Hotpoint Ultima Extra WMA66
Whenever I switch the machine on is causes a power failure in the house. There are no signs of burning or damage to any of the electricals but as soon as you start a programme it will short the house fuse within seconds. Any ideas? Tks
  • Anonymous Nov 02, 2007
    As above. Blows trip in house. Engineers thought heater.... no.......thought motor brushes..... no... Motor armature at fault. needs whole new motor. not good on a low regular use three year machine! Is it worth fixing or replacing the whole machine?
    similar problem on WMA74 , finally solved, needs new motor, but is this cost effective?
  • 209 Answers
Something is shorting out direct, remove plug from power supply and test each item, element / pump / main motor etc for down to earth, replace the affected item
Posted on Oct 02, 2007
Want to select drying only on a hotpoint ultima dishwasher it has symbols only
the hotpoint ultima fdud4812 is not equiped to select drying only only option is the extra dry button
Nov 23, 2011 | Hotpoint Washing Machines
Hotpoint ultima extra washing machine, door open sign flashing on lacd display even though the door is closed properly
first check all connections on circuit board are tight if ok change interlock,if problem still persists you have a circuit board fault which could have been caused by blown interlock
Sep 08, 2011 | Hotpoint Washing Machines
Fault F 02
F02 is listed as a motor
jammed or tacho failure.
Check that the motor is not siezed or damaged. Try turning the drum by hand. Does it turn easily and freely? Are there any strange noises from the motor area?
Check for broken wires from the motor plug to the main control board.
Check the main control board for signs of damage or burning.
Check that all plugs are firmly seated on the control board and into the motor.
If there's nothing obviously wrong I'd check the carbon brushes in the motor.
After that, if it's all checked out ok, time for the engineer.
As it could be costly on parts, ie. possibly a motor and a main pcb.
Apr 06, 2010 | Hotpoint Ultima WF860 Front Load Washer
E15 code on display of Hotpoint ultima extra WD72.
E15 means that it is not draining fast enough. As well as checking the outlet pipes, check the filter leading to the pump. Disconnect the power and pipe. If possible take outside because there will be a residual amount of water. Remove the back panel, then disconnect the locking rings holding the tubes on. Your main target should be the big downflow rubber tube from the drum, in here is a plastic filter. In mine I found a child's sock... plus slime. Problem solved.
Dec 20, 2009 | Hotpoint Washing Machines
Need wiring diagram to conect pcb to a hotpoint ultima extra wma66 for manuals on WM & WMA machines including wiring connection charts
Feb 19, 2009 | Hotpoint Ultima WF860 Front Load Washer
WMA66 Noise
Could you describe the noise plz?
Feb 16, 2009 | Hotpoint Ultima WF860 Front Load Washer
Knocking noise on spin cycle
My machine did the same thing, I found it to be the heater element in the air box had come loose inside the casing and was hitting the sides of the air box. Removed air box from machine and resecured the element now all ok
Apr 10, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima wma66
Sounds like the PCB is Freaking out. All you can do is Check all the connections between the Main board and Display board and if you still have the problem - then i'm afraid it is probably the Main Board gone Faulty.
Mar 14, 2008 | Washing Machines
may be the pressure switch, or the rubber tube up to the pressure switch blocked
Oct 21, 2007 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima extra WD72
There are 3 possibilities 1 altough the water as drianed the pressure switch as not released due to blocake in the filter, or the interlock has jammed on the closed position which means it will have to forced open or the last fault could be the power board has gone.
Feb 28, 2007 | Hotpoint Ultima WD72 Front Load...
Washing Machines Logo
177 people viewed this question
Top Washing Machines Experts
