Question about Technics SA-DX940
Need technics sa dx940 code to program ATT uverse remote
SOURCE:
SOURCE: Technics SA-DX940
Ratnesh, I have this same receiver and the fan only comes on at certain volume levels. Unfortunately I now live in an apartment and can very rarely listen to it that loud. I had the same problem for a little while until I thought about moving the receiver to the lowest shelf with nothing on top of it. This seems to have worked so far although it does still get quite warm. Good luck!
Posted on Sep 28, 2007
  • 4234 Answers
SOURCE: i need info on a
What info do you need?
Dan
Posted on Aug 19, 2008
SOURCE: EUR647132 code list
http://service.us.panasonic.com/OPERMANPDF/SADX940.PDF
This is a pdf that has everything for the remote and reciever
Posted on Dec 02, 2008
jealhol
  • 3 Answers
SOURCE: SA-DX940 recently stopped recognizing digital formats
Make sure you are using a digital connection, optical or coaxle cables must be connected, setting on receiver must match cable being used
Posted on Apr 14, 2009
jimedington
  • 39 Answers
SOURCE: My technics sa-dx940 receiver runs for about
It's your receiver. The speakers only output, there's no reason a speaker would shut down a receiver.
Posted on Jan 16, 2012
How do I program an AT&T u-verse remote to an ONKYO RC-866M remote
The RC-866M is the remote. What you need to do is add the codes for your Onkyo receiver into the ATT remote. There are 4 or 5 different Uverse remotes, but most can be reprogrammed by pressing the 'Menu' and 'OK' button together. First add your Onkyo codes to the ATT remote as an 'aux' device. After that is working, you can control the power and volume by adding the 'aux' device (Onkyo) to the power and volume buttons on the uverse remote.
These are all the different Onkyo Receiver codes:
Onkyo: 5002, 5018, 5073, 5074, 5075, 5076, 5077, 5078, 5079, 5080, 5081, 5082, 5084, 5085, 5086, 5087, 5130, 5131, 5140
This is how to reprogram the S10 style of Uverse remote:
http://www.att.com/support_media/images/pdf/uverse/standard_black_remote_control_uverse.pdf
Dec 22, 2014 | Onkyo Audio Players & Recorders
I HAVE THE SA-DX940 RECEIVER AND I AM LOOKING FOR THE ORIGINAL REMOTE CONTROL FOR IT IF ANY ONE CAN POINT ME IN THE RIGHT DIRECTION
if you search your make and model of reciever on the internet, you will find several web sites that wish to sell you a remote for your device
Mar 08, 2013 | Technics SA-DX940
I moved and cannot find manuel for sa-dx940 need instruction on how to reconnet wire to t.v. and speaker
The Technics SA-DX940 is made by Panasonic. The manua as a PDF is available here: http://service.us.panasonic.com/OPERMANPDF/SADX940.PDF . The directions for connecting the speakers start on page 14. The connection to the TV is on page 10. To use the SA-DX940 as just external speakers for your TV, connect either the digital audio out from the TV (if it has one) or the RCA audio out from the TV to the matching TV audio in on the SA-DX940.
I hope this helps.
Jun 30, 2011 | Technics SA-DX930 Receiver
I want to buy a Technics SA-DX940 reciever
ebay cheap as chips just keep your eye out for them there always about look for the sa-ax730 aswell more or less the same
Jul 23, 2010 | Technics SA-DX940
Att uverse remote won't work with other devices
Yes you have to use the recommended Uverse codes, and follow the directions to enter the code. Hold the tv button down, on the Uverse remote, then with it stil held down add the OK button, let go of both, then you will see the lights at the top of Uverse remote light up, it is then ready to accept the code, it will be a four digit code, Go to [email protected], and look under TV, then programming the remote is there. Put remote Code in the att search box if you can't find it.
Apr 04, 2009 | Televison & Video
Not able to program vizio remote towork with att uverse Cisco box
Maybe too late for you but ATT just gave me a code that works with my Vizio plasma. Code is 1343. Even the mute works correctly. They gave me some others to try but I didn't need them. Other codes were 1018, 0030 and 0056.
Mar 19, 2009 | Vizio VO47L 47 in. LCD TV
Programing Remote
1343 or 1005 are the codes - press the TV mode button and the OK button together - the release at the same time - the top row of mode buttons needs to blink twice - then enter the code - the TV button should blink 2 times - try the power and volume buttons - if it worked then be sure to press the ATT mode button again after so you can change the channels
Jan 02, 2009 | LG 32LG30 32 in. LCD HDTV
Programing Remote
Most Polaroid flat-screen TVs won't program to the Uverse remotes. Try buying a different universal remote that shows coding for both Uverse and Polaroid.
Apr 19, 2008 | LG 47LC7DF 47 in. LCD HDTV
EUR647132 code list
Oct 21, 2007 | Technics SA-DX940
Technics SA-DX940 Logo
108 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
