Question about Kenmore 63672 Convection/Microwave Oven
Admiral oven E3V-81yr
I do not have the manual and when select Bake and temperature burners do not come on. I need to know the settings for the dials so its not the timer stopping the bake from not working.
  • 473 Answers
I would contact Sears parts and give them the entire model # from the sticker inside the unit and they can get a manual sent to you.
Posted on Oct 07, 2007
GE JVM1790WK convection microwave
I assume you've referred to your owner's manual to be sure you are operating the convection properly?
If for some reason you don't still have your owner's manual, you can get it here. See the tips on page page 30.
You can also do a hard reset by unplugging the oven for a couple of minutes, plugging it back in, then setting the clock and trying again.
If it's still not working, you may have a bad sensor or other problem.
Sep 04, 2012 | GE JE1590 Convection / Microwave Oven
Oven will not bake correctly when set to bake only the top element comes on
The problem is likely one of two things: Either the lower burner is shot and should be replaced, or there is a defect in the switch. The burner is the more likely problem if the upper burner is still working. If the lower burner works on any of the other settings it could be the switch, which would need to be replaced.
May 03, 2011 | Microwave Ovens
I have an electrolux convection model. the manual does not have suffiencient information on how to bake a cake. could you please explain me the precedure interms of the power selection, time required,...
Firstly I would suggest contact Electrolux for more info.
But in general all cakes are baked and no microwave energies are used.
An oven timer is critical to avoid over-baking.
Nov 02, 2017 | Electrolux E30MO75HSS Microwave Oven
I have an oven which I believe is a Kenmore model # 911.93251590 that the printed temperature numbers have worn off around the dials. I was hoping to find a picture of the stove or a manual assuming it...
Get an oven temperature gauge and place it in the oven, turn on the oven with the dial set at a near mid position letting oven stabilize in temperature. Read the temperature and mark the dial. Repeat at select positions marking the dial with the new temp setting.
Jan 27, 2018 | Microwave Ovens
My old GE oven (JSP38G052BG) won't bake or broil. It start then stop after 1 or 2 minutes. The heating elements get worm. Can you help me please
Hello ediben11.
If your oven's bake or the broiler heating elements won't heat but the range burners still work;the clock may be set for a timed or self-cleaning cycle. So,make sure to check the clock buttons and the knobs are set properly.
*If your clock has a knob that says "push for manual" then push the knob in after that, try the baking and broiling elements again.
*If it still does not work properly, you may have a defect in the thermostat/selector switch/common wiring.
*If the oven does not have a separate bake or broil selector switch; then the thermostat is probably the problem. It is not easy to check the selector switch or thermostat for proper operation. If you suspect a problem in this area, call a qualified appliance repair technician.
Hope this helps.
Mar 23, 2010 | LG LMVM1945 Microwave Oven
The bake function on the oven is not functioning the rotary dial adjusts the temp setting after the bake function is selected 350 temperature is selected and the temp flashes and stays at 100 without...
You probably have a bad bake element or control.
Please note that FixYa is not currently notifying us Experts when Clarification Requests are answered.
To allow us to help you effectively (at no charge), please post a
NEW problem to FixYa (but in the oven section, not in the microwave section), and please include your brand name and the full model number from the tag in or on the unit, and your symptoms.
You can find links to helpful exploded view diagrams and part ordering help here.
I'd recommend that your bookmark this link to your favorites.
Dec 11, 2009 | Roper Microwave Ovens
Wont heat
Hi!
Here are two instances when this happens---
  • When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
    You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
    If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
  • When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly.
    If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective.
    Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details.
    Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat.
    If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
If you find this solution helpful then do rate this solution.
Thanks
Rylee
Feb 05, 2009 | Kenmore Brew 'n Wave 63992/63999 Microwave...
Westpoint convection oven take more than a hour to bake chicken
Chances are you have a bad thermistor (internal temperature sensor).
Your owner's manual should have a number or Web address for Westpoint customer service.
They should be able to tell you where you can locate an authorized servicer or parts.
Dec 23, 2008 | Microwave Ovens
Kenmore 63672 Convection/Microwave Oven Logo
153 people viewed this question
Top Kenmore Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Kenmore Microwave Oven Expert? Answer questions, earn points and help others
