Question about RCA OPAL M4001 MP3 Player
Cd-rom is not working on this computer - RCA OPAL M4001 MP3 Player
  • 22 Answers
OK.... 1. What kind of Operating System? Mac? Windows 95/98/2000/ME/XP/Vista? Linux? 2. Did you click on My Computer>[Whatever letter your CD ROM is]? 3. Did you actually put the disc in the right way or in at all?
Posted on Oct 03, 2007
My TS-H653N CD Rom device does not work. What do
Buy a new one and replace it. Follow this tutorial on how to do it:
1. shut off your computer.
2. Unplug the power cord from your computer and the rest of the wires from the back of the computer.
3. find a sturdy flat surface on which to work on
4. unscrew all screws from the back of your computer except the power supply screws. You will make a mess if you unscrew the power supply screws.
5. open your computer up by taking the side panel off, or sliding the cover off.
6. unplug all plugs from the back of the cd-rom drive, there should be an IDE (wide) plug, a cd plug (small) and a power plug (medium).
7. unscrew the 4 holding screws on both sides of the cd-rom drive.
8. now, you just have to remove the cd-rom drive, carefully by sliding it either forward. Check the jumpers on your new cd-rom before moving to the next step. A typical cd-rom drive should be set on slave if it is using the same IDE cable on the same cable.
9. Do everything in reverse to install a new one.
Jul 19, 2010 | Compaq Presario 5000 PC Desktop
My cd rom in my computer hasnt worked for a while...recently my computer crashed so i thought it corrupted the cd rom but i swithched it with another cd rom from an old computer and it still doesnt work...
I just fixed a problem I had with my cd-rom where it wasn't burning my cd's. I downloaded the ASPI Driver for Windows from here and it fixed my problem. Without that driver, your cd-rom doesn't get fully reconized by the system basically. Let me know if this helps.
Jun 23, 2010 | Compaq Presario 5000 PC Desktop
CD ROMS WILL NOT WORK ON MY WINDOWS7
Some computers have 2 CD Roms. If you have 2 Roms make sure both are empty before you put your CD in.
Feb 14, 2010 | HP w2558hc 25.5" Widescreen LCD Monitor
I have brought a new computer that dosnt have a cd rom. I have tried putting in two different cd-roms but they wont show up on my computer. i have tried downloading drivers to help but it still wont work.
Hello !
Your CD-ROM should have at least two cables connected to it: a power cable and IDE cable that should also be connected to your motherboard. Disconnect and reconnect the cables and be certain that they are snug.
Some computers will also have a small third cable used to interface the CD-ROM with the sound card. If the audio for your CD audio CDs is not working properly verify that this cable is not disconnected from the back of the CD-ROM.
Hope this helps.
Sep 19, 2009 | Dell OptiPlex GX270 PC Desktop
Acer aspire 5520 cd rom drive is missing
use this tool to reset the cd in the registry
after you run the file - reboot the computer -
http://www.dougknox.com/xp/utils/XP_CD-DVD-Fix.zip
May 05, 2009 | Acer (99.B0311.002) Internal 50x CD-ROM...
My computer dont want to play dvd
Well, you need a DVD-ROM not a CD-ROM. If you have a CD-ROM and it's not playing then it's because you need a DVD-ROM and it's not working then I don't know, sorry! From Jake @ Dudey-Dreamz.piczo.com
Feb 23, 2009 | E-Machines emachines (emachinees) CD-ROM...
Cd-rom driver does not work
Insert the OS cd and turn off the computer. Start up and if work you will prompt to boot from cd.
Sep 24, 2008 | Compaq Presario Notebook
Cd rom has stopped working. the light is flashing as if it is working but the cd is not spinning.
Check the disk for scratches, and try other disks to make sure the problem is not unique to that one disk. If all disks fail, then double-click on My Computer, then double click on the CD-Rom drive and see if a CD will run. The "autorun" option may have been disabled, which is very noticeable if you've been used to this feature working. To re-enable autorun, right click on the cd-rom drive in My Computer, and go to device properties - recheck the autorun or autoplay option.
If none of the above resolve, then turn off your computer. Open up your computer with screwdriver. Unplug and replug the cd-rom driver. Restart computer. Test cd-rom drive again.
If it still fails, Make sure you are connected to the internet (I am assuming Windows XP - Vista may vary): Go to Start --> Control Panel --> Printers & Other Hardware --> System --> Hardware --> Device Manager --> DVD/CD Rom Drives - se if the drive has a yellow exclamation by it - if it does, then right click on the yellow exclamation, and click install drivers - windows will most likely find a solution
If all of the above fails, write back with more details, including model/manufatcurer of cd-rom drive, and model/manufatcurer of computer.
Jun 11, 2008 | Computers & Internet
Cd-rom
CD-ROM not working in Windows 9x, 2000, or XP. If after cleaning the CDs that do not read you're still getting errors ... If, however, the CD-ROM does not work, refer to the next and final possibility
CD-ROM recieving power but does not work. CD-ROM receiving power but does not work. Issue:. CD-ROM receiving power but ... CDs are read by a laser within your CD-ROM drive
Good Luck/Please dont for get to Vote, Thank You.
Dec 15, 2007 | Acer Aspire 3610 Notebook
RCA OPAL M4001 MP3 Player Logo
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
