SOURCE: Won't stop turning
There are some gears which move back and forth under the turntable which link to the plated Sometimes they just get stuck, sometimes just reseting them will resolve the issue. Sometimes you need to lubricate them since they a just getting stiff (only lubricate the center of the gears by the shaft they set on) It is rare that any parts are actually broken PS Protect the needle while attempting to service the unit Rob
SOURCE: Denon dp-35F turntable.
It apears the lead wiring contact arrangement is typically generic. Green over Red and Blue over white. I searched Google by images and found the wiring arrangement in a detailed photograph of a Denon headpiece with cartridge installed.
So always remember to draw a diagram before disassembling something.
SOURCE: Denon DP-29F belt is loose
please not this is when first set up but may help
• The drive belt is fitted under the platter. When assembling the
player, please handle the drive belt with care.
• Remove all packing materials attached to the tone arm, except
that on the stylus, and then open the dust cover and assemble.
Remove the stylus cover after assembling.
Hold the platter by the holes at its outer surface, and
then carefully lower the platter so that the center
spindle enters the center hole.
Rotate the platter until one of its outer openings is
aligned with the driving roller. (Refer to illustration.)
Gently grasp and pull at the ribbon tape of the drive
belt that is would under the turntable, and then
extend the belt around the driving roller. (After
attaching, remove the ribbon tape.)
In order to make sure that the drive belt has been
correctly fitted, slowly rotate the platter 3 or 4 turns.
Place the rubber mat on the platter.
IMPORTANT! Please Check.
Check that the drive belt and ribbon tape have been attached
under the platter. Grasp the ribbon tape as shown in the
illustration to the left, and extend it onto the driving roller.
L
R
L
R
L
R
ENGLISH
3 CONNECTIONS
SOURCE: Hello, the belt on my Denon DP-29F has come off,
Go here and find the manual. It shows the belt.
http://usa.denon.com/us/downloads/pages/instructionmanual.aspx
SOURCE: How do you adjust the
Basically, like almost any other turntable.
Look up the recommended tracking force for your cartridge/stylus.
Unplug the power to the turntable.
Using the tonearm elevation control, raise the tonearm.
Manually move the tonearm in toward the platter.
Manually rotate the platter ClockWise a few turns to disengage any cueing mechanisms.
Set the Tracking and Anti-skating controls to 0.
Disengage the tonearm elevation control. The tonearm will either float or drop. This is why we have no power, just in case it hits the platter.
Adjust the counterweight until the tonearm floats exactly horizontal. Use the flat portion of the tonarm rest as a gauge.
Return the tonearm to its rest.
Dial in the prescribed tracking force and anti-skating. Play records.
Register with http://www.vinylengine.com/ and find the manual here...
http://www.vinylengine.com/library/denon/dp-47f.shtml
