Question about SanDisk Sansa e250 MP3 Player
I had the error of refresh database fail but my pc still cant see the mp3 player
I had the problem of the refresh database file i fixed it with a solution on this site. But if i plug it in to my computer then i hear the sound that a usb device is conected but i cant find it no where. not in my computer not in any sync programs does anyone know how to solve it??
  • 626 Answers
Check in the Device Manager on the computer. With the device connected Right Click on My Computer and select Properties>Hardware Tab>Device Manager. If there are any errors (red or yellow) by the Sansa, right click on it and select un-install. Disconnect the device and after it restarts, re-connect. The drivers will re-install. If that is not the issue, try using a different USB port, preferably in the back. Or, change the device mode Settings>Mode or USB Mode and try connecting to PC. You can add to the question if you need more assistance. Best of Luck.
Posted on Sep 30, 2007
SOURCE:
While switching on the mp3 player... it been hanging.... refresh database error
Reset the sansa by pressing on the reset on the device , this is usually a small pin hole through which an office pin can be put in and pressed.
Now connecct your player to the PC and scan for virus, copy out all the files and format, the reinstall safe files.
The player will work fine.
Sep 01, 2010 | SanDisk Sansa e250 MP3 Player
Stuck on fresh database
Some songs or files with extension device can't read, so it takes so long/infinity to refresh. Plug the device to pc, format it.
Good luck
Feb 18, 2010 | SanDisk Sansa Clip MP3 Player
"Refresh Database" freezing
Dude connect your mp3 player to your pc and then format it ... it will help alot...!
Thankyou. :)
Jan 08, 2010 | SanDisk Sansa e260 MP3 Player
(Sansa 2.0 GB e250R) Player shows an empty database...
DO YOU GO TO YOUR COMPUTER ICON ON YOUR COMPUTER AND THEN PLUG IN YOUR SANDISK SANSA AND THEN DRAG YOUR SONGS TO IT BECAUSE THAT IS WHAT I DID AND IT WORKED
Apr 15, 2009 | SanDisk Sansa e260 MP3 Player
Refresh database loop
SCREN LOAD MAIN IMAGE FAILED SWITH TO RECOVERY MODE
WHAT HAVE ?
Sep 24, 2008 | SanDisk Sansa e250 MP3 Player
Refresh database (frozen )
Connect your mp3 player to your PC then turn it off by holding power button until it shuts off, switch the hold switch to HOLD then press and hold the REC button on the side until the mp3 player shows a black screen and your PC shows that it found a 16mb removable media, now download the file from the below link. Run it and it should fix your problem, but note that all your files will be erased.
http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe
Jan 22, 2008 | SanDisk Sansa e250 MP3 Player
E270r Refresh Database error w/ version details error
Try putting the player into "msc" usb mode. "mtp" usually does that, but i've never hear of it being on the comp.
Good luck
Dec 17, 2007 | SanDisk Sansa e250 MP3 Player
"refresh database failed"
You have an error in the firmware. This is damage than is irreparable by any user of a mp3 player. Call the company, tell then that your firmware was corrupted and ask how you can "hard boot" back into a "Fresh copy" of your firmware. Problem solved! hope this helps!
Jul 14, 2007 | SanDisk Sansa e250 MP3 Player
Sansa e200 shows refresh database fail
Try emailing SanDisk technical support team at: [email protected] And ask them for the Recovery Mode firmware upgrade (Also send them the problem the way you posted it here). They should send you a link to some firmware upgrade file. You could also try calling them at: 1-866-726-3475 but an email should be sufficient because, from what I remember, it is just a link to file that you need to download. I hope that helps...
Feb 07, 2007 | SanDisk Sansa e250 MP3 Player
"refresh database failed" how do I do a database refresh?
i have the same problem ... refresh database fail .. i can put songs on the player but it doesn't show them or play them :-( HELP!!!!
Nov 15, 2006 | SanDisk Sansa e260 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
61 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
