Question about Nokia E61 Smartphone
Screen always white no data displayed
I drop my phone and now the screen is always white. i can not see any of the setting. do you have any ideas how i can fix this
The connection at the top of your display is disconnected.
Posted on Mar 22, 2008
Buy a new one
Posted on Sep 30, 2007
6ya staff
SOURCE:
Ive dropped my phone multiple times and it's always been fine, but last night i dropped it and the screen is white. is there anything i can do without having to pay for a new phone and/or damages?
chech if the contact to the display has been cut. This you can confirm by noticing whether the display atleast lights up any way. if it does not there may be a disconnection between power supply to your display. Also check of cracks on the screen. if there are cracks you may have to change the screen. I HOPE THIS HELPS YOU
Jul 18, 2011 | Samsung Cell Phones
It has lost display
Hi, display lost is classified in different areas:
When a phone has VIRUS in it, it might make the screen go white, through downloads from the internet or from another cell phone through data cable transfer or blue tooth.
Solution: Needs to be flashed.
Also when there is screen damage.it can make the screen go white. You will know if it is the screen when you switch on the cell phone and you can still operate the phone with out seeing anything.
Solution: you will need to replace the screen.
You can use the link below to replace the screen .
formymobile.co.uk/6700disassembly.php
And also when a phone drops on the phone, and the screen shifts from it's position,that can also cause white display on cell phone.
You can use the above link to use and check for screen shift...
Hope it helps.
Take care...
Mar 11, 2011 | Nokia 6700 Classic Cell Phone
Every time i am out in the cold my phone seems to break.The screen turns white and colorful lines appear to be moving across it. Does anyone have any idea as to why this is happening and what i can do...
The screen turns white is because the screen is a liquid crystal display and it can not exceed certain tempurature drop. If it gets too cold it will crack.
Oct 20, 2010 | Nokia 5800 XpressMusic Smartphone
My N72 is not showing any display... just a simple white colour screen
Did your phone drop on the flow? Is it just showing white and still works ?or Display white screen and not working?
For a phone to display a white, does questions need to be answered..
If it fell on the flow it's usually a screen fault and it needs to be replaced.
If it didn't fall down, but displays white screen and nothing function,it a software faulty needs a memory restoring..
If just showing white screen and you still can make calls with it, then it's screen fault needs to replace..
Feb 11, 2010 | Nokia N70 Cellular Phone
No display white Screen keys are working
ok try this but all data will be lost it will factory reset ok
try this if it helps
hard rest factory default settings = when ur set is switched off press both buttons call and end key and then press power button on upside of pda for like 5 sec screen will appear asking to format all data take out ur card if u dont want to format that now confirm by pressing the centre action button in 4 side joystick and go
if not solved then go to www.htc.com for latest Rom update downlaod and update backup ur data first
pls rate me fixya if i fixed ur problem
Dec 02, 2008 | HTC P4350 Smartphone
White Screen No Work
have the LCD/screen replace...take it to a mobile tech and have that done.
Dec 26, 2007 | Samsung SYNC SGH-A707 Cellular Phone
Sagem my501x blank white screen
the fone is ****, thats why. it boasts all features when it came out, but couldn't handle them well.
It's like having 3 biscuits in your mouth and trying to speak, its possible, but its hard.
Oct 31, 2007 | Sagem My501X Cellular Phone
My screen wont work!! :s
hav u dropped ur h.set ?if yes contact lg  care center. if not then take the back up of data & reset ur h.set .check display settings & try to set some theme.
Oct 21, 2007 | LG Shine KE970 Cellular Phone
Dropped phone with a white screen
Hello, Your phone's display is operated by 2 separate wire ribbons. One of them sends data to the display's matrix and the other one powers the led backlight. A display doesn't produce light on it's own so instead it utilises some white led's to light up. What you see on the display are actually those led's lighting up from under the display. I supose your problem is with the display connector. However the phone must be dissasembled and the display connector must be checked. In order to do this you will need some T5-T6 screwdrivers (they can be found at most radioshacks or electronics store). Locate the display's connectors and with the phone opened, try to move them around a bit to see if something is showing on the display. Also check all the connectors on the phone mainboard for cracks or other defects. I'm sorry for I can't help you more with this on a simple chat. If you have any questions however, please ask and I will try to guide you through this process.
Sep 09, 2007 | Samsung SGH-D520 Cellular Phone
White display on VX9800
The display contains of two main supplies. One is for the data which gets displayed on the screen and the second one is for a thin sheet containing the led's for light. It appears the the data connection has been lost. It can be due to a loose connection for complete malfunction of the screen. If the connection is not loose then the screen needs to be replaced
Apr 12, 2007 | LG HBM-300 for VX9800 Wireless Headset
Nokia E61 Smartphone Logo
135 people viewed this question
Top Nokia Computers & Internet Experts
Anthony Ward
Anthony Ward
k24674
Ekse
Are you a Nokia Computer and Internet Expert? Answer questions, earn points and help others
