Question about Altec Lansing VS4121 Speaker
One speaker my right speaker stopped working. I have checked all the plugs and cords, and all seem to be in perfect condition. It will adjust volume and other settings, but no sound comes out.
  • sun_shine Sep 30, 2007
    so how could I check that?
    New Friend:
  • 50 Answers
The reason would be. 1.the spaker coil is open. 2. the speaker connection to the wire may be dry solder.
Posted on Sep 30, 2007
SOURCE:
My Bose speakers stopped working. They are properly plugged in and seem to be getting power, but no sound.
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
if you dont have a motherboard disc you will have to download the drivers
hope this helps you
Aug 27, 2011 | Bose Companion 2 Series II Multimedia...
BA 635 subwoofer stopped working. green light in the back does not light up anymore. Can it be the power supply cord? It this common? Solution? How can I check if it is a power cord issue?
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
also
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
make sure you have an earth ******** before touching any parts inside your computer
hope this helps
Apr 27, 2011 | Boston Acoustics BA735 Computer Speakers
Why does the audio out is so low???
check whether the volume is low...
double click on the speaker icon on the system tray and then check if all the options has the volume set to max..
Mar 14, 2011 | Toshiba Computers & Internet
Very low volume coming from speakers
i have exact same problem i think its got something to do with volume controller on front right speaker damn shame as the sound was awesome
Jun 02, 2010 | Altec Lansing ADA745 4 Speakers
I just got a couple ativa speakers and I can not get sound out of them. I have a HP Pavilion a6200n. I have the ativa cord plugged into the same spot that my old speakers were plugged into, so I'm...
check your audio setting>>> go to control panel>just locate, sound and devices> check the volume, if mute option is have check, please uncheck and adjust the all option related to volume. if doesn't work just buy a sound card... see to it before you buy a sound card test your speaker first to other pc. if it is work to other pc you need to buy a sound card.
Nov 28, 2009 | Computers & Internet
I cant get my speakers on my computer to work
Computer speakers are specially designed for a computer desktop environment. They are smaller than normal stereo speakers and often have built in volume controls and amplifiers. In most cases, you can plug in your computer speakers and have them work immediately. Occasionally, however, you will need to adjust your computer sound settings to get them to work correctly.
  1. Step 1 Plug your speakers into each other. Most PC speakers have a detachable cord that goes between them. Powered speakers have a cord that plugs into the wall, which may be detachable as well.
  2. Step 2 126401_thumb.jpg Image Courtesy of: http://www.hardware.windowsreinstall.com/soundcards.htm Look at the sound card output in the back of your computer. If your soundcard has three colored jacks, plug into the green one. If it does not have colored jacks, plug into the one next to the jack with the picture of a microphone. Plug the power supply into a wall socket.
  3. Step 3 Turn on the speaker, turn up the speaker volume and play some music. If it doesn't work, continue to step 4.
  4. Step 4 Turn your volume up on whatever media player you are using. If the music still doesn't play, continue to step 5.
  5. Step 5 Go to the volume settings. If you are using windowsmag-glass_10x10.gif, click Start Menu -> All Programs -> Accessories -> Entertainment -> Volume Control.
  6. Step 6 Adjust the volume settings. Use your mouse to drag the main "Volume Control" slider and the "Wave" slider all the way to the top. If either of them have the "Mute" box checked, uncheck it. Try the sound again.
Nov 14, 2009 | Sony SRS-D21 Computer Speakers
Low volume on creature speakers
Your speaker volume must have reset. You have to touch the dots on the right speaker to turn up the volume to desired volume. I just remembered that on my system. Hope this helps.
Jun 14, 2009 | JBL CREATURE II Computer Speakers
JBL Creature Speakers have very low volume
use another device like your i pod to make your jbl sounds louder and then plugged it to your pc without turning it off. after plugging try to test it if works.
Apr 02, 2009 | JBL CREATURE II Computer Speakers
Altec Lansing VS4121 Speaker Logo
316 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Don Hart
Ekse
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
