Question about Western Digital 500GB My Book World Edition 500 GB Hard Drive
My WD 500GB My book (world edition) keeps going offline
My WD My Book (world Edition) only stays online for less than a day. It is only a month and a half old. To get it to be recognized by the Mionet software (WD's newly aquired company)I must power it down and then back up. When I go to access it later in the night, it is again offline. I have emailed WD twice and have NEVER gotten a reply (Over 1.5 weeks) Thank you
  • 5 more comments
  • Sparky311 Oct 13, 2007
    to connect to the hard drive (from the local network), I went to the start menu then run and typed \\mybookworld   (which is the default name of the book.  This always worked for me (it was the mionet drive mapping that was inconsistent.  I then ran an extension cord from another household circuit to the drive only and restarted my mionet connection (I didn't have a problem for at least two days).  This told me that it was a power issue (probably a bad choice of power supply for WD).  I then redid how everything was plugged up on the old circuit by trying to put this POS WD drive on a power strip with as few of other low energy consuming things as possible and plugging that power strip directly into a socket.  So far it is working.
  • catfreak Apr 03, 2008
    Hello
    I have exactly the same problem and got no answer from WD.
    I found this post and changed the socket
    Also I will format the disk. It did cost me a lot off time up to no trouble shouting. I hope your remarks work.
    Andre
  • Anonymous May 02, 2008
    I have exactly the same problem. I don't think the power supply is the trouble maker in my case, I have my WorldBook II 1Tb plugged to a no break and only stays active for some hours, then I have to switch it off and then on again. So much for "world wide access"! I am very disappointed and confused. I hope the trouble of going through reformatting it an resetting the whole thing fixes the devices.
  • randyWCG Nov 30, 2008
    Ditto, have had mine for less than a month. Have NEVER been able to get an online indication, although the WD Backup indicates it's running. I cannot get into WD anywhere.
  • Anonymous Dec 07, 2008
    having the same problem.
    notified that the device can not be pinged: seems to drop out of the network.
    Bought it. seems to have this problem. Didn't have time.
    Installed it yesterday again (after a year. Immediately did a firmware upgrade. it worked that day
    this morning: no connection, no ping, no connection LED's on the Ethernet adapter. The thing is just dead!
    As it's yet out of warranty (got is for over a year now, just filling the shelf). I can not claim anything.
    ANYONE have a solution??
  • Anonymous Feb 04, 2009
    From day 1 mionet does not stay on line. very frustrating to not be able to access MY files when I want to. I have in the past rebouted my computer and the external hard drive, sometimes that works. I have tried to connect it to my computer directly using the ethernet cable, I have not been successful with this at all. I have called Western Digital and was told they are having problems with Mionet and that I sould connect the hardrive directly to the computer but he could not help me to do this!
  • hand1e May 11, 2010
    I know power supply is not the issue on mine, I also have a 400GB MyBook with the same power supply. I swapped them, and my 400GB powers on, but my 1TB will not power on with either. Randomly it powers on after unplugging and replugging all cables and restarting my computer 3 times, and I get about 1.5 hours of use. This same process does not work the next time. For the love of god how do I use this incredibly expensive hard drive?
Is your drive warm/hot like mine was/is ?
Mine dropped offline 2 or 3 times a week.
Put a small fan blowing on it.... been up for two weeks now.
Posted on Nov 06, 2008
    New Friend:
My 1TB version was working great up until last week. This was when I moved my computer setup across the room.
After that I was having the hard drive drop off the network quite often, while downloading, watching a movie from it etc.. I would have to unplug and restart it and all would work for a few hours.
I tried upgrading the firmware with no change, in fact I think that caused it to go offline faster.
I decided to spend some time to investigate and noticed that the AC adapter also fits in my cable modem. I swapped them around and my hartd rive has not gone offline since.
I must have mixed the two AC's up during the move. Atleast I don't have to go buy another HD....
Check this before you try anything else.
Posted on Nov 23, 2010
  • KaffeMyers Jan 04, 2011
    Seems like we did the same thing, switched the power supply cables which incapacitated the drive. It works perfectly with the original WD cables.
I have a My World Book II 1 TB
Same issues. I have MAC and PC clients and this piece of **** keeps dropping off the network! i should have just bought some cheap chinese **** - at least i would have expected these headaches. I am probably going to remove the two 500 gig HDs and put them in some enclosures. I can't believe the might WD released such a shoddy product.
Posted on Jul 27, 2008
Hi to all.
I've found this in linuxquestions.org .
You may have ssh access to your WD My Book World edition and login (login is all in uppercase) and execute as root (doing a su because root has not password):
umount /dev/md4
tune2fs -O ^has_journal /dev/md4
tune2fs -j /dev/md4
mount /dev/md4 /shares/internal
It will fix the problem with journal (I hope it).
That solved MY problem.
Thanks and sorry for my very bad english, but I'm only trying to help others.
Posted on Jul 05, 2008
For Gods Sake!!!
DOES NO ******* BODY on the internet knows what about the vista X64 Drivers for this ******* WD 500GB thing i bought???? OMG? Mionet. Lazy bastards. GO WORK ON YOUR PRODUCTS AND ACTUALLY START RUNNING A REAL SERVICE & SUPPORT
Posted on Aug 11, 2008
Wot do u do when you are offline and 3/4 full of data and already got mionet on computer xp x64 and cannot access data thru mybookworld because it doesn't recognise my mionet password or is there someother password required?
Posted on Jun 28, 2008
This product is a disgrace. First, because the notion that no-one would want to store more than 1000 files in a directory or subdirectory on a 1TB drive is bizarre. Second because MioNet won't work with Vista x64 which is bundled on all new high end computers. Third because MioNet is infuriating even when used from a PC running Windows XP Pro x86. Like many others around the world, I have found that MioNet in Manage mode just reports the drive as OFFLINE and that's the last you will ever see of your drive or data written with MioNet directories. You can get limited usage out of it with SAMBA access by using your browser to open \\MyBookWorld and running the bult-in drive management utility, BUT and it is a critical BUT, the drive will still not work with most backup software, even though network attached storage is what most home users want to use for backup.
So, in short, unless you just want to use this drive for shared storage of unimportant files on a home network and don't need it for backup purposes, go ahead and use it but don't install MioNet whatever you do - only use the native utility at \\MyBookWorld!!
Posted on Jun 23, 2008
I have come across lots of problems with the WD MyBook range. The bulk of problems are caused by WD being lazy and not informing thier customers properly.
When you buy a WD MyBook it comes pre-formatted by an Apple Mac so both Windows and Mac workstations are supposed to be able to access it.
The reality is that if you are using it on a Windows PC after a while it will start playing up and doing weird things (like sometimes showing up/sometimes not).
What you are supposed to do if you are using a Windows PC (which WD recommend but forgets to tell you on any MyBook packaging/docs) is to do a full format before ever using it.
***If you havent done so and already have data on the MyBook, this will be erased if you format without backing this data up beforehand.***
After formatting it you need to ensure that you always remove the device safely before unplugging it. This is an irritating Windows design flaw, where if you don't remove the device safely it could corrupt the data on part of the drive and it might never be recognised by your PC again.
So I suppose what I'm trying to tell you is if you have any valuable data, like family photos and things that can't be replaced , that you think is safe by saving it on your MyBook. Don't! The same goes for any media, especially USB HDD's. The only thing you can do is do multiple backups, don't just save them in one place. Save you valuable data on cd's and store them somewhere safe.
That being said, WD MyBooks are great value for money and on the whole a good product. As long as you look after it and treat it well it should last you a long time.
I hope this helps you if problems arrise again.
Posted on Oct 28, 2007
I had the same problem. After contacting e-mail support at WD they suggested an exchange under warranty. The replacement unit was 50% bigger (750gb) and it has worked perfectly from the day it was switched on.
Posted on Oct 03, 2008
6ya staff
SOURCE:
How to replace hdd on my book live
If it's under warrenty then contact WD for a RMA. If it out of warranty then you can go to you tube for a tutorial.
Aug 04, 2013 | Western Digital 500GB My Book World...
Can anyone tell me what type of replacement drives go in a WD World book II? 1 TB
Do I understand that you are willing to open up the enclosure yourself to replace the drive inside?
You can put any two SATA 3.5" drives inside you want, as long as they are identical to each other.
Nov 25, 2009 | Western Digital 500GB My Book World...
Same Problem with MyWorld Book Edition II, sent back got a new on
Exactly but this time around they change it. If there is some issued about your My Book keep us update here to know what is the problem it made.
Jul 29, 2009 | Western Digital 500GB My Book World...
My network wont detect wd my book world edition 500 GB HD
if u have a Cd rom which have a driver then u shoud download it on all computers in ur network to make it work better and faster but if there is no CD driver then u shoud read its manual
Jul 25, 2009 | Western Digital 500GB My Book World...
Had my book 500gb hard drive for less than a day, same problem, no recognition and no blue light, lost my music backup. Not impressed.
Cheap power supply provided, died on the first day. Contacted ebuyer and they sent me a better quality, replacement power supply the next day.
Jun 20, 2009 | Western Digital 500GB My Book World...
Can't Access my WD World Book.
what system you use for your WD World Book
Jun 17, 2009 | Western Digital 500GB My Book World...
I have a world book 1tb hd with mionet. connec to network
hard drive is hanging up continually have to p[lug in and unplug in order for me to transfer everything off of it!
Dec 11, 2008 | Western Digital 500GB My Book World...
Keeps going off line and then freezes / can't turn off
I'm getting issues like this too...ready to throw the thing in the trash...as soon as I can figure out how to get files off of it.
Jun 23, 2008 | Western Digital 500GB My Book World...
PROBLEMS WITH MY WD BOOK
Hi, This post might be of some help/idea... http://www.fixya.com/support/t191153-device_recognized The only difference is your model uses Western Digital and not Seagate. Yours can still be recognized but Windows consider it non-formatted. First try a data recovery software and another storage medium where you can copy the files if you're successful in the recovery. Good luck and kind regards.
Aug 28, 2007 | Western Digital 500GB My Book World...
Western Digital 500GB My Book World Edition 500 GB Hard Drive Logo
7,235 people viewed this question
Top Western Digital Computers & Internet Experts
Ekse
Alun Cox
Marvin
Marvin
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
