Ovens Logo
Michael Young Posted on Oct 27, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
PLES389ECH F30 ERR code. Oven and stove top is locked out after trying to run self clean. The fan is still running. I have turned breaker off and back on after waiting a day and range is still locked out. How do I unlock so I can at least use the range top?
billconfused
Level 2:
Champion:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 211 Answers
  • Posted on Oct 28, 2013
billconfused
Expert
Level 2:
Champion:
Cheetah:
Answers
211
Questions
Helped
59565
Points
377
This should help, good info includes links! http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/76555-error-code-f30.html
2 Related Answers
Anonymous
  • Posted on May 04, 2009
SOURCE: Self-Clean oven fan will not turnoff and the door still locked
Have you tried to unpulg it and see if it unlocks
Anonymous
  • 8 Answers
  • Posted on Aug 12, 2010
SOURCE: frigidaire professional stove, Oven does not work,
Is the clock set?
In mine - the clock has to be set - or it won't work;
GE wall oven JK3800SHSS. Started clicking loudly during last 5 mins of Self-Clean. Ongoing clicking and running fan. How do I diagnose/fix this?
what was the error code?you should never self clean your oven before any big holidays,for reasons like this, if it takes out a part the part most likely will have to be ordered and the last day they take orders at my parts store is monday before thanksgiving so if it's your clock and you have to order it you might not have it for thanksgiving so hopefully you just have a bad latch assy. and you can get it fixed before the holiday,from what i've seen i will never self clean my oven,i use easy off and scrub it,the oven gets up to 1000 degrees and it damages the electronics in the oven.the clicking you hear could be the latch assy. unplug the oven.open the door and see if the hook part that locks into the door isn't jammed,i just went out tuesday to change a latch assy and that part was jammed,the rod that goes from the motor and to the door latch was hitting the metal part of the latch that bolts to the frame and i couldn't move the hook part or catch at all and the motor was clicking trying to move it,i had to lift the top of the stove,bend the body of the catch assy. so the rod could move freely and that fixed it.but using the self clean short lives the oven and it can damage the latch or the clock assy.send the error or just goggle it and it will tell you what it is.
Nov 13, 2017 • GE Ovens
1helpful
2answers
Oven door will not open after self clean
There are two easy things to try to fix this.
First, unplug the oven, or turn off the circuit breaker to it - so long as power is cut to the oven. Leave it for about 5 minutes, then plug it back in or turn the circuit breaker back on and try to open the door.
If that doesn't work, turn on the self-cleaning cycle again, and let it run for about 15 minutes. Then turn it off and wait another 15 minutes, and see if the door will open.
If neither of those work, you have a more serious problem with the locking mechanism. Either a bad solenoid or a damaged heat locking mechanism. Both of these will require removing the stove top to access and repair. Let me know if the above suggestions fix the problem. If they don't, I will get you more specifics on repairing the locking mechanism - assuming you're up for that.
-Dyllan
Mar 06, 2008 • Ovens
I have a frigidaire gallery wall oven (2003). We set the self cleaning and then canceled. The door is now locked and the fan is running. I tried to reset breaker and it is still locked. How can I get the...
If tripping and turning the circuit breaker off for about 10 minutes does not work, contact Frigidaire. Sounds like the control board and/or door switch will need replacing.
Kenmore Elite c970-418091 wont work after self clean - Code f30
Here is a how it works post I{ wrote a little while back.:The oven temperature is regulated by a temperature sensor when placed in self clean the sensor is removed from the circuit and full power is applied to both the bake and broil elements causing an the temperature to exceed in some some models up to 1,000 F. I would recommend against using self clean for the simple fact that no oven cavity to this date has been designed to withstand that high of a temperature and therefore excess heat is passed upward resulting in damaged lock mechanisms, control boards, and other electronic components. With all that said you can try to cycle the controls by turning the breaker of the oven off for a few minutes the n turn it back on. It should then read PF which is normal. Press the cancel button and try it to see if it works. If not then you will need to replace the control board in the upper panel
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
My Oven is displaying a f30 ERR message and won't allow me to use my oven,,,the stove works fine....what do i do?
I have same problem, displaying a f30 err message and does not work oven rest is working. I have changed sensor still does not work.
Frigidaire professional stove, Oven does not work, can't bake, self clean. get an ERR F30 code.
Is the clock set?
1helpful
F90 code flashing and i cant reset it
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question@#$%
112helpful
14answers
Kenmore Elite slide in range F30 error
I had the same F30 error problem but fixed it. On my professional series Frigidaire, there are 2 resettable red button locations. I discovered that only one is in the rear of the oven. After going to the breaker box and shutting off the power, pull out the stove enough to work, unscrew the rear screws (I didn't unscrew all of them, just enough to work back there). The small red button is on a small black round piece with two purple wires feeding to it. That was not my problem. Mine was the other red button behind the control panel. Pull off all 4 knobs, unscrew by hand the large black rings that are underneath the knobs, pull out the whole panel. Look back and right (below where the right knobs were located) to find the 2nd red small button. Push to reset. Check this one first since it is easier to do.
Dec 27, 2007 • Ovens
Top Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you an Oven Expert? Answer questions, earn points and help others
