Question about KitchenAid KESC300 Electric Kitchen Range
Kitchen Aid KESC300 smooth top electric stove
Error Code read F7E0. Cooktop works fine. When you try to use the oven is start up for about a minute, shuts down, beeps, and gives the above error code. I was hoping you can tell me what is wrong with it. Thank you!!!!
  • Anonymous Nov 11, 2007
    When I use the front burners for an length of time and have the oven on , The oven goes off and wont come back on until the burners cool off as if the control panel gets to hot, Also when I tried to clean the self cleaning oven it doesnt work. Any suggestion as to what I need to have looked at....
  • gilardonepg Dec 12, 2008
    Kitchen Aid KESC300 smooth top electric stove problem. Oven shuts down
    after 10 - 90 seconds and F7EO displays. Top range works well.
  • 473 Answers
Look on the back of the oven for a tech sheet. This will tell you what the code means and what to check. May be an oven temp. sensor or oven control bad. Can't remember what f7 is without looking at the tech sheet.
Posted on Oct 06, 2007
I tried to change the light bulb in the oven, thought I had the power turned off, I did not. The bulb socket sparked, nothing seemed to happen but now my controls on top of my kitchen aid KESC300 electric...
Hello- Glass bulbs don't make very good handles, do they? Find a good tech to check wiring behind bulb socket. May have burned a connection, and or grounded a wire somewhere. Electric ranges have two 110v circuits that work in combination. One is out. Let me know if info helps- have more if needed- Thanks- ED
Mar 04, 2010 | KitchenAid KESC300 Electric Kitchen Range
CONTROL PANEL WON'T WORK AND HAS - F2 E0 - ERROR
Remove the power and disconnect all connectors to the control board and put them back on one at a time. If it still won't work the board may be faulty.
Aug 26, 2009 | KitchenAid KESC300 Electric Kitchen Range
Large element burns high
The problem is in the switch not the element.
Mar 24, 2009 | KitchenAid KERC507 Electric Kitchen Range
Kenmore Select Clean Self-Cleaning Electric Range Model 6659580
This means you hace a problem with your clock. Take the back off the stove and then pull the ribbon connector off the clock and clean the terminals. If that doesnt fix it replacing the clock should fix it.
Nov 16, 2008 | Kenmore 91112 / 91114 / 91117 Electric...
Could you tell me what F11 code means?
F11 error code means there is a problem with the Control panel. Could be melted wiring, etc, since you left the oven standing. However, you can try unplugging the device from the power socket for about 5 minutes and reconnect. If the error goes away, then well and good; if not, you may have to replace the panel control.
Oct 13, 2008 | Frigidaire Kitchen Ranges
ERROR
it means one of your door latchs isnt reading could be faulty
Sep 11, 2008 | KitchenAid KESC300 Electric Kitchen Range
Error code E1 -F5- Broil element comes on and wont shut off
if it is a whirlpool, kitchen aid or kenmore by whirlpool you need to check the self clean latch asembly found on the rear of the unit. check the micro switches with an ohm meter. always remember to unplug the oven before you test any thing or replace parts. not sure why the broil wouldnt shut off. but the f5 error is definatly related to the door latch.
Sep 06, 2007 | Kenmore 95822 / 95824 / 95829 Electric...
Oven is not working
Both elements are controlled by a common relay on the ERC (Electronic Control Card) and cannot be repaired. The ERC needs replaced. This is also referred to as the Clock/Display.
Aug 17, 2007 | KitchenAid KESC300 Electric Kitchen Range
KitchenAid KESC300 Electric Kitchen Range Logo
701 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Carmen Mikulic
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
