Question about Sony KP-65WS500 65" Rear Projection Television
Double screen image
I have a sony KP65WS500 TV. All of a sudden there is a double image and a fuzzy hazy picture. Tried the focus button without much difference. It was repaired in the past for a bad red lamp. Another part was also replaced at the same time that had to do with focusing the image (name I can't recall). What do you think is going on?
  • doshaffer May 09, 2009
    Are the convergence IC's on a Sony KP65WS500 soldered or just plug in?
  • 10,594 Answers
Double image shows that TV got problem of Convergence Out ICs failure and will be replaced two ICs mounted at D Board of TV.
ICs, STK392-360 are available in Part Store, click to see an image and price info.
Posted on Apr 27, 2009
SOURCE:
I have a 43" Sony KP-FX432M91 projection TV. It is showing a double picture hence the picture is hazy. What can be done to sort it out ?
One of the selections in the TV setup menu has a selection called convergence. Under that selection chose digital quick focus and it should automatically align your colors. If that doesn't work there is also a selection that lets you align them manually.
Jun 11, 2016 | Sony Televison & Video
I'm getting a double image of everything on the screen in a hazy blue colour. I tried configuring the colour within the menu but the cross simply won't line up. touch focus seems to work with the...
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Aug 11, 2011 | Toshiba 57H81 57" Rear Projection...
Mitsubishi WS-55511 convergence problem?
No,need to diagnose.It a 100% convergence problems.Convergence problems very easy diagnose.The picture look like 3D,colors lines don't lines up.Fuzzy,out of focus.Convergence controls don't work to lines up any colors cross.The tech is cheating u if he said cost $125 to diagnose.If u know how to solders u could fix this convergence problems about $100.U can buy a convergence kit at Websites Tv repair World.com,Tvrepairkits.com.The shop everythings fix parts and labors only $300.
Mar 16, 2010 | Mitsubishi WS-55511 55" Rear Projection...
My rca projection tv has blue and green images like a 3D picture would without your 3D glasses, a double vision image and no other colors
sounds like the sensors are out of focus and your red sensor isnt turning on. look in the back of the tv for a master reset button or in your menu screen some sort of "Flash focus" or "convergence". They will realign the 3 sensors.
Dec 27, 2009 | RCA HD52W56 52" Rear Projection HDTV
The screen is showing a ghost or double picture
Does the picture look 3d? colors out of place and or skewed?
If it does, go into the customer menu with the Sony remote and select convergence----if red or blue are warped and will not move in some direction--you have a common problem---CONVERGENCE.
Confirm model number and tell me if it is 3D like picture.
I can if it is tell you what is needed to fix it--I am here to help people and I do this here for free.
Regards, SD TECH
Oct 30, 2009 | Televison & Video
POOR PICTURE QUALITY
The convergance IC's need to be replaced along with possibly a pico fuse in the same circuit.Theres a large heat sink with two IC's starts with a STK number,replace them and that should take care of it.
Apr 29, 2009 | Televison & Video
SONY rear projection TV KP61HS10 picture blurry, hazy
Issue is with main tuner since you have two of them. At least the tv is ok but that tuner is fubar.
Sep 07, 2017 | Sony KP-61HS10 61" Rear Projection...
36'' Admiral fuzzy picture model GOJ 12390
you'll have to take the back off the tv and on your right you'll see two black button on the flyback transformer one over the other the other the top button is for the focus you can bright or darken the image on your screen don't be afraid it will not bite as long as you don't touch nothing but the button with a phillips screwdriver and don't have the kids around when you are doing it
Jan 15, 2009 | Televison & Video
Like seeing double!
You need to replace both convergence ICs they are STK392-110. You can get replacement Ics with free instalation instructions with pictures at the following link
http://servicemanuals.vstore.ca/
Jul 14, 2008 | Toshiba 42H81 42" Rear Projection...
Picture focus problems
make sure there is no flower icon on bottom left corner of screen-very common on sony to hit macro button to turn on by accident and you will get blur-only for extreme closeup-hit flower button to turn off if on and let me know if that was the problem
May 17, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Sony KP-65WS500 65" Rear Projection Television Logo
369 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
