I have a 1998 Ford Explorer XLT 5.0 V8. With the a/c knob on, the compressor does not engage. I've checked the fuses and they're all good. Should I just replace the relay since I do not know how to check it? Would the improper amount of freon prevent the compressor from engaging?
Low pressure in the system and the clutch will not engage. The low pressure sensor is on it for a reason.
Check refrigrant level i have found that if the pressure is low the compressor will not engage. usually means that you have a leak. if yopu regharge the system and after a day you lose cool air you probabnly have a really bad leak mech time
TY for the advise. I've filled the a/c with apprx 12-15 oz (40-45 psi) of R134A. While in the process, the compressor turned on and off continously. What does this mean?
i've put two cans in,fixed the mixing door but the compressor wont come on.
