Question about Dell A960 All-In-One InkJet Printer
Dell A960 AOI Printer problem
After a good deal of successful printing the black ink ran the color ink was also low and I replaced both cartridges. The alignment print was a top broad black band under which came a row of 17 vertical bars, \\\\\\\\\ (blue) and 35 vertical bars. I have a 4-page document typed using Word Perfect XP it was the one on which the ink ran out. When I try to print it now the pop-up "printer preparing" appears but printing does not start. Bill Bebbington
My printer is only feeding to the right. Is there any thing I can do to fix it myself?
Posted on Dec 19, 2007
  • 33 Answers
Have you reset the ink levels for your printer? Some printer software refers to it as that others ask if you have installed a new cartridge.
Do maintenance on the printer, such as clean heads, print test page, head alingment, etc and see if that fixes it. You can get to all these options through properties
Posted on Oct 17, 2007
  • Simon
    Simon Oct 17, 2007
    If maintenance on the printer does not help, check on the dell website or contact dell and see if they have a solution.
SOURCE:
Can Dell A960 ink cartridges be refilled and re-used or not?
A lot of inkjet printer manufacturers make you purchase their ink cartridges by installing a chip in the cartridges so when the cartridge is empty it cannot be reused by filling the cartridge.
Jan 28, 2013 | Dell A960 All-In-One InkJet Printer
Missing black ink cartridge
Unplug the printer from the wall. Also remove the power brick for 60 seconds. This will reset any error messages you get from the printer. Plug everything back in and power on the printer. Take out the Dell black cartridge and reseat it. Put it back in and do the same for the color cartridge. When you close the printer it should try to print an alignment page.
Aug 11, 2009 | Dell A960 All-In-One InkJet Printer
I have a dell printer A960 I refilled color cartridge and have not used it for about 2 months and now it only prints in red what can I do
The print heads on your ink cartridges have dried up. Ink printers need to print in black and white and color once a week. Doing this will extend the usable life of your cartridge because the ink will not dry on the print head and clog it. You can try and get the ink flowing yourself by resting the print head on a warm moist paper towel until you see ink on the towel (ink stains most surfaces so be careful where you do this). To check your progress, press the print head into a dry paper towel. You should see three entire distinct colors for the color cartridge and one black line for the black cartridge. If you can't get it flowing again you will need to buy new cartridges. You can get Dell refills from Cartridge World if you would like to save some money.
May 11, 2009 | Dell 946 All-In-One InkJet Printer
Dell A940 and A960 printers will not print in black ink, just purchased ink cartridges from Office Max, have deleted all info from computer of previous A940 and A960 printers, reinstalled program via disc....
I had the exact same problem with a replacement black cartridge directly from DELL. I called support, and they just had me clean the cartridge manually by swiping the print strip, then running the standard cleaning commands in the computer. I had to do that a couple times, but eventually the black ink started working again. VERY ODD. I hated dealing with it, but these steps worked to fix it eventually. Hope that helps.
Dec 15, 2008 | Office Equipment & Supplies
Printer Always Indicates Ink is Low or Cartridge is Incorrect
To get rid of the low ink warnings google the specific error message with 'ink refill' and look for 'engineers reset' or similar ..
NB. Dell printers (re-badged Lexmarks) are notorious for ink usage and high costs .. so my best recommendation would be to throw it away and purchase something else ..
Nov 30, 2008 | Dell 922 All-In-One InkJet Printer
Cartridge Error 50 C in manual A 960 No l
One solution is to replace cartridge snap-down levers  (the levers that snap down inside the dell printer to hold the cartridges, blue for color and black for black). This seemed to have work for several people with the same issue.
Nov 25, 2008 | Dell A960 All-In-One InkJet Printer
A960 All in One Printer not working with color cartridge
My new black ink cartridge wasn't working at all. I sprayed the cartridge with windex and let soak for a minute. I wiped dry with paper towel and there was black ink on my towel unlike before. The windex unclogged it and it worked like new!
Oct 17, 2008 | Dell A960 All-In-One InkJet Printer
Black ink not recognized
Select printer, properties.
Select printing preferences, select advanced.
Select more options.
Make sure you do NOT have Use color cartridge for all black printing selected.
(I had set that a while ago when my black cartidge ran out when the kids had a paper due - I forgot I had reset it. Once my color cartidge ran low, everything printed pink).
Let me know if that works for you.
Jun 05, 2008 | Dell 924 All-in-One InkJet Printer
Dell A960 All-In-One InkJet Printer Logo
193 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
