 2003 for PC
Msnlive messenger i cant sign into msn live messenger it comes up with error code 8004888d
    Scholar:
  • 113 Answers
Ok, concentrate!!! and please switch restore "on" and create a backup date before doing this. just encase! The log file contains "Error 0x80092026: The cryptographic operation failed due to a local security option setting.", error. This occurs due to local security setting, to resolve the issue check for "safer" key in registry and delete it. Locate the following key Start/Run Typr "regedit" ENTER HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\ SystemCertificates\TrustedPublisher Under "TrustedPublisher" look for "Safer" key. Delete the "Safer" key if it is there. and bingo! later.
Posted on Sep 30, 2007
SOURCE:
Signing in to windows Live Messanger failed because the service is temporarily unavailable Error Code:8007007e
If your desktop live messenger is not working, you can use web MSN messenger. For example KarooLark web MSN messenger: http://karoolark.com/#msn
Jun 29, 2011 | Microsoft Windows Live Messanger
Problem with MSN Messenger
well they were hit with denial of service recently so try again later as it suggested. We cant log you in from here anyway.
Thanks for using FIXYA please rate our help++++ Thanks
Oct 09, 2009 | Microsoft MSN Messenger Connect Service
Cant sign in to wlm
If you can't sign in to MSN Messenger, the connection settings in MSN Messenger might be preventing you from connecting to the Microsoft® .NET Passport or Microsoft® .NET Messenger Service. The MSN Messenger Connection Troubleshooter can often find and fix these problems. The Connection Troubleshooter starts automatically if MSN Messenger encounters a connection problem. If you choose not to use the Connection Troubleshooter, or it does not solve your connection problem, try the following:
1. Click the Tools menu, and then click Options.
2. In the left pane, click Connection.
3. Under Connection Settings, click Test Connection.
If you agree to allow the Connection Troubleshooter to examine your system, it will test for connection problems and report steps you can take to correct them.
4. Optional: Perform advanced troubleshooting
To troubleshoot your specific type of connection, click Advanced Settings. On the Advanced Connection Options dialog box, check that the settings for your particular connection type are correct. To test your connection, click the Test button. Click OK, and then click OK.
5. Click OK.
When you choose these settings, MSN Messenger will use the Microsoft® Internet Explorer connection settings if possible.
6. Try signing in to MSN Messenger again.
Hope I helped MSN expert Dr Reed
Sep 16, 2009 | Microsoft Windows Live Messanger
Error code 8007007e
  1. Start > run > sfc /scannow
  2. Insert windows xp cd
  3. Restart computer
  4. You can skip step 1-3 but its strongly advised you do it.
  5. Uninstall msn messenger with ZapMessenger you can download it from:
http://www.softpedia.com/progDownload/ZapMessenger-Download-115115.html
6. Download and install Windows Installer Cleanup you can download it from:
http://support.microsoft.com/kb/290301/en-us
7. Run the utility, select all items concerning Windows Live, delete the following:
- Windows Live Call
- Windows Live Communication Platform
- Windows Live Essentials
- Windows Live Messenger
- Windows Live Sign-in Assistant
- Windows Live Upload Tool
8. Then restart computer
9. Download msn messenger again. You can download it from
http://download.live.com/?sku=messenger
10. Once installed Restart computer
11. Run msn messenger
12. Enjoy with J
Jul 29, 2009 | Microsoft Windows Live Messanger
Error code 8e5e03fe
uninstall msn messenger to begin with and download and install once again.
If this still happens reset your router, the router may of changed itself to strict so just reset :)
May 24, 2009 | Microsoft Windows XP Home Edition for PC
Error code in windows live messenger 14.0
Try to clear the cache
C:/users/%USERNAME%/contacts/%YOUREMAIL%
C:/users/%USERNAME%/appdata/local/Microsoft/Messenger/%YOUREMAIL%
Delete these two folders and then restart Windows Live Messenger.
May 06, 2009 | Microsoft Windows Live Messanger
MSN Live is not Responding, I sign in to MSN Messenger Live and it doesn't respond. What can I do to fix this problem with MSN Messenger Live?
HEY guys!!
i had da same problem i went to google and i didnt find any way so i start finding it my way ..IF msn is not responding after 3 seconds when you signin...And if you did system restore dat what had happened to me ... i ve the answer... Go to Control panel> firewall>exception> .... IF YOU VE MORE DAN TWO WINDOWS LIVE MESSENGER CHECKED..here is da mistake ...just uncheck one and signin and see..IF its again not workin check the other one.. CAUTION: leave da msn (phone) NO NEED ........I HOPE MY ANSWER IS HELP FULL
Nov 10, 2008 | Microsoft Windows Live Messanger
Msn messenger error code 81000306
Windows Live Messenger error code 81000306 Problem description When you start Windows Live Messenger you cannot sign in, and you get error code 81000306 along with the message:
We were unable to sign you in to Windows Live Messenger, possibly because of a problem with the service or with your Internet connection. Please make sure that you are connected to the internet.
Error code: 81000306
Oct 18, 2008 | Computers & Internet
Cannot sign in and Error Code 81000306
Here is a good link to information about that issue:
http://messenger-support.spaces.live.com/Blog/cns!8B3F39C76A8B853F!13932.entry
Jul 18, 2008 | Acer Aspire 5050-3242 Notebook
Microsoft Office Outlook 2003 for PC Logo
77 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
