Bad tuner on F27680gy
I can hear sound but see no picture. I am guessing the picture tube has gone bad. This TV has two tuners and a repairman once told me that if the first tuner ever goes, I can switch tuners. The user manual does not mention this. Do you know how I can switch tuners to make the other one primary?
  • 372 Answers
Hi. Your problem is not at all likely to be the tuner or the crt. Your problem will be frame collapse or fault in heater chain. Not complicated for repair shop to sort out for you.
Posted on Sep 30, 2007
Dynex DX-LCD37: Missing cable channels caused by bad tv tuners?
That "Tech" is full of hot air, I have never heard of such rubbish! http://www.hdtvreview.com/pdf/dynex-dx-lcd37-09-02-manual.pdf
Above is your manual. have a look for your self. Now IF you can do Picture in Picture, then technically, there are TWO tuners, BUT one cannot work, and the other not, I do NOT know what that Tech is on about I suspect he is BSing you... If channels are Blocked, then it is maybe something wrong with the cable, or the strength of the signal, or something else, But there are NO "Tuners" that are going faulty, this is NOT how a TV receiver works.
Does this Dynex model have multiple tuners: NO If so, can they go bad : Yes, as could any electronic bit. maybe the ONLY tuner has faulted, but I don't think so. Tuners usually work, or don't. but still may pay to take to a professional and ask them to check the tuner?
Are the tuners replaceable: YES.
will the rest of the tuners eventually go out and I will end up replacing the TV:. NO, well depending if there is any fault, maybe.
Again I have never heard such BS, EVER.
Apr 08, 2010 | Dynex DX-LCD37 TV
WHITE DISTORTED SCREEN
U Main Tuner signal board is dead.Replaced the Main Tuner board will solved this problems.Picture was white distorts,he should of replaced the Main Tuner board.The T-con control board only replaced when u have power to tv,but no video.When have any kind of video on the tv all it way cause by Main Tuner signal board.
Mar 17, 2010 | Televison & Video
My 32" Sanyo HDTV from Walmart has problems with the picture and sound blinking off. You must push on TV to get the picture and sound to blink back on. Sometime it stays and sometimes it goes right off...
Sounds like you have bad solders in or around your tuner ***`y .Try knocking on the cable input while it`s working, this might confirm bad solder or cable connector. In case of bad solders you can take the cover off, the tuner will be right at the end of that connector and mounted on the circuit board . The bad solders are often on the p.c board itself . If you feel handy with a soldering iron you can resolder the tuner on the board, otherwise you might need the help from a local repairman. In any case you will know what is going on
Hope this will help Good luck
Dec 01, 2009 | Televison & Video
I have a Toshiba cx35e70 tv. The problem began as a turn on, live screen, no channels, no sound. I found that when I would tap on the tuner on the main board the problem would disappear. Every thing worked...
Is the VCR going through ch 3 or video inputs - if video inputs your TV tuner is likely bad if through ch 3 seeif te picture goes funny on ch 3 without using the VCR the tuner may be bad on higher band channels - smetimes you can remove the tuner and resolder the tuner itself. But if it always works with the VCR just use it that way and don't bother with the fix.
Sep 26, 2009 | Televison & Video
Bad/No reception problem on older tube tv worked good yesterday
have your tuner check for any cold solder on pins.
Jul 29, 2009 | Televison & Video
The tv acts like the cable has gone out even though it has not. on my mitshubishi rear projection 52 in
do you have the yellow video and red and white audio rca cables ?
it will give you a better picture than the coax connection.
but the tv tuner may be going , so using the rca jacks would eliminate the tuner, but finding out which tuner is bad ( cable box if using one or the tv tuner)should be checked with another tv to see if it also happends to that tv , if it does not then the other tv tuner is bad and needs to be replaced
Apr 18, 2009 | Mitsubishi VS-45607 45" Rear Projection...
Sony projection tv with dual tuners; only one tuner appears to be working now.
To verify that the tuner is the problem, move the cable from the second to the first. If you don't get a signal, the tuner is bad. The main tuner is part number 859843000 and is available for $47.38 from tritronicsinc.com
Dan
Oct 07, 2008 | Sony KP-51HW40 51" Rear Projection...
Sharp v29j200s always blue on the screen
Sharps are known for bad tuners and cold solder joints.If you tap on tuner and picture comes back there is cold joints in tuner, If not most likley bad tuner. if the audio is there with blue screen it is the tuner definitly.good luck
thanks DOCTOR VIDEO
Mar 25, 2008 | Orion1934 19" TV
RCA Scenium HDLP 50
YOU HAVE AN INTERNAL TUNER FAILURE IT NEEDS TO BE REPLACED
Jan 06, 2008 | Televison & Video
Tuner A/B Out
I think you may be missing a power supply voltage from the sweep supply from a shorted convergence IC or a Bad capacitor. Not alot a user can do as it is a splid state set and requires know how of the circuits to find out whats bad in that circuit. Please seek out a trained tech to assit you in this repair.
Sep 27, 2006 | Mitsubishi VS-50611 50" Rear Projection...
Televison & Video Logo
66 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
