Question about Sony Cyber-shot DSC-W70 Digital Camera
File Error I have a Sony Cyber Shot camara. It has one problem after taking some pictures or recording a vedio, the pictures can't be viewd and says file error, the display mode shows file error, when I format the card it works for while after some pictures again same problem, I can't harldly take more than 30 pictures. Please if you can help me. Thanks, Mansoor
  • Jmansoor Oct 01, 2007
    Thanks alot, I have already formated the memory, run anti virus, and even I replaced the momory card still the problem remains the same. I feel it is a problem with inside the camara.
    Please look again to this problem, waiting for your further help.
    Thanks again ,
    Mansoor
    Brigadier General:
  • 6,966 Answers
Hi, It might be time for a new memory card. A last effort you can try is to remove the memory card and insert it into a memory card reader connected to a PC. There are diagnostics and utilities that can be performed on your memory card since it will be treated by your PC as a removable storage. You can format the memory card, run diagnostics like Norton Disc Doctor or similar. If in any test an error shows, then you have just confirmed that is due for replacement. If after formating, scanning and checking it shows good, then you can try using it again. You can also try cleaning the little gold tips at the end of one side of the memory. Hope this be of some help/idea. Post back how things turned up or should you need further information. Good luck and kind regards.
Posted on Sep 30, 2007
  • Louie  Role
    Louie Role Oct 01, 2007
    Hi again,
    Based on the updated information you provided, we can rule out the memory card. It is then possible that the contacts where the memory card mates to are partially corroded or not completely touching the pins of the card. This is rather a tricky repair since this involves cleaning the contact pins of the camera which is in a very tight enclosure. You might need a very thin tweezer or something to reach the said contacts. Cotton or cotton ear buds should work if you can make it reach and fit in such a confined space.
    If this does not solve the problem, then perhaps it has something to do with the firmware of the camera which may be flashed by the authorized camera manufacturer's service centers.
    If things prove to be to beyond economical or practical reason, perhaps your best bet is to replace the camera itself.
    Cheers.
SOURCE:
Can't take a picture, just records
try taking out the battery's and then put them back on also make sure it is switched over to take photos there should be a button to change it back to photos.
May 31, 2009 | Sony Cyber-Shot DSC-W1 Digital Camera
I have a Sony-Cyber shot DSC-P72
It's a memory card error,You can try to take the memory out and retrieving them with your computer
May 13, 2009 | Sony Cyber-Shot DSC-P72 Digital Camera
Sony Cyber Shot 5.0 MP Zeiss Lens has distorted image
Please RESET camera by going in to camera MENU -> Initialize -> OK.
Camera will go to default factory settings and problem will resolve.
Feb 25, 2009 | Sony Cyber-Shot DSC-S500 Digital Camera
Sony cybershot dsc p200 user manual
Press Menu and go to setup, set date and time option to adjust it.
You can download user manual of DSC-P200 by clicking Sony Support. for further guidance.
Feb 11, 2009 | Sony Cyber-Shot DSC-P200 Digital Camera
Menu is not working in dsc w 55 sony cybershot
This camera is eleven years old, and is probably worn out
May 02, 2017 | Sony Cyber-Shot DSC-S40 Digital Camera
Memory stic in camera format problem
dear,i've sony cybershot DSC_W35.I was getting format error c13.01 when i insert sony memory stick.but I've no problem when i was using internal memory.how can you rectify this problem
Nov 07, 2008 | Sony Cyber-shot DSC-W35 Digital Camera
File Error
my camara when I see or viewed the picture same of they are bad with lines and same videos says error and I can't see it
May 18, 2008 | Sony Cyber-shot DSC-W30 Digital Camera
File Error
I also have the same problem
Dec 17, 2007 | Sony Cyber-Shot DSC-S500 Digital Camera
Camara won't take pictures, screen shots look black and white blurry
Hello, please try to reset the camera and check your settings according the user manual. If you need more info please advice. Arpi
Jun 14, 2007 | Sony Cyber-shot DSC-W70 Digital Camera
Sony Cyber-shot DSC-W70 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Dan Dangel
Dan Dangel
Level 1 Expert
Are you a Sony Camera Expert? Answer questions, earn points and help others
