Question about Beverage-Air Freezer K Series Reach in Freezer 2 section 449 cuft
Freezer water line frozen
Drip line frozen. Defrosted as normal. Turned back on now fans will not go on...
  • Beverage-Air Master
  • 4,655 Answers
Sounds like your defrost sensor is not working the sensor should return the fan running and cooling after it senses 50 degrees in the condensor housing unplug the sensor and check if it shows a closed circuit. First unplug the freezer for your safety
Let us know what you find.
Posted on Oct 21, 2007
  • John Tripp
    John Tripp Oct 21, 2007
    Also the defrost element coud be bad or have a burnrd connection
SOURCE:
Where is the evaporator fan motor? My Freezer and fridge would quit cooling/freezing. I took the back panel off in the freezer a week ago and the evaporator coils were completely frozen over with ice. I...
I do not believe the problem is the fan. sounds like the frig. is low on Freon this is what will cause the ice build up. you need to find the leak, you can do this by spraying soapy water on coil tubes & watch for bubbles. repair leak & recharge.
May 25, 2015 | Samsung RS261MDBP Side by Side...
Water on floor
The hose that goes into the drip pan to defrost the refer is plugged with stuff.
take the back off and see the hose connection.A coat hanger works well.Usually a 1/4" hose.
Also see where the bottom of the freezer drains into the drip pan.That may be plugged,also.
The temp may be set too low and the condenser is frozen up,leaking water into the floor.Just ice stuck to the condenser.
Possible that the condenser FAN stopped turning. That will ice up and melt at random:
see/hear that the fan is working.
If stuff gets into the fan,it will ice up,melt and make a mess on the floor.
Nov 26, 2012 | Sub-Zero 700 Refrigerator Freezer...
I have a Daewoo FRN U20DA type american fridge freezer. The Ice maker has sropped working. There is no water getting into it. There is water getting through to the water dispenser in the front door. the...
The water filter should be changed every six months, not two years.
The water lines may still be frozen even though you turned the unit off, but most likely you are not getting water flow due to a clogged filter. Change it.
Feb 26, 2011 | Daewoo Freezers
Not freezing on top shelf of door
try to replace the Styrofoam cup then put on the top.. if the same happens.or it will be frozen it means styrofaom is .................................. then use another...
Jun 22, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
Door was left very slightly open. reclosed but so...
This is normal when compressor starts u can hear some gurgling from evap. from feron flowing. If you hear gurgling only when you close the door it's water in drain pan when you close the door air is forced down drain tube blowing air into water.
May 17, 2010 | Freezers
Not really cold, Defrosted it and put everything back from the coolers and the water btl on the door hasn't frozen all day. The frozen meats are holding their own and staying frozen but not real cold in...
u've brocken the coolent circulating pipes which v;ll be surrounded in the freezer box....!! due to the leakage of compressed gass....its not getting cold,.
thnak u sir...
all d best, have a great day
Jul 18, 2009 | Freezers
We purchased a small haier chest-type freezer in 2006. It has worked fine until the past week. It seemed to be running normally, but suddenly did not keep the food frozen solid. There was a little ffrost...
You may have a refrigerant leak. First make sure the lid has not warped and leaving an air gap for heat to enter. That's really about all you can do without getting a tech. involved.
I’m happy to assist further over the phone at https://www.6ya.com/expert/david_dc2f9e0a44104720
Jan 01, 2018 | Haier 3.5 cu. ft. Chest Freezer HNCM035E
BEKO Frost free freezer not as cold as it should be!
hi i have same problem one of my lodgers left the door open and it froze thick with ice i defrosted it and let it dry for 3 days and was fine for a couple of days then it defrosted so i switched it of for 24 hours it worked fine for a day before it defrosted again could you email me with any help thanks [email protected] matt
Apr 12, 2009 | Freezers
Frozen water on the bottom of my Amana freezer
Your drain line is clogged. Take a small diameter pice of wire and snake out the drain line from inside the freezer.
You may have to access the back rear near the compressor and separate the drain line there and clean it further.
Apr 07, 2009 | Amana Freezers
Upright freezer not cooling
The model number would help but it sounds like a sealed system leak or restriction. If thats the case I would not suggest trying this yourself. The water should freeze overnight and the frost should keep going to all the shelfs that have coils in them.
Apr 16, 2008 | Freezers
Beverage-Air Freezer K Series Reach in Freezer 2 section 449 cuft Logo
181 people viewed this question
Top Beverage-Air Freezers Experts
Dennis Boxerman
Michael Youngman
Michael Youngman
Todd B
Are you a Beverage-Air Freezer Expert? Answer questions, earn points and help others
