SOURCE: Kenmore Elite Heavy Duty King Size Capacity Quiet Pack II Dryer
catriver, Thanks for the advice....the model number is 110.64972300, serial number is MP5012063. Please provide the door hinge P/N and my husband will order and pick up the part. Cutiepie
SOURCE: kenmore agitates doenst spin
There are 3 things that may be wrong.
The timer is keeping the transmission in neutral drain.
The clutch is slipping.
The basket drive block that supports the basket has failed.
Aimiel is correct that you will need to see what is happening during the spin to diagnose the problem. Please post the complete model number from the top under the lid and I will try to walk you through checking it.
Thanks/Mike
SOURCE: I have a Kenmore Heavy Duty, super capacity, quiet
It sounds like your heating element has broken. There are several links provided on this site on how to replace it. You might want to take a look at davesrepair.com to purchase a new one. He has pretty good prices on the element.
SOURCE: We have a Kenmore Ultra Fabric Care Heavy Duty 80
You probably have a faulty heating coil, or thermostats.
If you plan to repair it yourself, remove the back of the machine, locate the air tube going from the blower to the drum. Normally inside of the air tube is where you will find the heating coil, and thermostats.
Check your heating coil with a continuity meter across the two terminals.
Good luck,
I hope this helps
SOURCE: Kenmore elite heavy duty king size quiet pak 1
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question#$^&
