Question about Toshiba Satelite 5205-S505 Notebook
Downloadinf programme from internet
My computer automatically logs off aqfter a minute or so.
  • 32 Answers
1. Reload the BIOS.
2. Go to Safe Mode.
3. Let the computer run by itself without opening up any programs.
4. Do an msconfig to disable all the start up programs except for the antivirus.
5. Check for viruses.
Posted on Oct 15, 2007
    New Friend:
  • 50 Answers
Following ponts to be seen 1. see wheather your outlook is open- if open see that the box -hang up when finished is checked if checked den un check it.
Posted on Sep 30, 2007
6ya staff
SOURCE:
I want to install Macfee antivirus but l am not see where to add to key code
It is automatic when you pay for the programme.
Why pay for a programme that clogs up your system when iobit.com does it properly for free?
Speed Up Slow Computer Keep PC and Internet Secure Freeware Download IObit
Oct 15, 2016 | Computers & Internet
I have a bt internet address and share use of my computer with my sister, when i attempt to click on my email address hers comes up, help! am not computer savvy.
That one's pretty easy, Janet. Your computer is trying to automatically log into whichever email account was last used. When you click on your email address and hers appears, find the "Log Out" link somewhere on that page. Now you should be able to log into your own email account using your own username and password.
Aug 06, 2014 | Computers & Internet
Yahoo Messenger for Vista Automatically sign out!!!
try checking if there can security configurations in yahoo messenger., you can find it in preferences. there may be a timeout configuration if no activity is met within 2-4 minute. or maybe there is a problem with your internet connection. because if yahoo messenger have not recieve any incoming internet connections, it automatically logs out. pm me if you still have the problem. Thank you.
Aug 07, 2009 | Computers & Internet
Internet Not Responding
Sounds like your best bet is to go back to Windows update and let them run all the way through before starting any further actions. Your daughters computer was fine because it did not require the same updates.
Aug 06, 2009 | Computers & Internet
Installing BT Voyager 105 on XP Pro PC shows newdev.dll error
I recently had this problem after buying a voyager 210 modem/router to replace the voyager 105 (in my case supplied for AOL broadband)
I tried to uninstall the voyager 105 and encountered exactly this problem - newdev.dll missing, Admin privileges required
After alot of Internet searching I found no answers. But in desperation tried this and it worked. I am by no means any computer expert so don’t blame me if this does not work for you, or damages your machine.
To install my 210 modem I was following instructions found here -http://www.sohodata.co.uk/soho.htm But first I had to get rid of the 210
Here is what I did, exactly as I did it (some of it is probably unnecessary) Further below is a condensed version I expect would work.
1) Firstly I restarted in safe mode by pressing F8 in start-up ( I was doing this because i had remembered an administrator profile and considered attempting to uninstall from there.)
2) I logged on as the administrator.
3) Attempted to uninstall the voyager 105 via control panel and via the uninstall icon in the programme folder. - Both Failed with the above-mentioned problem.
4) I navigated to programme files. (Start> My computer> C drive> Programme files)
5) There I highlighted the folders "British Telecom”, "BT Voyager 105 ADSL modem", " Voyager Modem Drivers", "Voyager Test". I cut these folders wholesale and pasted them to my USB pen/stick (incase I needed to put them back)
6) I then ran disk cleanup (Start> All Programmes> Accessories> System Tools.)
7) Then I turned off my computer and unplugged the USB pen/stick and the USB and DSL cables from the back of the Voyager 105.
8)I turned the computer back on (starting up normally), logged on with my normal username which has admin privileges. Ran the driver install for my new router (previously downloaded from BT at –(http://www.btopenworld.com/broadband/adhoc_pages/driver_homepage.html#yahoodrivers) It stated that a BT driver was already installed.
9) Navigated to add/remove programmes (Start> Control panel> add/remove programmes) selected the BT driver from the list selected uninstall …. AND IT DID IT! No error, or messages about newdev.dll or privileges.
10) This left me free to install my new driver and go through its install process ending in plugging the USB into the back of the modem and having internet again.
Here is what I expect would work
1) Turn on and log on to any account with admin privileges.
2) Navigate to programme files. (Start> My computer> C drive> Programme files).
3) Select and delete (or to be safe, cut and paste to a removable drive) the folders "British Telecom", "BT Voyager 105 ADSL modem", " Voyager Modem Drivers", and "Voyager Test".
4) Remove removable drive and run disk clean up (Start> All Programmes> Accessories> System Tools).
5) Then I turned off my computer and unplugged existing modem.
6) Turn on computer log back onto account with admin privileges. Navigate to add/remove programmes (Start> Control panel> add/remove programmes) selected the BT driver from the list selected uninstall.
7) Install desired drivers/modem.
If you find this works for you too and have asked this question elsewhere, please copy this solution so others can solve this problem too
Jul 11, 2009 | Computers & Internet
Can't Sign into Windows...How to do system reboot if I can't log in to windows?
Hi e_norris
Do you have either the Windows installation disk or a Recovery Disk. Some manufacturers ship the Recovery Disk with the PC others require you to create one when you first turn the computer on.
May 02, 2009 | Computers & Internet
Will not log on to internet
belkin router F5D7230-4
wireless works fine, anything plugged in gets cut off after a few minutes.
Dec 14, 2008 | Belkin (F5D7230-4) Router (587009)
My Toshiba Laptop
click Start>>Run>> (type)Msconfig>>Click ok
System configuration utility window will open up
U will see few tabs at the top like General,Startup
Click on startup tab
At the bottom click disable all>>Close>>It will ask for restart
Restart the computer
when the computer restarts you will get the message
You have used the system configuration utility
Check the box at the bottom Do not Show this Message Again and click ok
Now you wont see the icons that use to load up on the right bottom of your system,however they have not been deleted just hidden,if you want to access any of those programmes that use to appear before
Click start>>All Programmes>>and clik the application you need to open.
May 25, 2008 | Toshiba Satellite A105 Notebook
Toshiba Satelite 5205-S505 Notebook Logo
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
