One thing you can check is the condensation line to see if there are wires going to it. This is the plastic pipe coming out of the indoor unit. If there is a float switch and the condesate line is clogged then it will not allow the a/c to operate. If the line is clogged you can use a WET/DRY vacuum on the end of the pipe which should be next to the outdoor unit. Hope this solves the problem. Good luck. Keep me posted please.
I appreciate the response, but the unit is very old. it doesnt have a float switch. you can hear the r-22 going thrugh the lines, just no fan.
