The bell is there to remind you your keys are in the ignition when the engine isnt running so you dont lock your keys in the car accidentally. You can unplug the bell under your dash, but I dont recommend it. If you do, make sure you have a spare key handy. Locating the bell can be challenging, but just listen to where it seems to be coming from and disassemble the dash at that point. You should be able to find it then.
SOURCE: bell ringing
the switch that shuts off the dome light and chime is part of the door latch and is broken
SOURCE: warning bell does not turn off
quick solution till u get it fixed would be to remove the steering column.....few bolts......then cut the small green wire that goes into the ignition harness.....this is the key warnings power.....I literally just came in from cutting mine.....but that was because I put in an engine start button
SOURCE: ignition won't turn, can't get car out of gear (manual)
the shift interlock fuse may be blown. check your fuse panel.
SOURCE: door ajar light stays on after i close the door
I had the same problem in my 98 and 96 Sables. Ford dealer says it is a problem with a sensor, located behind the left rear quarter panel. It doesn't recognize when the doors are closed, therefore it leaves the dome light, etc. on--sometimes briefly, but possibly until the battery goes dead. Worse when the weather is damp. Their solution was to throw it on the diagnostic computer BUT ONLY WHILE THE PROBLEM IS ACTIVELY HAPPENING, then replace the sensor--they quoted me a minimum of $300. I leave the cover off the dome light, and pull the bulb when necessary.
SOURCE: 97 cadilac devile drains battery overnight
possibly alternator could be draining it ,or glove box light or visor light staying on causing it to drain out
