Question about MSI : 661FM-L P4 SIS661FX FSB800 Motherboard (MOT34)
Computer freezes during startup
Computer turns on fine, but on the screen where it tells you to press delete to enter setup, it just stops. There are no warning beeps and won't let me enter setup. I'm not sure if it's disabling the keyboard or not but all the lights(eg., Caps Lock light) turn off when it gets to that screen. Memory seems fine, I get the appropriate warning beeps if i remove the ram, i've tried two power supplies as well. I have removed all hard drives minus one and it has the correct jumper setting. I am kind of out of ideas at this stage. Help would be appreciated.
  • 1 more comment
  • Ticketmanbob Sep 30, 2007
    Haha awesome, that did the trick. I just pulled out the hard drive and the wireless card and it started working again. Reconnected everything and it all worked like normal.
    Thanks.
  • Anonymous Dec 08, 2007
    I HAVE THE SAME PROBLEM, LOADS THE NNEDS FILE FOR INSTALL.THEN WHEN IT READS WINDOW START IF TURNS OFF FOR A SPLIT SECOND AND A BLUE SCREEN WARNING THAT IT HAS BEEN STOPPED TO AVIOD DAMAGE THE COMPUTER.ALSO READS MAKE SURE IT HAS ENOUGH DISK SPACE ( I SWITCHED HARD DRIVES TWICE) AND CONTACT VENDOR FOR BIOS UPDATE OR START SAFE MODE DISABLE BIO MEMEORY.I STRIPDED THE CU AS MUCH AS POSSIBLE AND RESETED THE CMOS BUT STIIL WILL NOT ALLOW THE OS TO BE INSTALLED.
    HELP
  • lilsteve00 May 05, 2009
    Hi ya!
    well i just had the same problem, turn on, get to the bios screen and.... dead just froze, i' reading the other comments and i'm really no whiz at this stuff i was really starting to think oh no your telling me to do what?? i'm thinking i'm gonna break my pc (if not already broke). NOW reading on its mentioned that add on's may be the key so i unplugged and usb memory stick i left plugged in (which i have to say has been there for wks, may be faulty) then reset the pc and bobs ya uncle fannys ya aunty it worked!!
    so have a look for plug in's/add on's to your pc simple but daft i dont really know the reason why but hope it may help some one else out there!!
    all the best!
I need solution of computer with blue screen on startup.
Posted on Jan 28, 2009
    Brigadier General:
  • 6,966 Answers
Hi, This is typical when the motherboard (CMOS/BIOS) is having a difficult time auto detecting the devices installed including drives, videocard, sound card, network, etc. Initially set your CMOS/BIOS to default/fail-safe settings, save & exit. Perhaps you can try running with the barest of add-on devices as you have posted initially, but do it one step further, remove everything including that one last HD (with the correct jumper settings). If you have onboard video use that one rather than an AGP or PCI-E add-on. Run the unit with just a single memory. No cables other than power and front panel. Thereafter connect your devices one by one and try every time a new one is added. This include removing any USB devices/cables plugged in. More often it is an add-on that causes freezing at this point as you have described. You may also venture in trying to flash your BIOS (however pls be forewarned of possible difficulty/failure when doing so). Hope this be of some help/idea. post back how things turned up or should you need further information. Good luck and kind regards.
Posted on Sep 30, 2007
  • Louie  Role
    Louie Role Sep 30, 2007
    Hi again,
    Alternately if your PC is a desktop, you can reset the CMOS/BIOS to default by temporarily relocating the jumper on the CMOS reset pins quite often very near the 3 volts Lithium backup battery.
    Cheers.
I syncronised my desktop how to stop it
syncronised it with what ??
Restart your computer
During the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
this will vary depending on your computer and operating system usually the Delete or the F2 key
Press and hold that key during the boot up process to enter BIOS using the arrow keys to navigate load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart.
Mar 13, 2014 | Lenovo Computers & Internet
Delete freeze
Depress the power button for a few seconds till the computer turns off. Wait a few seconds and restart.
Where does it freeze, during startup, or once within Windows? If you make it somewhere into the Windows operating system, restart, and during startup, peck on F8 key till you get to the B/W Startup options. Cursor down to "Safe Mode with Networking", and press the Enter key. If it makes it to Safe Mode, use "System Restore" (SR) to back up to a date before the problem occurred. If SR isn't available, or doesn't work, enter Safe Mode again, use your IE, Firefox, Google Chrome, or Opera browser to go to www.download.com. In the right-hand column of Most Popular Downloads, you'll find Malwarebytes. Download and run that program to see if the problem came from a malware infection. Follow the instructions to scan, and afterwards to remove the infections, then restart the computer.
Oct 31, 2013 | Computers & Internet
Siig sc-sat212-s4, stops boot when connected
While most computers are capable of starting up properly with external drives connected, from time to time the external drive can cause confusion during the startup process. The computer may attempt to boot from the external hard drive rather than the primary internal drive. This causes the computer to fail during startup because the external hard drive does not have the operating system installed on it.
Disconnect the external hard drive from the computer. In order to minimize the risk of damage to or loss of files on the external drive, shut down the computer if possible, or hold down the power button on the computer until the computer turns off and then disconnect the external hard drive. Restart the computer with the drive disconnected. If the computer still does not start up, it is possible that the computer is attempting to boot from the external drive. Reconnect the external drive and restart the computer. Watch the screen as the computer boots up. A prompt will appear indicating which key to press to enter "Setup" or the "BIOS." Press this key when the prompt appears. On many computers the key is either Delete ,F2 or F10. Use the keyboard of the computer to navigate the "Setup menu" that appears. (Advanced Bios Features.) The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ? or using the arrow keys you can load failsafe or optimized defaults this will set the boot order. Highlight the option for "Boot Disk" or "Startup disk" and select the "C:/" or the primary internal hard drive. Press the associated key, labeled so on the bottom of the screen, to save the changes and restart the computer. This will allow the computer to boot from the appropriate drive. Hope it helps.
b>
Jan 23, 2013 | SIIG Scsat212s4 Pci Serial Ata 2 Channel...
It wont start
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
hope this helps
Aug 02, 2012 | E-Machines eMachines Desktop PC
Screen keeps auto adjusting, cant make it stop
During the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
hope this helps
Jun 04, 2011 | Computers & Internet
Hi, i have a Sony vaio and it was working fine until I shut it down overnight, the next morning I tried to turn it on which started out fine but as soon as the windows emblem started loading, it didn't...
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
or
During the boot process tap the f8 button three times this will boot into safe mode where the only things working will be your mouse and keyboard enabling you to attempt to repair your computer
Also you might try
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer)
hope this helps
May 01, 2011 | Sony Computers & Internet
How can i enter BIOS set up pf Compaq Armada M700
Usually the delete key or F2 will do the trick
Mar 09, 2011 | HP Compaq Armada M700 Notebook
Hi, i want to set up cd drive on first boot. How do i can access to setup?
If I don't know what computer you have It makes helping you more difficult.
Here are some options for different computers:
  • Turn on the computer, immediately hit the F2 button. - Most computers with Phoenix BIOS.
  • Turn on the computer, during POST hit the Delete button - Most computers with AMI BIOS
  • Turn on the computer, hit Ctrl+Alt+F3, Ctrl+Alt+Ins, or Fn+F1 - Older Lenovo.
  • Turn on the computer, immediately hit the F10 button. - Some Dell computers.
  • Turn on the computer, hit Fn+Esc or Fn+F1. Older Dell laptops.
If you tell me exactly what you have, I'll tell you exactly what to do ;)
Jan 28, 2011 | Computers & Internet
I have a gateway gx7022e windows xp computer. When i try to boot it up the white letters pop up then the screen goes to the gateway screen and freezes. Then my num lock comes on but my keyboard wont work....
At power on / power up, look for the key during the bootup (black screen with white text), that allows you to enter SETUP. If none designated such as F1, F2 F10 etc, then quickly click the delete button a few times and that may get you into setup. You may have to turn off the computer if you miss that window of time if it rfequires pressing the delete button a few times. Keep an eye out for the Enter Setup key though. To turn off the computer press and hold the power button 'till is shuts down and resart the process until you get to the setup screen in bios. In setup bios environment, look for set factory defaults and then save and restart. That may solve the issue of the lockup.
Jan 10, 2011 | Gateway GX7022E (RBGX7022E) PC Desktop
Seagate Barracuda 7200.7 ST380011A 80 GB stop working, it would not work properly, keeps freeze up
Press and hold delete during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart then
once you have your computer running try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/r/f which will scan for and attempt to fix any bad sectors and automatically fix any corrupt files on your hard drive then defragment your hard drive
hope this helps
Nov 28, 2010 | Seagate Barracuda 7200.7 ST380011A 80 GB...
MSI : 661FM-L P4 SIS661FX FSB800 Motherboard (MOT34) Logo
176 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
