Question about Garmin GPS
Garmin 111 Personal Navigator
I've had this unit for several years now and it's ideal for my boat! But, I'd like to replace the "lithium battery". Where is this battery and what type do I need?
  • Diddly Mar 06, 2008
    How can I replace the lithium mem back up battery? The lithium battery will not hold a charge
    GARMIN GPS 12XL
    THANK YOU
    Dale Peterson
    [email protected]
5 Suggested Answers
SOURCE:
fidoliedo
  • 162 Answers
SOURCE: first time use / battery charge
The Nuvi units are short on battery life and therefore Garmin has given you a connector other then USB to power your unit while in a car. You need to carry that. It's just a design flaw. If you try to rely on the battery of your Garmin Nuvi, you have less than 2 hours even on a full charge. And carrying the USB adapter which plugs into the cigarette lighter socket won't allow your unit to run while charging. so you need to take the adapter charger bracket that comes with the unit if you need it for longer trips.
Posted on Jul 25, 2008
SOURCE: remove and replace the lithium coin batt from a Garmin gpsmap185
The battery is a Panasonic BR2032-1F2; the suffix desinates that it has two flat tabs for soldering into the unit horizontally. Once you remove tha back of the unit, you'll see the battery next to a resistor that's siliconed in place. You'll need to knife the silicone loose so you can gently move the resistor aside to reach the soldered tab underneath it. Just heat the solder on each tab with a small soldering iron until it melts and the tab pops loose.
Install the new battery with the unmarked side up (the other side has type) and solder in place. Reinstall the power and antenna connections in the cover, replace the cover, power up the unit and start re-creating all your lost waypoints.
Batteries can be ordered online from Allied Electronics at $2.42ea (www.alliedelec.com)
blackcatjim
Posted on Jul 20, 2009
Mykel_N
  • 315 Answers
SOURCE: My owner's manual and reference guide was
hi,
This should be the manual your looking for:
Garmin eTrex Legend Manual
This is a pdf file so you will need adobe or foxit to read it, I;m sure that most pc's come with adobe on them though.
I hope that helps..
Mike
Posted on Sep 01, 2009
SOURCE: Replacement of the 10 year lithium back-up battery
Pry it apart along the edge with an exacto. Be careful around the antenna where it is circular.
Get a new battery to match and a battery holder from DigiKey.
Solder wires to the new battery holder and secure it at an angle up by the antenna with white silicone making sure that the case closes. Get the + and - right when you solder.
Test the unit then secure the case with white silicone in a small bead.
Posted on Jul 08, 2010
I left my Garmin 765t GPS in the car over a very cold night and since then the unit doesn't recharge. Please help Thank you Bill
While the rechargeable lithium-ion batteries inside the GPS can operate in a fairly wide temperature range, leaving the battery out in anything less than -10 weather will render the battery inoperable. Unfortunately your battery has probably been exposed to a lower temperature, and therefore will no longer take a charge. You will have to replace the battery. Depending on the retail source that you bought it from you should be able to purchase a replacement unit from them. On a side note, lithium batteries normally have a 3 year lifespan, and you would have to replace after that time-frame.
Thank you for the opportunity to assist you in resolving your issue. Should you need further information or assistance please do not hesitate to let us know.
Feb 17, 2011 | Garmin n?vi 765T Car GPS Receiver
My battery is 2 year's old and is now only lasting 30 minutes after fully re-charging.
Two years is actually pretty good for a rechargeable battery in regular/constant use.
Lithium-ion rechargeable batteries have around 500 recharge cycles and then will loose capacity very quickly as for your unit.
This internal Li-Ion battery will now need to be replaced.
Hope it helps.
Sep 27, 2010 | Garmin Forerunner 205 GPS Receiver
Replace battery on a nuvi 360
Please see this link. Please don't try to do it yourself. You risk damaging your unit.
http://www.sharc.net/gps_battery_repair.htm
- Jim
Sep 22, 2010 | Garmin Nuvi 360 Bilingual GPS Navigator...
The internal battery is dead. How do I replace the the old battery with a new one. Please explain how to open the battery compartment and how to install a new lithium-ion battery.
The internal battery, that only Garmin can change. It would cost $125 just to send the unit in if it needed work outside of the warranty period.....hopefully the battery will last about five years.If you get it replaced from Garmin. If still you want to void the warranty and get it opened then there is step by step images shown how to open the unit.But that actually damages the unit. Click this link directly:--- There are total 26 images showing step by step procedure.Click on each image and continue disassembly. http://content.techrepublic.com.com/2346-22_11-178052-6.html?tag=content;leftCol ---------------- Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Aug 10, 2010 | Garmin StreetPilot C330 GPS Receiver
How do you open the garmin nuvi 360 to replace the battery
Please don't try this yourslef. You risk damaging the unit. Please see this link for more info:
- Jim
Oct 25, 2009 | Garmin Nuvi 360 Bilingual GPS Navigator...
I cannot turn off my garmin nuvi 360 it has a white screen
If it was in the middle of a firmware update, you may need the help of Garmin as it will have crashed.
Use your desktop Garmin software and usb lead to try and recover it.
Feb 10, 2018 | Garmin Nuvi 360 Bilingual GPS Navigator...
Battery replacement now ca't find satellite Garmin c320
I had the same issue with the only difference that I haven't replaced the battery yet. When my unit can't locate or acquire satellites I change between GPS and WAAS mode. Within 45 seconds my unit successfully locates satellite. After some time if I disconnect unit I might have to switch it back to GPS and so on, and so on, and so on. It worked for me for past 3 months... Hope it will help you...
Nov 12, 2008 | Garmin Nuvi 360 Bilingual GPS Navigator...
I get a 'battery missing' indication on my Garmin 478. The battery is in place, I'm on 120v external power and the battery does not indicate that it is cahrging. I have a Log Entry - battery low...
Although the WebUpdater should always be the first stop, the instructions do state that you need to have full charge to ensure you don't "brick" the unit.
I've had the unit about 3 years. I already replaced one battery for this issue. I got the new battery, charged it up, and was happy. Several months later I tried to charge it up again, and got the same "Battery Missing" message. It can't be the battery!
I think it's when the battery is COMPLETELY discharged the battery can't be properly detected. You have 2 choices:
1-Leave the unit on the charger for several hours. It may trickle in enough power to recognize the battery eventually.
2-The other option is NOT AUTHORIZED by Garmin, and you do it at your own risk! Find a 12v car charger you don't need. Expose the wires if necessary. Tape the positive to the contact on the far right of the battery, the negative to the middle, and nothing to the left (that's a data connection). Plug the 12v car charger in, and let it sit for a few minutes, not long or the battery could overheat.
I left it on for under 10 minutes. When I inserted the battery back in the unit, it recognized the battery immediately and happily charged the battery.
Long term, this is probably not an ideal solution. The voltages might not match, there are computer chips in the battery that are designed to receive power the "Garmin" way, and you could severely damage the battery (even explode?).
But if it's this or trashing a $700 unit, it might be worth a try.
Sep 27, 2008 | Garmin GPS
Unit fails to maintain charge
You are correct, most GPS units use a lithium ion rechargable battery, typically they loose there ability to retain a charge after about a year or so depending on use, resulting in the unit having to be always plugged in.
You probably could replace the battery on your own if you could get one, (needs to be soldered into the mainboard) however GARMIN does not sell battery's to consumers, they state that a battery can only be replaced by a garmin service tech.
Check the link below for contact info for garmin.
https://buy.garmin.com/shop/shop.do?pID=290&tab=sp340
Hope this helps
http://pchelpforanyone.blogspot.com
Mar 07, 2008 | Garmin StreetPilot c340 GPS Receiver
GPS Logo
199 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
