Question about Acer Aspire 5100 Notebook
Acer Aspire 5100 Startup Problem
My computer was working fine. then it froze and i had to restart by holding don the power button. then it was running fine again and then froze again so i did the same thing. now when i power it up nothing happens ... the on light goes on and the fan starts running but no load screen or anything ... can anyone help?
Hi guys. I have the same problem with my Aspire5110. Th only solution i've found is to unplug it from the power. From battery it can startup and works correctly. Unfortunetly I have some other problems as well (i think it's basicly a motherboard problem) so I lost my trust for th acer. The performance is low even with the latest drivers, the Xpress1100 is enough for windows but not enough for games. Even if I play with low graphic details. Some of the games can't even recognize this videocard (eg COD3). I'm haviving trouble using microsoft Flight Simulator etc, etc....I'm a bit dissapointed. I know that this is not a gaming 'powermachine' but I expected more the that for my money. Good lock with yours! Dan
Posted on Oct 08, 2007
    Brigadier General:
  • 6,966 Answers
Hi, The most that can be suggested that you check are the memories and possibly the video card (if an add-on). All others would require opening up the unit. The battery is not even an issue since as long as the AC adapter is plug to the mains and to the laptop, it should work. Even a defective hard disk would not cause the no screen display. Verify that it is not powering up and not just no display. In some cases, the laptop powers up, boots and runs Windows but nothing is shown on the display. A way to check is to connect the laptop to an external monitor, hit the Fn + F? key to enable external monitor. Another is to use a flashlight and shine towards the display panel. If the display is the issue and the unit boots, you will see a very faint semblance of your desktop, chances are that it is a defective CCFLamp or its inverter. If even with with a known good external monitor, no beeps, no display when powered up, it is the laptop itself. As initially said check your memories (or if you've got one, video card). flip the laptop over, underneath would be a lid/panel cover with 1 or 2 small screws. Remove the screw(s) and lift the cover. Exposed would be 1 or 2 sticks of memory. Slightly move the side lock apart and away from the memory sticks, the memory would slightly popout, remove and clean the little gold pins with a pencil eraser. Reinsert and click/lock in place. If there is a video card, do the same. If none of the above works, you might have to seek the services of a qualified professional as this involves opening up the unit and doing in circuit diagnosis. Hope this be of some help/idea. Pls post back how things turned up or should you need further information. good luck and kind regards.
Posted on Sep 30, 2007
I cannot start up my acer aspire 584g32bn
Safe Mode and System Restore can fix startup issues in an Acer Aspire One, but if the computer won't even load the boot screen, the problem could be related to the basic input/output system (BIOS).
The Acer Aspire One 110 and 150 are two models that can have BIOS-related problems that prevent the computer from booting.
You can upgrade the BIOS through a USB flash drive to repair this issue.
If you are able boot past the startup screen, but can't sign in to Windows, you can use Windows Advanced Boot Options to bypass startup problems.
Go to the Acer website (see Below).
http://us.acer.com/ac/en/US/content/drivers
Click "Support," then select "Download" from the menu on the left.
Select "Netbook" as the product family.
Click "Aspire One" as the product line. Select "AOA110" or "AOA150" as the product model.
Click the "BIOS" tab.
Click the download button and save the file to the desktop.
Go to the desktop when the download completes.
Double-click the file to open it.
Drag-and-drop the folder to the desktop.
Double-click the folder to open its contents in Windows Explorer.
Double-click the "BIOS_Acer_3310_A_AOA110 & AOA150" folder.
Double-click the "Dos_Flash" folder.
Insert a blank USB flash drive into a USB slot.
Drag-and-drop the "3310.fd" and "Flashit.exe" files to the flash drive.
Right-click the "3310.fd" file. Click "Rename."
Change the file name to "zg5ia32.fd" and press "Enter."
Connect the AC adapter to the power jack.
Hold down "Fn" and "Esc" with one hand, then press the power button with the other.
Release the "Fn" and "Esc" keys when the power indicator light comes on.
Wait at least seven minutes for the system to fix the BIOS and repair the Acer Aspire One startup issues.
The computer will restart automatically when the process is complete.
Other Models
Turn on the computer.
Press "F8" before the Windows logo appears to access the Windows Advanced Boot Options menu.
Scroll to Last-Known Good Configuration.
Press "Enter" to load Windows.
If the OS fails to start up, hold down the power button for 10 seconds to turn off the computer.
Press the power button to turn the Acer Aspire One back on. Press "F8," then select "Safe Mode" from the options.
Log in to Safe Mode. Click "Start," "All Programs," "System Tools" and then "System Restore." Click "Next."
Select the last working restore point from the options. Click "Next."
Click "Finish" to run System Restore and recover the Acer Aspire One to a previous state.
Apr 21, 2013 | Acer Aspire 5600 Series 5630-6951 Laptop
My Acer Aspire 5100 laptop won't startup. When I hit the power on button the button light up and stays on. The harddisk light above the keyboard lightup for about 5 seconds and then go off. Notting...
Try starting it up in "Safe Mode" as it is starting up Keep pressing F12 key, I believe it is. Start up in safe mode, if it starts and runs you probably have a virus.
Jan 13, 2011 | Acer Aspire 5100 Notebook
MY LAPTOP DOES NOT BOOT UP IT TAKES SEVERAL TIMES BEFORE IT WILL
windows might be loading too many programs during startup. go to run then enter 'msconfig'. go to startup and uncheck unecessary startup programs then restart your computer.
Dec 03, 2009 | Acer Aspire 5100 Notebook
Keeps rebooting
as the computer is booting tap the "F8 key" continuously until you get the startup menu which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode With Networking " and press your Enter key.
(NOTE) In safe mode Black desktop lager Icons
open your internet and download Malwarebytes run a full scan and remove what is found
http://www.download.com/Malwarebytes-Anti-Malware/3000-8022_4-10804572.html?part=dl-10804572&subj=dl&tag=button
and this is how Malwarebytes works:
http://www.malekal.com/tutorial_MalwareBytes_AntiMalware.php
Jan 31, 2009 | Acer Aspire 5100 Notebook
Startup repair fails to fix the problem
Try reinstalling windows. Insert a the windows cd into the drive and restart your computer, than follow instructions.
Dec 31, 2008 | Acer Aspire 5100 Notebook
PROBLEM WITH ACRE ASPIRE 5100.... DOES NOT BOOT
try to boot into safe mode, to do this restart the pc and as it boots hit F8 repeatedly, this will bring a sub menu up and choose safe mode, when in safe mode perform a system restore and take it back a week or so
I hope this hepls and please don't forget to rate us
Dec 11, 2008 | Acer Aspire 5100 Notebook
My frind hasn't used her laptop for a while and now it has frozen and wants to know how to restart
Try pressing and holding the power button for about 10-15 seconds. This will turn off the laptop. She can then press the power button to turn it back on. If it freezes again then there may be bigger problems.
Hope this helps! : )
Jun 12, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 5100
To prevent the computer from freezing up, make sure you are running nothing else while you are trying to burn the disk. You can also change the programs that are starting up. Hit start, run, type msconfig, go to startup, uncheck everything, restart the computer. Then try to burn the disk. Also you can run CCleaner to repair some of your registry.
Apr 16, 2008 | Acer Aspire 5100 Notebook
Toshiba Satellite A135-S2376, black screen problem
first instinct u cooked sumthing
second try unpluging and removing both batterys ur nicad and the internal lithium 1
this shuld force bios 2 reset
if u cannot locate the internal battery un plug power and batt
w8 aprox 3days the internal clock will drain it 4 u
Apr 05, 2008 | Acer Aspire 5100 Notebook
Acer aspire 5100
look on the front of the lap top for a button fo rthe wireless network and turn it on
Jan 13, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 5100 Notebook Logo
197 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
