Question about Microsoft Office Standard for PC
Microsoft Access I want to sort my report by month from a given date field.Thank you.
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 359 Answers
Create a hidden calculated field to extract the month from the date and use that for sorting and/or grouping. You should be able to group on the month as well, if that is the primary purpose. Thanks for rating FixYa!
Posted on May 05, 2008
SOURCE:
When using excel how to get dates to automaticly update in order
Sort the data to represent descending order for a chronological data set. If your information is listed in a table format in multiple columns, make sure you select all of the data and sort on the date field.
Feb 16, 2014 | Microsoft Excel Computers & Internet
Hi, Need to create multiple running auto numbers in one table in one field, can anyone help?, am using access2000.
you can add page #'s in reports, insert, page #
you can't add auto #'s in the table without just adding the # in one field for each one
Access is a database program, the report option is where the page or file # is entered
I hope this helps
Apr 08, 2009 | Microsoft Access 2000 Step by Step...
How to get 1 value from report to another form in ms access
You'll have to use a separate Group By query to get the summed data you are looking for, you cannot pull it off the report.
Feb 06, 2009 | Microsoft Computers & Internet
Storage of MS-Access 2007
(please refer for www.office.microsoft.com for further information)
Database specifications Attribute Maximum Access database (.accdb) file size 2 gigabytes, minus the space needed for system objects Note NOTE: Although the maximum size for a single database file is 2GB, you can work around this limitation by using a split database. A front-end database file can point to thousands of back-end database files, each of which could be as large as 2GB. For more information, see the topic, Split a database.
Number of objects in a database 32,768 Number of modules (including forms and reports that have the HasModule property set to True) 1,000 Number of characters in an object name 64 Number of characters in a password 20 Number of characters in a user name or group name 20 Number of concurrent users 255 Table Attribute Maximum Number of characters in a table name 64 Number of characters in a field name 64 Number of fields in a table 255 Number of open tables 2048; the actual number might be smaller because of tables opened internally by Access Table size 2 gigabyte minus the space needed for the system objects Number of characters in a Text field 255 Number of characters in a Memo field 65,535 when entering data through the user interface;
2 gigabytes of character storage when entering data programmatically Size of an OLE Object field 1 gigabyte Number of indexes in a table 32 Number of fields in an index 10 Number of characters in a validation message 255 Number of characters in a validation rule 2,048 Number of characters in a table or field description 255 Number of characters in a record (excluding Memo and OLE Object fields) when the UnicodeCompression property of the fields is set to Yes 4,000 Number of characters in a field property setting 255 Query Attribute Maximum Number of enforced relationships 32 per table, minus the number of indexes that are on the table for fields or combinations of fields that are not involved in relationships* Number of tables in a query 32* Number of joins in a query 16* Number of fields in a recordset 255 Recordset size 1 gigabyte Sort limit 255 characters in one or more fields Number of levels of nested queries 50* Number of characters in a cell in the query design grid 1,024 Number of characters for a parameter in a parameter query 255 Number of AND operators in a WHERE or HAVING clause 99* Number of characters in an SQL statement Approximately 64,000* *Maximum values might be lower if the query includes multivalued lookup fields.
Form and report Attribute Maximum Number of characters in a label 2,048 Number of characters in a text box 65,535 Form or report width 22 in. (55.87 cm) Section height 22 in. (55.87 cm) Height of all sections plus section headers (in Design view) 200 in. (508 cm) Number of levels of nested forms or reports 7 Number of fields or expressions that you can sort or group on in a report 10 Number of headers and footers in a report 1 report header/footer;
1 page header/footer;
10 group headers/footers Number of printed pages in a report 65,536 Number of controls and sections that you can add over the lifetime of the form or report 754 Number of characters in an SQL statement that serves as the Recordsource or Rowsource property of a form, report, or control (both .accdb and .adp) 32,750 Macro Attribute Maximum Number of actions in a macro 999 Number of characters in a condition 255 Number of characters in a comment 255 Number of characters in an action argument 255 default.aspx?assetid=za100776681033 Top of Page
Project specifications The following list of tables is specific to Office Access 2007 projects:
General Attribute Maximum Number of objects in an Access project (.adp) 32,768 Number of modules (including forms and reports that have the HasModule property set to True) 1,000 Number of characters in an object name 64 Number of columns in a table 250 (Microsoft SQL Server 6.5) 1024 (Microsoft SQL Server 7.0, 2000 and 2005)
Microsoft SQL Server database Microsoft SQL Server maximum capacity specifications are described in the SQL Server documentation. Form and report Attribute Maximum Number of characters in a label 2,048 Number of characters in a text box 65,535 Form or report width 22 in. (55.87 cm) Section height 22 in. (55.87 cm) Height of all sections plus section headers (in Design view) 200 in. (508 cm) Number of levels of nested forms or reports 7 Number of fields or expressions that you can sort or group on in a report 10 Number of headers and footers in a report 1 report header/footer;
10 group headers/footers Number of printed pages in a report 65,536 Number of controls and sections you can add over the lifetime of the form or report 754 Number of characters in an SQL statement that serves as the Recordsource or Rowsource property of a form, report, or control (both .accdb and .adp) 32,750 Macro Attribute Maximum Number of actions in a macro 999 Number of characters in a condition 255 Number of characters in a comment 255 Number of characters in an action argument 255
Zulfikar Ali
Jan 16, 2009 | Microsoft Computers & Internet
Conditional Formatting doesn't work until I select the item
the mouser is equip with shortcut of any of program by using right click pointing to item.
Oct 15, 2008 | Microsoft Office Professional 2007 Full...
GPS 38 unable to access date and time in system setup. presently shows 1 jan 05
Hi John921,
Here is the step by step procedure to set date and time of your Garmin GPS 38......
It will definitely work......
Set Local Date and Time
1) Verify the date and local time (this should be
the date and time according to the local date and
time of country/area you are in). Because the
time shows is Universal Time (UTC), you will
need to enter a time offset to display the correct
local time for your area.
2) Move the field highlight to the OFFSET field
and press Enter
3) With the arrows (←→), go to the figure which
represents the hours then with the up & down
arrows (↑↓), select the time offset for your
longitude and press .
4) Move the field highlight to the HOURS field
and change to 24 if that is not already the case.
This will definitely work......
Please rate this solution............
Thanks......
Sep 08, 2008 | Garmin GPS
Sort incoming time for received e-mails
Depending on what client you are using, clicking on the "triangle" in the date column toggles between sorting ascending and descending.
MM85
Jul 22, 2008 | Microsoft Office Outlook 2003 for PC
Creating Running Sum with Grouping Query
Looks like your GROUP BY subclause says to group by Force_no but also the yyyy and m datepart values for Subs_Dt as separate items. [Also since you are returning "Force_no AS FN", you need to refer to it as 'FN' and not 'Force_no' in the other subclauses of the statement. Same is true for your partial-date references as well in the SELECT subclause] So the query will return the grouping not by Force_no (should be FN) and some partial date but instead by Force_no (shoukd be FN), the year, and then the month.
The fix would be to group by a concatenation of the year and month and to change the references to the fields to be what you renamed them as in your SELECT subclause using "...AS...", for example:
SELECT GIS_Subs.Force_No AS FN, DatePart("yyyy",GIS_Subs!Subs_Dt) AS AYear, DatePart("m",GIS_Subs!Subs_Dt) AS AMonth, DSum("Subs_Amt","GIS_Subs","DatePart('m', [Subs_Dt])<=" & [AMonth] & " And DatePart('yyyy', [Subs_Dt])<=" & [AYear] & "") AS RunTot
FROM GIS_Subs
GROUP BY FN, AYear & "-" & AMonth
ORDER BY AYear, AMonth;
So now you have only 2 GROUP BY parameters instead of three and the grouped results won't be done by FN, then year, then month, but by FN and year-month. [As for the "-" in GROUP BY subclause, you can use any character you want as the separator; I just picked "-" since it is so typical.]
The DSum function in the SELECT subclause may also need some rework; also, possibly you will need to return [Subs_Dt] in the clause as well so DSum() has it to work with. Also check to be sure that reference to [Subs_Dt] is being recognized OK without using the "table!field" form of reference. I dunno if you need it given I don't know your whole table-field definition and so can't say if there would be a naming conflict someplace.
If you are still having trouble, try starting over and building this query piece by piece, one field, one condition, one subclause, at a time until you get to where it breaks for you. That'll be the "threshold of failure" you are looking for that should point you further in the right direction.
I hope this works for you. Let me know how it goes!
Feb 23, 2008 | Microsoft Office Access 2003 (077-02871)...
Microsoft Access Query
Your date form is what it wrong. In order to use dates in Access with a BETWEEN function clause the values have to specifically be dates.
You can create dates in literal strings using the # sign to bound them, as in:
Select DISTINCT [ActivityDate] between #1/1/08# and #12/31/08#
#....# tells Access to treat this literal string as a date.
If you are using non-literal values, such as a parameter handed into the query, which would then be a variable, you can't use #some_variable# to cause Access to view it as a Date since #...# is for literal values only. To convert (also called "casting" a variable), use the CDate function. CDate likes to know what format to expect the string to come in though so it helps to pass that along, as in:
Select DISTINCT [ActivityDate] between CDate(begin_dt_string) and CDate(end_dt_string)
Remember the date string you pass into CDate has to be readable as a date by CDate. So make sure you pass in something that it can handle (use the IsDate() function to check to be sure so you can avoid a runtime datatype casting error). If your locale is US, then passing in x/y/z it will take for MM/DD/YYYY. If Europe, it will take it as DD/MM/YYYY. So keep that in mind.
To convert out of a date, use the FORMAT() function. That is how you get a date data type value to become a string value.
More fun reading:
http://www.techonthenet.com/access/functions/datatype/cdate.php
http://www.techonthenet.com/access/functions/advanced/isdate.php
http://www.techonthenet.com/access/functions/date/format.php
Hope this helps!
Feb 11, 2008 | Microsoft Office Access 2003 (077-02871)...
Excel
Prepare table having coloumns Client, Premium Amount , Month.
Now take Pivot table of the above table. Take Field 'Month' in Page field and Client in 'Row' field and sum of amount in 'Data field'.
If you refresh the data and select the required month you will get the desired information.
Sep 11, 2007 | Microsoft Office Standard for PC
Microsoft Office Standard for PC Logo
64 people viewed this question
Top Microsoft Computers & Internet Experts
Ekse
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
