ITunes Skips Like Crazy
Just about any activity on my computer will cause iTunes to skip. I have a AMD64 4000 with a sound blaster X-FI and a ASUS A8R-MVP motherboard (built on ATI Crossfire). Quicktime is set for 44kHz, 24 bit (to match the X-FI), stereo. Safe mode is turned off. Device latency set to 33ms. I have the latest drivers for the X-FI and iTunes 7.4.2.4. Any ideas how to fix iTunes?
  • 4 more comments
  • Anonymous Sep 30, 2007
    ***My Settings___________________________
    K-Lite Codec Pack also installed but Quicktime Alternative is not installed.
    ***I tried with NO success________________
    - Setting Quicktime to 8 bit, 16 bit, and to Safe Mode(wave only).
    - Reinstalling Quicktime and iTunes.
    - A remedy I found on Digg that involves setting iTunes to max volume.
    Does someone know how to stop iTunes from skipping?
  • Anonymous Oct 01, 2007
    These are good comments.
    1. Have you defragged your drive lately?
    > Fragmentation is nominal.
    2. Do you think you have sufficient memory?
    >Yes, I have 2GB of RAM and am only using 740MB.
    3. Are there any other programs running (that may be processor/memory hungry)?
    > Doesn?t seem to be the issue. Just opening Firefox causes a skip.
    4. Are you running any anti-virus software and at what level of detection in real-time?
    > Yes, I am using NOD32. Turning off NOD32 does not solve the problem.
    5. Is your video set-up as good as your audio set-up?
    > Yes, I have an Nvidia 7600GT (pci-e) with the latest drivers.
    6. Have you tried setting your swap file bigger say double your RAM?
    > The swap file is turned off.
    7. By any chance are you running an overclocked FSB?
    > The FSB is not overclocked.
    8. Have you tried configuring your CMOS/BIOS to default or fail-safe settings?
    > Just updated the BIOS and am using safe settings. Also hardware-disabled the on-board audio.
    9. Do you think you have sufficient power from your PSU?
    > The PSU seems to be sufficient; it is a high efficiency CoolMax 450W PSU. The voltages are almost constant through operation.
    >>>> Hardware disabling the on-board audio seems to have helped a little.
    However, I found a work-around. Setting the process priority for iTunes to above normal seems to stop the skipping. This shouldn't be necessary and means that something is still broken, but it seems to work.
  • Anonymous Oct 02, 2007
    OK, my mistake I actually have a paging file on this machine (I was thinking of a different machine). The page is set to 5GB and sits on its own partition at the front of the disk. Also memory is optimized for programs.
    --- Your "...Setting the process priority for iTunes to above normal..stop the skipping..." is indicative that the CPU is doing something else ---
    >> Right. Generally the CPU load is very low around the time the skip happens. The event that takes time away from iTunes is the operating systems hitting the disk when it loads a new application, such as firefox or explorer. Window Media Player an Winamp aren't skipping so I am wondering if there is an iTunes playback buffer I can increase or something along those lines.
    Best,
    Toaster
    "Generally the CPU load is very low around the time the skip happens."
    >> I should have written "Generally cpu usage is very low. Around the time the skips happen the CPU usage jumps to around 80% on what ever application is being used.
    I noticed that there are a bunch of forum postings too. I have tried some of the solutions on the forums with no success.
    The problem isn't actually fixed but your input helped me find a work around. I imagine the problem is deep in iTunes or the OS.
    Brigadier General:
  • 6,966 Answers
Hi, I will assume that you have tried various settings with your iTune profile and soundcard settings, might it be that you will have to look elsewhere and probably start with the basics. Basically iTunes is a player and to play something, it has to read it from somewhere which i would presume is from your harddrive or another mass storage. Following this path, it has to be processed and temporarily stored somewhere before iTune come picking it up bit by bit and play. With that in mind, probably a few things you can check/try: 1. Have you defragged your drive lately? 2. Do you think you have sufficient memory? 3. Are there any other programs running (that may be processor/memory hungry)? 4. Are you running any anti-virus software and at what level of detection in real-time? 5. Is your video set-up as good as your audio set-up? 6. Have you tried setting your swap file bigger say double your RAM? 7. By any chance are you running an overclocked FSB? 8. Have you tried configuring your CMOS/BIOS to default or fail-safe settings? 9. Do you think you have sufficient power from your PSU? Hope this be of additional idea to you. Pls post back with how things turned up. Good luck and kind regards.
Posted on Oct 01, 2007
  • 1 more comment
  • Louie  Role
    Louie Role Oct 02, 2007
    Hi again,
    "The swap file is turned off." - pls try setting to 2Gb. In your System Properties, Setting, Advanced, Virtual Memory - Change, Custom Size, enter 2048 on both Initial & Maximum, Set, OK. Pls verify also that you are set to Programs preference for Memory usage rather than Systems Cache. This has solved a lot of my problems with video editing.
    Your "...Setting the process priority for iTunes to above normal..stop the skipping..." is indicative that the CPU is doing something else other than the iTune. To be able to determine just exactly what the "something", with no programs running other than iTune, pls Ctrl+Alt+Del, check your Performance tab, pls note your CPU Usage and your PF Usage, on the Process tab, note which program is using the biggest CPU share. Clicking on the Applications tab will also show you other displayed propgrams running.
    Cheers.
  • Louie  Role
    I did a Google of your problem and it would seem from various forums and posting that you are not alone in your problem (one way or the other) but one thing that strikes me is that it happens more often with AMD processor machines.
    You did mention another PC(I was thinking of a different machine), hopefully Intel based CPU, are you having the same issue with that machine?
  • Louie  Role
    Apple has released Version 7.4.3 of iTunes. The changes include bug fixes.
SOURCE:
I need itunes to work awesome on my computer
We are unable to find iTunes on your computer. ... Work Awesome is the podcast adjunct to the Work Awesome website. ... On this episode of the Work Awesome podcast, outgoing Podcast Prodigy Mike Vardy chats with a man .... I don't want to sound like I'm nagging but I do want to be able to listen and enjoy the podcas.
http://www.mbzparts.com/
Mar 09, 2013 | Apple iPod MA446LL/A MP3 Player
My sound skips around alot to a point where you cant hear much
well the sound skips only in one condition when there is not enough memory.if you have good ram then your computer requires a proper servicing.
Jul 08, 2009 | Acer Aspire One Netbook 8.9" Notebook
Itunes skips during music playback
Boot to safemode and see if it does the same thing.
Oct 16, 2017 | Apple iTunes
Sound Is Skipping
Have you installed anything else on your pc
is this xp
Jan 16, 2009 | Dell Dimension 8400 PC Desktop
Songs skipping!!!
my phone sound is low please ask what possible to sound are hi
Apr 05, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Creative sound blaster x-fi xtreme audio
Windows closing slow means you have a bunch of program that are running in the back ground. Windows has to close each before the system can shut down. To see just what is running in the back ground. Allow windows to completly finish opening. Click the start button, click run. In the window type, msconfig & click ok. System Configuration Utility window will open. Click on the Startup tab. Now you can see just what programs are running in the back ground.
Adding memory can also help speed up a slow pc & keeping the system clean by using the two programs listed next.
First. Run disk cleanup, a windows program found in system tools. Than run Defrag also found in system tools. Restart the pc when finished. This should help your system to run a bit better.
If you have the CD that came with the sound card uninstall the software through Add/ Remove programs found in the control panel. Restart the pc. Reinstall the drivers from the CD & try opening a few programs. Open & run the program your using to play music. Any better? If not try using another music program like iTunes a free download found here. http://www.apple.com/itunes/
You can also try the drivers from creative they may be newer than your CD here: http://us.creative.com/support/downloads/welcome.asp?action=next
Enjoy!
Please vote...
map9966
Jan 29, 2008 | Creative Labs Sound Blaster Live! 5.1...
Recording audio on hard drive for books, etc.
Probably too high a setting in record for your computer. Try setting the quality down a little and see if it helps.
Nov 19, 2007 | Creative Labs Sound Blaster Live! 5.1...
Soundcard
This Sound Blaster X-Fi Vista Installation CD is intended to support X-Fi products bought before a Vista installation CD was available in the box.
It supports the following models:
  • SB X-Fi Xtreme Music (SB0460)
  • SB X-Fi Xtreme Gamer (SB0730/SB073A)
  • SB X-Fi Xtreme Gamer - Fatal1ty Professional Series (SB046A)
  • SB X-Fi Fatal1ty FPS (SB0466/SB0256)
  • SB X-Fi Platinum (SB0460/SB0251)
  • SB X-Fi Platinum Fatal1ty Champion Series (SB046A/SB0256)
  • SB X-Fi Elite Pro (SB0550/SB0510, SB055A/SB0510) This CD does not support the Sound Blaster X-Fi Xtreme Audio range (SB0790/SB0792).
This Sound Blaster X-Fi Vista Installation CD includes a full suite of drivers and applications:
  • X-Fi Mode Consoles (Gaming/Entertainment/Audio Creation)
  • Creative Mode Switcher
  • Creative Audio Console
  • THX Console
  • Creative MediaSource 5
  • Creative Smart Recorder 2
  • Creative WaveStudio
  • SoundFont Bank Manager
  • Creative 3DMIDI Player
  • Creative Diagnostics
  • Creative Entertainment Center
For more information on how to obtain a copy of Sound Blaster X-Fi Vista Installation CD, please refer to our regional sites at www.europe.creative.com or us.creative.com.
Windows XP applications do not work with Windows Vista. When launched, it will display a message "The audio device supported by this application is not detected. The application will exit" even though your Sound Blaster card is working properly.
If you have installed any Windows XP applications for your Sound Blaster X-Fi card, it is recommended that you uninstall these (Windows XP) applications before installing the Sound Blaster X-Fi Vista Installation CD. To uninstall, go to Control Panel, and select Programs and Features, and then choose the applications that you need to uninstall.
Nov 18, 2007 | Biostar P4TPT - Motherboard
Sony handicam trv skips playback like in slow motion?
you need a computer with at least 1.5 ghz and 1 gig of ram anything less will cause recording to pc problems
Oct 26, 2007 | Sony Handycam DCR-TRV280 Digital Camcorder
Open Questions:
Computers & Internet Logo
317 people viewed this question
Ekse
Alun Cox
