PC Desktops
Problem for PC Desktops
Generic problem for all PC Desktops
Sata, ide
By babies on Sep 30, 2007
i have 2 sata hard drives and 1 ide hard drive. how can i run all 3 and boot from 1 of the sata drives?
Same Problem
Mar 09, 2008
-   I have Gateway GX7018E. Currently, I have 2 Sata Drives. What I need is to add one IDE hard disk as a slave. How can I do that? Please help me. Thank you.-   Guest
Best Solution
posted on Oct 03, 2007
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
The sata hard drives do not have jumpers
Solution #2
posted on Oct 01, 2007
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
why u want to do these unnecessary thing.
if u want to do. go through the steps.
1. YOUR SYSTEM MUST BE SWITCHED OFF.
2. REMOVE SYSTEM CABINET.
3. INSERT ONE IDE CABLE TO YOUR MOTHER BOARD.
4. CONNECT MIDDLE ONE TO YOUR SATA HARD-DISK.
BUT IT SHOULD BE BOOTABLE DISK.
5. CONNECT LAST ONE TO ONE MORE SATA HARD-DISK.
INSERT JUMPERS TO THIRD PLACE, WHICH IS
ALLREADY WILL BE IN FIRST PLACE.
6. NOW TAKE ONE MORE IDE AND CONNECT TO ONE
END TO YOUR MOTHER BOARD AND OTHER END TO
NEXT HARD DISK.
THERE IS NO NEED TO CHANGE JUMPERS.
GOOD LUCK
PURUSHOTAM
Solution #3
posted on Sep 30, 2007
Somewhat Helpful)
vijiu
Rank: Apprentice
Rating: 78%, 2 votes
First thing you turn off the power then remove the cabinet keep the first sata hard drive as master (Between Data cable & Power supply) there you have four pins from left first pin keep the jumper it is going to be as master & the second sata drive keep it as slave & the third ide hard disk you donot keep any jumpers ok.
Was this helpful?
Yes
No
Solution #4
posted on Aug 04, 2008
Not Rated)
magic69er
Rank: Apprentice
Rating: 0%, 0 votes
ok, i had to comment on this, first off, to the person who posted before, you cannot connect a IDE connector to a SATA drive, SATA drives take SATA connectors. To introduce myself i am a highly trained computer technician. Second off, SATA drives do not have jumpers at all, period!! Ok, you should just use the two sata drives if thats what *********** board is set up for. Pluggin you your os drive in SATA connector 1 on your MB. Slave drive in SATA connector 2 on MB. Then you are good to go, Good Luck!!!
Was this helpful?
Yes
No
Solution #5
posted on Jan 15, 2008
Not Rated)
conradinsf
Rank: Apprentice
Rating: 0%, 0 votes
Just wondering if there is room for a third SATA drive in this machine. I looked inside, and it looks like there are only two connections. I wanted to add a third SATA drive. Any ideas how to do add a third SATA drive in the 670?
Was this helpful?
Yes
No
Popular Solutions for PC Desktops
Questions and Unsolved Problems for PC Desktops
Answer
What is the best NAS for about $300 (+, - $100)? I was looking at... (More)
Answer
sx2800 how is it compared to other brands its size
Answer
windows will not remember to keep me signed in on yahoo or face book
Answer
When starting the computer, it stops at a black screen and does not open into Windows.
Answer
I hve a compaq presario 5000 desktop. It will boot up to the desktop with these errors QTTask Error... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Desktops Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
