Question about Dryers
Tumble dryer My tumble dryer still works and turns the clothes but does'nt heat up! Took the back off and can see the heating element but it all looks connected properly and does'nt seem damaged. Will this be expensive to repair?
  • 5 more comments
  • Geesh Oct 08, 2007
    Where would i get a multi meter from because all the people i've asked about it are not quite sure what one is! hopefully if i can get hold of one i might fix my problem. the help posted was helpful but cannot say it's fixed yet!
    Forgot to add i can't see a trip switch anywhere in the back so i don't think it would be that!?
  • iduuno Oct 03, 2008
    Dryer tumbles but no heat. Lint trap in front cleaned. I know I need to check the outside vent to make sure not clogged. What else could be causing problem? What year was this model # mfg.?
  • boballison7 Feb 06, 2009
    dryer spins, but there is no heat. Is there a check list or manual online?
  • Anonymous Feb 09, 2009
    I have had the timer changed and thermostat changed and it still spins and will not dry the clothes.
  • michelle2402 Mar 01, 2009
    My tumble dryer does not heat up as well as it used to. Is it repairable or do I need to replace it. A load takes 2 hours to dry now, it used to take 40 minutes.
  • Anonymous Mar 31, 2014
    Dryer tumbles, but does not heat up
  • 209 Answers
The element has to be tested with a multi-meter, looking good just isn't enough, it could also be a cut out that has tripped, there are normally 3 on a dryer, all need to be checked with a meter, easy job if you know what you are doing hope i have helped you where to look next, if so please rate me
Posted on Oct 03, 2007
  • Anonymous Oct 09, 2007
    basically a multimeter is just a meter that checks the circuit of a component,
    if you can check the circuit of the element using other methods then that is just as good, all you are doing is checking that there is a circuit through the connections of the element from one end to the other, if there is no circuit the element is faulty
    there are small cut outs located around the machine, different machines and models have these cut outs located in different places, so its no good me telling you where they are, but trust me there are at least 2 of these fitted by law for safety reasons
    try different methods or ask someone electrically minded to help you, it has to be the element or cut out, you are very close just keep going
SOURCE:
Clothes not drying
Clothes not drying? Thats it? Does the dryer turn on at all? Does it tumble the clothes but doesn't get warm? If it turns on and tumbles but takes a long time to dry, then your heating element is not working. There is a thermal fuse right before the heating element that will open up if the vent becomes clogged and its gets too hot. The thermal fuse is not resettable and will have to be replaced. If the thermal fuse is o.k. then your heating element could be burned out. These two items almost require an electrical meter to read continuity to check them. Make sure the dryer is unplugged before checking these items.
Dec 21, 2011 | Zanussi TC7114W Electric Dryer
The dry will not start the display or dig. Controls wont engage anything the start button keeps flashing was just working great
Bad Heating Element
Most clothing dryers heat up and dry clothes with a heating element inside the appliance's body. Maytag dryers are no different and sometimes these heating elements break down or burn out, making the dryer cease to get hot. Make sure the dryer is unplugged and the breakers that run the dryer are switched off before inspecting so you don't electrocute yourself. The heating element is in the bottom panel of the dryer and is often a silver part which heats up when the dryer is on. Sometimes the heating element will be cracked or burned out, which means it is broken. Other times it won't look damaged but may not be working. Replace the heating element if this occurs, to see if this is the main problem.
Broken Motor
Maytag dryers have motors which turn the dryer drum, tossing the clothes so that air and heat can help dry them out completely. When the dryer drum is not turning it means there is something wrong with the motor or that the motor is not getting power. Unplug the dryer and take it apart to inspect the motor. Once you have found the motor, plug the dryer back in and use a meter to see if the motor is getting power. If it is, and isn't working, then there is something wrong with the motor and how it is operating. If the motor isn't getting power, then there is something wrong with the circuits or fuses which disperse power to the motor itself.
Bad Switch
When Maytag dryers won't tumble or heat the clothes which have been put inside of them, this means there could be a number of different things wrong. However, sometimes there's a simple solution to this problem: The switch on the door of the dryer itself may be faulty or not making the electric connection it should to allow the dryer to run. This is a cheap fix and worth troubleshooting before tearing your Maytag dryer apart. Remove the switch and inspect the two leads to make sure they haven't broken or are still transferring electricity. If they aren't you will have to replace the switch
Mar 11, 2011 | Maytag Dryers
My whirlpool model LTE5243DQ6 is not heating up. i turn it to the max heat and it doesn't heat up. it turn on and i could hear the clothing moving but it not heating up.
Hi
If the dryer is not drying the clothes then you would need to check for the following things-
1. Inspect the fuses and circuit breakers they may have burned out or tripped. Usually, dryer will still tumble but not create heat if a fuse or a circuit breaker is not working.
2. Check for the amp reading at 240 V, it should have reading of 24, 21 and 3 amp (approx.) for 2 lines and neutral respectively.
3. Heating element may have turned or the connection to the element might be loose. Sometimes a shorted circuit element will keep on blowing the fuse or circuit breaker.
4. Motor wiring shorting to ground.
Hope this helps... Please post back if you need more information.
Daniel
Feb 10, 2011 | Washing Machines
Electric dryer tumbles but does not dry clothes on any setting. dryer is only 4 yrs old.
Heating element has gone bad. You need to unplug unit. remove back, then find heating element and remove it. Look for what looks like broken springs, if found replace element. 99% of electric dryers not drying are the heating element. Cost around $50
Sep 28, 2010 | Dryers
Dryer not heating, still tumbling
your heating element could be burned out...or a thermal switch could be stucknot allowing the element to turn on
May 25, 2009 | Dryers
My kenmore gas dryer heats up but cools down too fast without completely drying my cloths
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Oct 15, 2008 | Kenmore 74602 Gas Dryer
Maytag compact dryer low heat doesnot dry. works for hrs clothes still damp.
Heating element
Thermal fuse
Wiring
Oct 02, 2008 | Maytag MDE2400AYW Neptune Electric Dryer
Dryer runs, tumbles clothes, but does not heat
Heating element
Thermal fuse
Wiring
Aug 09, 2008 | Maytag SDG4606A Gas Dryer
Dryers Logo
716 people viewed this question
Top Dryers Experts
Marvin
Marvin
paul
paul
