Question about HP LaserJet 4L Printer
Paper LED blinking
Hi, At the very beginning, my HP Laserjet 4L got jam and after clearing jammed paper. It works for 5 to 6 printouts and finally the Paper LED blinking all the time. I'm sure it didn't has any paper left inside. I've disassembled the roller, control PCB & Main PCB.. and still blinking while fixed it back. At this moment I didn't connet to PC. Please advise. Thanks a lot. CK Lai
  • Anonymous Dec 15, 2007
    I have the same problem precisely. Any one got any ideas?
  • Tarekegn Alemu
    Tarekegn Alemu Dec 25, 2007
    all four led are light during printing process and stay this four led light upto last
  • HP Master
  • 1,113 Answers
Try feeding using bypass, probally worn/dirty/broke paper cassette paper feed roller having trouble feeding the paper in.
Posted on Dec 18, 2007
SOURCE:
Hp laserjet 1005 printer second page paper jam
Hi senthil, my name is Lisa and I would be happy to help you with your Laserjet 1005. I understand you are experiencing a paper jam when printing multiple page documents.
There are multiple variations of the 1005, below I will list 3 links one for each of the 1005 Laserjet printers I think you could have.
Clearing Paper Jam for HP LaserJet P1005 P1006 P1007 P1008 and P1009...
http://h20565.www2.hp.com/hpsc/doc/public/display?sp4ts.oid=1839458&docId=emr_na-c00765431&docLocale=en_US < HP LaserJet M1005 MFP - Clearing jams
http://h20564.www2.hp.com/hpsc/doc/public/display?docId=bpl10965 < HP LaserJet 1000 Product Family - Clearing Printer Media Jams
I hope that one of these links is specific to your printer, and that the appropriate link helps you resolve the issue.
Best of luck. I work on behalf of HP.
Jul 02, 2015 | HP Office Equipment & Supplies
Paper got stuck in my HP Laserjet 4L. I didn't pull the paper out straight but finally got all of the paper out. However, now each sheet of paper gets stuck like the first when I try to print. Does anyone...
Remove the tonner and reinstall it, check the papers parth with a torch as the tiny bit of paper will cause a jam. Check for obstructions.
damnor01
Apr 17, 2011 | HP LaserJet 4L Printer
HP laserjet 4L paper jam after printing one page.
You need the pick up rollers replaced. Call your service centre to replace pick rollers as these are feeding the pages crocked
Aug 31, 2009 | HP LaserJet 4L Printer
HP 4L printer indicates no paper when the tray has
When you removed the paper jam, was the paper torn? If so, did you ensure that you found all the pieces. (Put the piece of paper back together like a puzzle to verify). There could be a piece of paper stuck in the printer that is causing the paper sensor to fail.
The other possibility is that when you removed the paper jam, something became dislodged in the printer. Forcefully removing paper from the printer can cause this.
Jul 16, 2009 | HP LaserJet 4L Printer
Grinding Sound - Orange Paper Jam Light
You have a broken gear main motor. I had the same problem, bought $5 part and after the replacement of the gear,it runs like new
Dec 04, 2008 | HP LaserJet 4L Printer
Paper jam
Remove the toner, and try to gently pull out the paper jam.. If the page gets torn, or ripped, make sure you have all the pieces of the paper removed. Then re-start the printer. Print a test page to make sure the paper path is clear..
Nov 21, 2008 | HP LaserJet 4L Printer
Paper out jam in hp laserjet 1020
Please visit this below mentioned link to troubleshoot your printer problem.
HP LaserJet 1020 Series Printers - Clearing Paper Jams
Thank You
Oct 20, 2008 | HP LaserJet 1020 Printer
Printer problem
hi,,
i think your printer has a jam paper, try to locate the jam and clear it so that your printer will work properly...
Aug 26, 2008 | HP LaserJet 1018 Printer
Paper jam blinking
Try and push the blue button after clearing the jam.
Dec 08, 2007 | HP LaserJet 4L Printer
HP LaserJet 4L Printer Logo
186 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
