Question about Panasonic PV-GS150 Mini DV Digital Camcorder
Panasonic pv-gs150 mac connection
Hi i cant get my panasonic cam corder to connect to my mac.....i have it hooked up with the fire wire and it does not show any connection on the imovie. when i first inserted the firewire into the camera and opened imovie it said "having problems finding camera" and then it acted like there wasnt a camera on the computer any more. i cant find any connection of the camera on the computer....any suggestions?
  • Motor-Roller May 07, 2008
    DV NOT WORKING ON MY PV-GS150.
    My camera's DV port seems to be broken. I tried to sync with iMovie, on several different mac computers, with several different versions of iMovie/Final Cut LE and each time the program said no camera connected. As a final test I connected it to a DVD /VHS recordrer, DV to DV and no workee. I tried pressing the reset button and turning the camera off and on, etc. So, I am now convinced the camera is the issue. Has anyone had their camera fixed recently? Is it worth it? Thanks
  • andrewbush Aug 19, 2008
    I tried using firewire, DV cables an dsetting to playback mode... my macbookpro is not recognizing it.... what am i missing to do? do i need to open an application on the mac first? if so, which - iMovie?
    Genius:
  • 1,447 Answers
For Macintosh
OS:
Mac OS X v 10.1–X v 10.3
CPU:
iMac, iBook or Power Book G4, Power Mac G4 or
Power Mac G5
RAM:
64 MB or more
≥The USB equipment operates with the driver
installed as standard in OS.
Posted on Apr 11, 2008
Compatible data card
I don't think this model has anything other than mini-DV tape. That's part of why the market is so saturated with mini-DV cams and hi-8. If there are memory slots -- take a poto and upload so we can troubleshoot.
Nov 17, 2012 | Panasonic PV-GS150 Mini DV Digital...
Push the reset button
you take it to service center. there are chances that you will mess it up more than than what is it now
Jan 28, 2008 | Panasonic PV-GS150 Mini DV Digital...
Hello, could you advice where I could purchase Panasonic NV-GS150 DV Camera MAC OSX 10.5 Support? I cannot connect my Panasonic NV-GS150 DV camera with my MacBook Pro. Thanks a lot for your help!...
Panasonic usually includes the Mac software program "Imagemixer 3" that imports the videos/photos you have on your camera. If the software isn't included with your camera, try Googling around for the program and it should come right up! I hope this helps. - Omn1cide
Mar 05, 2011 | Panasonic NV-GS150 Mini DV Digital...
Panasonic PV-GS35 will not connect to iMac, so can't upload video from mini DV cassettes into iMovie. when I connect with my USB cable, nothing shows up on the iMac saying that the camera or a "N0_NAME"...
So if it's miniDV and you have a firewire cable, it should work. Have you followed this sequence:
If your battery is sufficiently charged to run the cam for an hour's worth of tape, fine, otherwise connect cam to AC power. With cam OFF, connect Firewire cable to Mac and cam. Open iMovie, name your project and create so that the viewer screen comes up. Turn on the cam. At this point, your Mac should, within moments, say "camera connected". Cam needs to be set on "playback" mode for capture. Then click "import" button and your Mac will control the cam.
If you still get a "no camera connected" you have to consider the possibility that either the firewire cable is bad or the firewire port on cam or Mac is bad. If you have more than one firewire port on your Mac, try switching. An Apple store should be able to help you determine if you have a bad cable or cam port, if you take both in to try on their Mac. Hope this gets you on track.
Dec 07, 2009 | Panasonic PV-GS35 Mini DV Digital...
How to connect panasonic nv-gs150 with dv to pc in 1394 port ?
You need to purchase a IEEE/1394 firewire. They run around $40-$55 for a 5 foot wire. The 1394 end goes into the computer and the other end goes to your AV/out port on the cam.
Oct 09, 2009 | Panasonic NV-GS150 Mini DV Digital...
How to download the movie recorded on a NV-GS150 into my laptop?
Hi, You need to connect the cam to the PC using a firewire cable.
It looks like this. http://www.ectech.co.nz/images/usb%201394b.jpg
After connecting, switch on the cam. Open Windows Movie Maker and import video from device.
Dec 29, 2008 | Panasonic NV-GS150 Mini DV Digital...
I am unable to connect my Panasonic PV GS150 handycam and Vista business edition running laptop using a USB cable. Do I need driver S/W?
You will need to install the USB driver from your software(disc) to your vista.
and make sure the computer is recognizing your camera, check under control panel and device managers list if your product is listed under imaging devices, but chances are you might be having compatibility issues since it doesnt have an updater for Vista, hope this help. pls dont forget to rate. Thanks!!
Apr 09, 2008 | Panasonic PV-GS150 Mini DV Digital...
Panasonic pv-gs12
Hi
You are right - play back mode on the dial or slider.the manual will give all the info on how to use it.If you don't have the manual then go on the Panasonic site and get a free manual.
Hope this helps
jay
Nov 17, 2007 | Panasonic Palmcorder PV-GS120 Mini DV...
Panasonic GS150 Camcorder- MAC not recognizing camera
Make sure you're using the right connectors -- the DV port on the inside of where the LCD screen opens up.
Mar 19, 2007 | Panasonic PV-GS150 Mini DV Digital...
HELP-AUDIO not playing out of Headphones/External Speakers!!
lower the volume on the camera by using the tight/wide slider on the cam
Oct 11, 2006 | Panasonic PV-GS150 Mini DV Digital...
Panasonic PV-GS150 Mini DV Digital Camcorder Logo
1,089 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
