Question about Symantec Norton AntiVirus 2004 - (Open Box) for PC
Virus once a space is deleted..next while seeing the space of the same folder/file it shows the recent memory used
  • 82 Answers
Its a boot sector virus pls use effective antivirus if your present antivirus does not work the install new another antivirus
Posted on Oct 10, 2007
SOURCE:
My tablet keeps giving me error message. Insuficcant space on tablet to download apps
This means the internal memory is full and the only way to add apps is to uninstall other apps that you have installed. Check to see if you have apps you no longer use and uninstall them.
Jan 02, 2017 | Tablets & eReaders
It gives error that your hard drive have 1mb free space
1. Go in control panel Add or remove programs or programs and features then uninstall the programs that you don't use or havn't used in a long time.
2. Go in control panel Folder options view tab at the top. Look for Hidden files and folders put a tic in show hidden files and folders.
Go in My Computer/Computer Click on the c drive then windows folder delete the update folders that have a $ infront of the name of the folders. Go back to Folder Options/View tab at the top. Hidden files and folders put a tic in Do not show hidden files and folders.
3. Right click on Rec bin choose empty rec bin.
4. Go in control panel / Internet Options clcik on settings next to the first delete button from the top then click on view files. On the upper roght clcik on edit/Organize choose select all. Then hit your delete key on your folder yes to conferm. Click on ok then in the next window click on delete button next the settings button you clicked on before.
5. Open notepad type del %temp% /q then save the file to your desktop name it Del.bat cloce everything out and double click the del file on your desktop.
6. Open the run command Hold the windows key down (left of the space bar on your keyboard) Press the r key. Type in %temp% Delete all the files and folders you can in that folder.
7. Right click on Rec bin choose empty rec bin.
If it still says low disk space I suggest saving your personal files and reinstall your oem system disk or add a second disk drive.
Terry
Apr 03, 2014 | Computers & Internet
Good morning, I have a 16gb memory stick, having deleted all files it still show as 11gb used and only 5gb remaining, can you offer any advice. many thanks simon
I think it could be due to virus activity. Some virus make the contents of the drive hidden, thats why user can't see the files and the space available for use is less than the capacity.
It is suggested that go to FOLDER OPTIONS - and seclect SHOW HIDDEN FILES. It may show the hidden files. Otherwise, if you dont have any vital data on the drive, just format it. Hope this would fix the issue and you would be able to enjoy the full capacity of the disk
Let me know if any further clarification is required. Hope this helps! Dont forget to rate the solution!!
CreativeTECH
Jan 13, 2011 | Verbatim STORE-N-GO (95312) 8 GB Hard...
How to make computer faster
1. Clear the temp files in the temp folder,recent files.
  • Click on Start and then Run.
  • In the text box in the Run window, type %Temp% and click OK. A folder full of files and other folders will appear.
  • All of the folders and files you see in this Temp folder are no longer being used by Windows XP and can safely be deleted.
2. Scan your machine with good anti virus every week with the updated definitions
3. Remove unwanted programs installed in the machine, as it uses unwanted memory.
Oct 12, 2010 | Computers & Internet
My sansa clip has maxed out space and won't turn on
Sandisk has an Answers support site for the Sandisk players.
Searching for answers on the item space, links to next page:
http://kb.sandisk.com/app/answers/list/kw/space/r_id/101834/search
The first answer on not enough space for musicDB will give 2 options for deleting files, see next page:
http://kb.sandisk.com/app/answers/detail/a_id/848
Option 1 for normally erasing files.
Deleting selected files:
http://kb.sandisk.com/app/answers/detail/a_id/41
Method 1: deleting files on the player itself .
Method 2: deleting files when connected to a computer
when using method 2, switching USB mode from MTP to MSC or vice versa may be needed to see the files in the folders.
Information about the problem "hidden files", see:
http://kb.sandisk.com/app/answers/detail/a_id/447
How to change the USB mode of the player, see:
http://kb.sandisk.com/app/answers/detail/a_id/207
Option 2, erasing all files on purpose or when memory is corrupted .
Formatting the device, deleting all files:
http://kb.sandisk.com/app/answers/detail/a_id/107
This help page shows how to perform a format of the player using
disk management. The player has to be in MSC mode when performing
this action.
How to switch to MSC mode is mentioned before, see link:
Manual for the Sansa Clip in pdf format:
http://mp3support.sandisk.com/sansa/UserManual/CLIP/CLIP_UM_English.pdf
When more help is needed, just post a comment.
Nov 20, 2009 | SanDisk Sansa e250 MP3 Player
Deleting files does not free up disk space
Note that "deleted" items move from their location into the "Recycle Bin".
So, "empty" the Recycle Bin, in order to reclaim the space.
Or, when deleting:
1. click ONCE to select a file/folder to be deleted
2. hold the SHIFT key down
3. click the DELETE key
4. release the SHIFT key
This will "permanently" delete the file/folder, immediately freeing-up the disk-space.
Oct 27, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
What is desktop.ini is it a virus?
Since Desktop.ini is a Windows system file, you are probably seeing it because you have set Explorer to display hidden/system files. By reversing this setting, you can get rid of Desktop.ini.
  1. In any Windows Explorer window, click Tools → Folder Options…
  2. Click on the View tab.
  3. Check off the radio button next to “Do not show hidden files and folders”.
  4. Put a check in the box next to “Hide protected operating system files (recommended)”.
  5. Click OK.
Aug 25, 2009 | HP Pavilion dv4-1140go Laptop
I can't delete files from my Maxtor 3200 external hard drive
The other comments are not the easiest way to free up space on the drive. The reason you aren't seeing a change in free space is because of a drive error (probably unplugged without unmounting). So First open up disk utilities and fix the hard drive (should only take 1-2 min). After the drive is fixed select erase free space (zero out data is fine for now). This usually takes about 20 min for me with a 120 gig hard drive. This allows you to have the free space without having to move all of those files around (which for me would be a problem because I have 100 gigs used on my drive, which would take forever).
Jun 20, 2009 | Maxtor Personal Storage 3200 (U01E200) 200...
Downloaded Frostwire to a memory stick, can't delete folder.
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
2. Format
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Apr 19, 2009 | PNY 2GB microSD Memory Card
Pendrive
this a definitely virus problem, do check with the updated virus cleaner or some other virus cleaner application.
Dec 31, 2008 | Microsoft Windows XP Professional With...
Open Questions:
Symantec Norton AntiVirus 2004 - (Open Box) for PC Logo
51 people viewed this question
Top Symantec Computers & Internet Experts
Peter Dragonetti
Are you a Symantec Computer and Internet Expert? Answer questions, earn points and help others
