Question about Magellan RoadMate 700 GPS Receiver
White screen powering up it only shows a white screen.Won't do anything.Can't even power it off from the switch.Got to unplug it.
  • Anonymous Feb 11, 2008
    Same thing here however I know the cause. I dropped it when it fell out of the cradle. Since then it pwers up but nothing else. How hard is it to replace a hard drive (roadmate 700) and where would i get one?
    mike
    Novelist:
    Scholar:
  • 86 Answers
Dorub,
you do not get any sounds right?  If no, you need a  new hard drive.  There is no magic fix for a white screen.  Either your hard drive is corrupted..  if no sound it's your hard drive.  If there's is sound it could be your lcd connector.   As a matter of fact it could be your hard drive cable.  At your own risk feel free to open up the mysterious unit and make sure the big metal rectangular prism in there is properly connected.
Posted on Oct 15, 2007
  • Daniel daniel
    Daniel daniel May 25, 2008
    As far as where to get one of the 20GB HDD's I do not know. Maybe from Toshiba or Hitachi directly, but have not attempted this.
    -Daniel
SOURCE:
Tip
TV shows either: black screen with: white vertical or, horizontal line
If Your screen shows a: white vertical line on a black screen or, a white horizontal line on a black screen:
Your TV vertical or, horizontal power transistor or, chip is getting too hot.
A vertical line indicates the horizontal circuit is at fault, a horizontal line indicates the vertical circuit is at fault.
To troubleshoot: Turn on your TV untill the line shows then: after about a minute, remove power (unplug) the TV, remove the TV back cover, find the too hot transistor or, chip; using component coolant; spray the too hot component with the component cooler until the screen comes back to normal. To fix: apply white coolant cream to the back of the too hot transistor or, chip. or, if there is room, a small fan can be wired in to cool the part. Radioshack sells the cream and, also a "component cooler spray" that should find and, fix this problem, also; with power removed you can, if you feel it is safe; carefully (with only one hand) feel the part; it will be very hot! (it could burn your finger!) Do not touch anything else! (this will not hurt the tv; when the picture comes back on (the offending part has cooled) you have found the problem part.
on Apr 06, 2010 | Televison & Video
My monitor is a View Sonic vg181 I left my monitor on that night, now the power on switch just blinks and I cannot shut it off. When I unplug it and plug it back in, I can see the screen getting a bit...
It sounds like it's in PowerSave mode.
Switch off PC and monitor.
Unplug it from PC.
Leave for a minute.
Plug it back in and switch it on.
Power on monitor.
Read screen in case of error message like 'No VGA' or similar.
Dec 30, 2010 | ViewSonic VG181 (White) 18.1 in. Flat...
White screen on TV.
My TV does this too. i know how to remove the white screen but the top will still have power only vo4.52.00 to get rid of the white screen press 'return' on your TV remote (not direct tv remote) then change the input pack to whatever it is it needs to be on to watch your (whatever)
Apr 24, 2010 | LG 32LH30 32 in. LCD HDTV
I have a dual brand car monitor stereo that won''t show dvd
hi there
well to start the e-brake will need to be applied to allow you to see the video if it was installed correctly.................to over ride this feature you need a toggle switch with 3 pins on it
on the toggle switch there should be two logos (power & ground) if you run a small wire from the red wire from the back of your in-dash system to the toggle switch (power) and do the same for the black wire (ground wire)..........the last pin on toggle switch you attach the e-brake wire from the back of your in-dash system to the toggle switch pin and turn it on video will play
if this doesn't work switch the e-brake and ground wire around on the toggle switch
hope this helped
Nov 28, 2008 | Car Audio & Video
Powers on, Controller wont connect, nothing shows up
switch the hard switch off in the back of the ps3. unplug power cord... press and hold power button located on the front f the ps3 for approx 10 secs, then let it sit for a few, then hook it back up and turn the hard switch back on and try to power it back up.
I have had this happen once before but it did return to normal.
Nov 14, 2008 | Sony Playstation 3 (PS3) Console
Doesn't start
hi, if ur screen turns white, it could be any problem starting from ur LCD to motherboard or as u said a virus. to assist u in a right way i need to know what exactly is happening between that short duration between pressing the button and white screen. most importantly is anything else comming up on the screen before the white screen.
cheers
Oct 12, 2008 | HP OmniBook 500 Notebook
No pic/sound
If you dont here anything then it sounds like the switching power supply or the horizontal output circuits not starting up. this requires troubleshooting with a variac, as well as maybe a scope. If your not trained to work on HI Voltage circuits you should seek assistance with this repair. Theres HI voltage inside these sets even after they are unplugged for a while. sorry i couldnt be of more assistance.
Jun 25, 2006 | Philips Magnavox MS3252S 32" TV
Magellan RoadMate 700 GPS Receiver Logo
173 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Ekse
Are you a Magellan GPS Expert? Answer questions, earn points and help others
