Question about Indesit W 123 Front Load Washer
Indesit WI 101
The machine began a cycle and then it blew the mains fuse - since then it won't turn on at all. The fuse is reset - does the machine have some kind of internal fusing which can be reset? It had been having a slight leakage from the tap which was quickly fixed and I don't think had caused the problem.
  • washedup Oct 01, 2007
    I have checked the plug fuse - it is working...
  • Richy Jan 04, 2013
    i got the same problem... is there an internal fuse?
    President:
  • 1,294 Answers
Check the fuse in your washer's plug.
Posted on Sep 30, 2007
SOURCE:
Indesit wia 101 stuck on one part of cycle and won't move on
check pump for blockage remove plug for 15mins re try
Apr 19, 2015 | Indesit Washing Machines
Indesit IWD7145K Washing Machine Error code F06 flashing on digital display + all program indicator lights. What does this mean. There is no such error code in the troubleshooting section of the manua
F06 - Door lock fault
Issue: Washing machine door cannot be opened or closed/when the door is closed the machine the programme will not start.
Advice: If your washing machine door will not close, please check for any obstructions in the door lock.
OR,
Switch off the device. Disconnect power. Wait about 3 minutes.
Open the door, then close. Reconnect device to the network.
Start device.
Cause: Door lock fails to close / open door lock triac open / closed,
frequency signal fault
Dado
Feb 12, 2015 | Indesit Washing Machines
Fuse blew half way through cycle ,changed fuse but cant get washing out
Try plug out plug in...it may reset...a long shot I know but try.
Regards,
Dennis
Aug 21, 2014 | Indesit Washing Machines
I have a indesit WIB 101 (uk) washing machine.
Remove the belt, and from the front, spin the drum by hand.
If it is noisy or rumbling or feels rough, then the main drum bearings have failed which would explain why the belt was off.
Also check the drum pulley for a brokem or cracked spoke, again this will give you the same symptons.
Please rate my solution.
Thankyou.
Jan 13, 2010 | Washing Machines
Indesit WIA 101 Machine wont start.No power
first check the fuse,if this is ok,you will require a main control board,this will require programing for you model and comercial code
Jul 25, 2009 | Indesit W 123 Front Load Washer
Indesit W1A111 starts cycle when selector set to "off"
many indesits have a memory on board, set the timer to off position, turn on the mains press start let the machine finish what it is doing, and it will reset normally, turn off at mains for a few minutes can also do the trick, it sounds like one of the option buttons was pressed and you didn't let the timer finish its course,
Aug 29, 2007 | Indesit W 123 Front Load Washer
Indesit evolution DE73 frozen program
I have the same problem. You need to switch it off at the mains for at least 20 mins.
Aug 14, 2007 | Indesit 24 in. DE73 Evolution...
Wi 101 INDEST
you might have a pressure switch problem due to a blockage in the sump , but more likely the fault is down to tracking on your control board. You might be lucky and find that if you take the board out and clean it around the the botttom of the printed side it might just work, failing that I suggest you call an engineer
Aug 01, 2007 | Indesit WA 115 Front Load Washer
Indesit W 123 Front Load Washer Logo
266 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
